Old 06-26-2022, 07:15 PM   #1
clio
Drives: 2013 Subaru BRZ
Questioning the wisdom. Brake bleeding and hose swap
I swapped out my brake setup to Brembos from a performance pack model.
Obviously the brake system needed to be bled. All advice on the forum concerning a brake bleed sequence, at least from what I read, points to furthest to closest from the master cylinder.
Looking however through the Subaru workshop manual for the BRZ the sequence is the opposite - it starts at the wheel closest to the master cylinder. What gives?
Another snippet I have from Subaru is a TSB to apply brake friendly grease along the thread of the brake hose banjo bolt that screws into the caliper. Note this TSB applies to Brembo calipers only. I have never heard of this practice before. The torque value for the bolt does not vary. I assume this provides a better seal. I followed it - but thought it was odd.
clio is offline   Reply With Quote
Old 06-26-2022, 07:22 PM   #2
soundman98
ProCrastinationConsultant
soundman98's Avatar
same as torqueing lug nuts clock-wise, or counter-clockwise.
the difference is just a difference.
i always do the furthest first specifically because it'll take the most fluid, and is usually the hardest. i like to leave the easier side to last so i can relax once i'm finishing up, instead of working myself up right before finishing.
Old 06-26-2022, 07:49 PM   #3
clio
In many modern brake systems that the wheel that is furthest from the master cylinder does not necessarily have the longest route. This might(?) be the case for the 86/BRZ as the workshop manual sequence ends with the rear wheel that is not furthest from the master cylinder.
I always figured the bleed sequence was good to follow.
Old 06-30-2022, 09:20 PM   #4
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
I do closest to farthest. To me, bleeding farthest first is like washing your car from the bottom up
Old 06-30-2022, 10:13 PM   #5
Ohio Enthusiast
Drives: 2018 BRZ
The Toyota service manual says "Bleed the brake line of the wheel farthest from the master cylinder first." under brake fluid replacement.
Old 06-30-2022, 10:24 PM   #6
soundman98
soundman98's Avatar
so clearly, the answer is "yes".
Old 07-02-2022, 03:06 AM   #7
EndlessAzure
Wheels for Brains
EndlessAzure's Avatar
You're also supposed to bleed the inside pistons of the Brembo Caliper before the outside pistons. This goes a little bit against the "furthest away" rule of thumb, but the order as far as corners of the car remains the same
EndlessAzure is offline   Reply With Quote
Old 07-03-2022, 07:34 PM   #8
clio
... here is the 2020 Subaru BRZ workshop manual extract
https://imgur.com/a/Tcg7Bi3
Old 07-03-2022, 08:01 PM   #9
Ohio Enthusiast
Drives: 2018 BRZ
Mindblown. Also, I thought that the corner opposite of the master cylinder is the furthest away, which would be the rear left in a right-hand drive car (as you have in Australia), but this says to bleed rear right last...
I wonder how much variance there is between the different services manuals (Toyota/Subaru and different markets).
Old 07-03-2022, 09:03 PM   #10
clio
Also note the sequence in the 2020 BRZ workshop manual, the typical 'Z' pattern (ie: RR RL FR FL) that is typically followed whether bleeding rear to front or vice versa is not traced - rather it travels in circular way around the car. The brake line routes may not run as imagined.
Hose size for bleeding brakes Xbk47 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 15 07-30-2019 08:41 AM
brake bleeding, air in abs? Grip Ronin Suspension | Chassis | Brakes -- Sponsored by 949 Racing 13 11-22-2018 07:34 PM
Brake Bleeding - How to Cycle ABS Valves? Jamestl Tracking / Autocross / HPDE / Drifting 4 11-11-2018 11:01 PM
Addition of a radiator hose sensor temp adapter & coolant bleeding FutureFT86 Engine, Exhaust, Transmission 9 07-21-2014 11:50 PM
Brake bleeding order? ubersoph Suspension | Chassis | Brakes -- Sponsored by 949 Racing 1 08-10-2012 07:13 AM
