Old 06-26-2022, 06:21 PM   #1
Nick.brz
Drives: 2013 Subaru BRZ
Is this something to be concerned about?
Noticed this after jacking my car up due to a flat tire… is this bad?
Getting the tire patched up tomorrow, Is it ok to leave the car jacked up like this over night or should I put the tire back on and use the rear jack point?
I am assuming I should probably bend it back after…
Size:  287.6 KBName:  FA304FB0-A930-4AF7-8C13-5611CD35C121.jpg
Nick.brz is offline   Reply With Quote
Old 06-27-2022, 02:40 AM   #2
Not safe to leave it lifted with a hydraulic jack. Stand would be fine. If you choose to straighten it, make sure you never bend it again. Jacking this car from the side is a challenge.
jcw99 (06-27-2022)
Old 06-27-2022, 11:15 AM   #3
Sasquachulator
Pavement Grey
I wish these car manufacturers would make these side jacking points a bit more sturdy than just a indicator cutout in the vertical bended steel portion. seems like failure/damage is more likely to happen using a hydraulic jack than the oem provided scissor jack.
Old 06-27-2022, 11:33 AM   #4
Ohio Enthusiast
Drives: 2018 BRZ
You just need to use the correct saddle for a pinch weld car. Yes, I bent my share of pinch welds using inappropriate jacks and jack stands, but now I use proper jack stand rubber pads with the cutout for the pinch weld rail.
The important thing to remember is that the pinch weld rail is there just to locate the jacking point - the actual structural weight bearing point is on the car itself.
After seeing what some other cars use for jacking points (both flat rails as well as brackets) I still prefer a pinch weld as it is much easier to locate and a proper saddle has less change of slipping.
The Following 2 Users Say Thank You to Ohio Enthusiast For This Useful Post:
NoHaveMSG (06-27-2022), Tcoat (06-27-2022)
Old 06-27-2022, 01:50 PM   #5
blsfrs
blsfrs's Avatar
Drives: 2013 frs base
Which wheel are you working on? Jacking on the seam to lift just one wheel shouldn't cause a problem. With that jack, positioning in the middle of the car would be a nono. Was your jack able to roll as you lifted the car?
Old 06-27-2022, 04:30 PM   #6
Nick.brz
I was working on the back right wheel, did not have access to a low profile jack and had limited space in the front and back as it was not in my garage. ended up jacking at the front right jack point since the jack did not fit under the back right jack point. I slowly lifted the car but frame still ended up bending. ended up just putting a spare on and will stay away from the side jack points.
The Following User Says Thank You to Nick.brz For This Useful Post:
blsfrs (06-27-2022)
Old 06-27-2022, 04:41 PM   #7
Not the end of the world. I mangled one of mine too.
Old 06-27-2022, 07:06 PM   #8
I will take a pinch weld indicator cut out over the death traps that many of my cars came with!
Nothing like taking the end of the car up 24"s to barely get the wheel off the road while the whole thing is resting on a base the size of a couple of playing cards.
Dadhawk (06-27-2022), g e (06-29-2022)
Old 06-27-2022, 07:34 PM   #9
Lantanafrs2
Drives: 2013 frs red
I've seen quite a bit of this on older cars that have been racked up for oil changes,services etc. Cars are usually lifted on the drip edges.
Lantanafrs2 is offline   Reply With Quote
Old 06-28-2022, 02:54 AM   #10
dpfarr
Drives: BRZ ts
For future, these are a good idea.
https://shopfigs.com/v5/L6006
dpfarr is offline   Reply With Quote
The Following User Says Thank You to dpfarr For This Useful Post:
Ultramaroon (06-28-2022)
Old 06-28-2022, 06:46 PM   #11
Code Monkey
Drives: Subaru BRZ
This is how I use jack stands, never had a problem (second picture the jack could be a bit more to the left).
Code Monkey is offline   Reply With Quote
The Following 2 Users Say Thank You to Code Monkey For This Useful Post:
Espi (06-28-2022), Ohio Enthusiast (06-28-2022)
Old 06-29-2022, 01:30 AM   #12
I've considered that but I worry that it could slip. Even though the side load on the stand is small, it's there. There's no "saddle."
blsfrs (06-29-2022)
should i be concerned? mcnvgget Suspension | Chassis | Brakes -- Sponsored by 949 Racing 13 11-06-2019 10:12 PM
Should I be concerned GotBRZ1691 Engine, Exhaust, Transmission 26 09-17-2014 08:17 PM
Should I be concerned with coolant and oil level? B-R-Z Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 18 01-28-2014 01:03 AM
Concerned with reliability... should I be? hmong337 Scion FR-S / Toyota 86 GT86 General Forum 37 07-01-2013 08:02 AM
