Old 06-19-2022, 08:53 AM   #43
David G 23
Drives: 2016 FR-S
Originally Posted by B T View Post
My ACE A350 header has twice melted my passenger side sway bar bushing.
What was the solution for this? Did you find a bushing that stood up to the heat or add some heat shielding? I have a ceramic coated ACE header and I just melted the Whiteline bushing that comes with their 22mm bar.
David G 23 is offline   Reply With Quote
Old 06-20-2022, 11:33 AM   #44
B T
Drives: 15 BRZ, 2003 MR2, '70 Elky, 06 TBSS
Thats the exact same setup I have. From what I recall, I lined the area with heat reflective tape and haven't looked at it since. It hasn't melted a second time. I also moved the supercharger coolant lines up out of the way to let heat escape up through the gap between the heads and frame rail more easily.
B T is offline   Reply With Quote
Old 06-20-2022, 11:35 AM   #45
B T
one more note the on Ace headers, my exhaust flange at the header separated from the collector tube. It looks like a very clean break, so I can't attest to ACE's welding abilities. Pulling it and putting on a JDL 4-2-1 header as soon as it comes in the mail.
Old 06-28-2022, 08:50 AM   #46
Tatsu333
Drives: 2020 BRZ Sport Tech RS
ACE A350 headers are back in production / in stock! I had inquired with them a while back and didn't hear anything, and then out of the blue this morning I got this email:
"Our headers are officially back in stock with an improved redesign. Please have a look at our website for more details:
https://aceheader.com/A350-GT86-FRS-...DER-p133843673"
Tatsu333 is offline   Reply With Quote
The Following 4 Users Say Thank You to Tatsu333 For This Useful Post:
AllThePeat (07-27-2022), Lantanafrs2 (06-30-2022), StraightOuttaCanadaEh (06-28-2022), villainous_frx (06-28-2022)
Old 06-28-2022, 09:28 AM   #47
SuperTom
SuperTom's Avatar
Drives: C5, GT-86, '24 Colorado TrailBoss
Wow I wonder what they changed
SuperTom is offline   Reply With Quote
The Following User Says Thank You to SuperTom For This Useful Post:
ballsdeep (06-29-2022)
Old 06-28-2022, 10:17 AM   #48
churchx
churchx's Avatar
Drives: 2014 GT86
Now at this price they still seem viable option. Slight con - if from themselves, no ceramic coating option.
The Following 3 Users Say Thank You to churchx For This Useful Post:
B T (07-25-2022), DocWalt (08-18-2022), PulsarBeeerz (06-28-2022)
Old 06-29-2022, 03:25 AM   #49
MrSkubi
MrSkubi's Avatar
Drives: 24 GR Yaris, 23 GR86
I got mine from them about 2 years ago (great service btw) at the same price as it's listed now and got it coated locally to me. Came out nice and it's working well because after quite a bit of track abuse I still haven't melted anything.
MrSkubi is offline   Reply With Quote
Old 06-29-2022, 09:12 AM   #50
ballsdeep
ballsdeep's Avatar
Drives: Ocho-Seis
What's improved about the redesign?? No real info on their website
ballsdeep is offline   Reply With Quote
The Following User Says Thank You to ballsdeep For This Useful Post:
SuperTom (06-30-2022)
Old 06-29-2022, 10:00 AM   #51
Espi
Espi's Avatar
Drives: 17 BRZ
looking at the previous post and https://aceheader.com/A350-GT86-FRS-...DER-p133843673
looks like the collector is shorter and after the collector the tubes are slightly longer to the overpipe flange. awesome!
Espi is offline   Reply With Quote
The Following User Says Thank You to Espi For This Useful Post:
Old 06-29-2022, 10:51 AM   #52
ballsdeep
ballsdeep's Avatar
Drives: Ocho-Seis
Looks can be deceiving! Unless there's an old vs new design side-by-side comparison with measurements, its all speculation. A write-up or explanation by the manufacturer of the improvements would be nice.
Espi (06-29-2022)
Old 06-29-2022, 10:57 AM   #53
Tatsu333
To me it appears that the primaries are exactly the same, but they moved the flange in the secondaries section further downstream (maybe to reduce turbulence by putting it in a straighter section?), and made the secondaries a *tiny* bit shorter overall, with the collector pipe being a corresponding little bit longer overall (which I believe is primarily for greater fitment compatibility between LHD and RHD models).
I'd guess that the changes were mostly done for fitment, and the fact that there may be a slight improvement in performance is just an added bonus...
The Following User Says Thank You to Tatsu333 For This Useful Post:
ballsdeep (07-03-2022)
Old 07-18-2022, 11:25 PM   #54
Windycitystig
Drives:
Would the redesigned ace header work with the Delicious Tune?
Windycitystig is offline   Reply With Quote
Old 07-18-2022, 11:26 PM   #55
Windycitystig
Drives:
Which heat reflective tape brand did you use?
Old 07-19-2022, 06:45 AM   #56
spcmafia
spcmafia's Avatar
Drives: 2018 Subaru BRZ
I would say yes. Like other tuners, it would take them a couple of runs to determine the best parameters.
If you mean changing the headers and using an existing tune by D.T, it could work, but I wouldn't recommend it. Always good to optimize any upgrades done to existing equipment.
spcmafia is offline   Reply With Quote
ace, ace 350, aceheader
STI Lip Kit Discontinued? ADabOfOppo BRZ First-Gen (2012+) — General Topics 12 10-15-2015 11:08 AM
Top Speed Auto UEL Header Discontinued raven1231 Engine, Exhaust, Transmission 11 09-28-2014 12:42 PM
FR-S / BRZ Discontinued? Thatruth2001 Northwest 16 06-27-2014 03:30 AM
BRZ MIGHT BE DISCONTINUED AFTER ONE GEN?? airjonny BRZ First-Gen (2012+) — General Topics 37 06-24-2014 01:47 PM
openflash header replica? toby714 Engine, Exhaust, Transmission 30 06-05-2014 02:11 AM
