Old 06-17-2022, 06:48 PM   #15
Capt Spaulding
Persona Non Grata
Capt Spaulding's Avatar
Drives: '15 BRZ (WRB)
Originally Posted by DarkPira7e View Post
With the ATOTO A6, it considers itself a tablet, rather than a headunit, so Ecutek loads and functions. I have the Ecutek Connect dongle, which plugs into the OBD port (just like any other dongle) and lets you datalog, set up dashboards, like the example one I have in my photo. The head unit also has 2 bluetooth channels, so the OBD dongle connects to 1 channel, and my phone connects to the other, it's pretty neat.
Irace86's gauge pod setup was my desktop background for quite a while at work, haha
LOL. Do you know if the A6 can run an app such as Torque that can display the OBD2 data without the ECUtek interface?
Slow is smooth, and smooth is fast
Capt Spaulding is offline   Reply With Quote
Old 06-17-2022, 07:53 PM   #16
DarkPira7e
Rust bucket enthusiast
DarkPira7e's Avatar
It runs a mobile android OS, so if you can run it on a phone, it will work on this. Even Pokémon Go (but you can't change from landscape to portrait orientation, so Pokémon Go won't display properly)
Old 06-17-2022, 09:45 PM   #17
FunnyGopher
Drives: 2015 BRZ Limited
I'm running a P3 gauge right now. The car is really only street driven. I live in the hot desert, so my worry is always oil and coolant temps. I basically leave the gauge on oil temp at all times. Being an OBD digital readout, it's nice to be able to flip through the different metrics and recall their highest and lowest values. Having recently supercharged the car, it's been interesting to see the before and after values of everything.
Harrop Supercharger | Delicious Tuning Flex Fuel Kit | ACE Type-A 350 Header + OP | CSG Touring 86 Catback | RacerX Fabrication Catch Can | Jackson Racing Dual Radiator/Oil Cooler | Tuned by Zach from CSG
FunnyGopher is offline   Reply With Quote
The Following 2 Users Say Thank You to FunnyGopher For This Useful Post:
B T (06-22-2022), BlaqkHavok (06-30-2022)
Old 06-22-2022, 12:57 PM   #18
B T
Drives: 15 BRZ, 2003 MR2, '70 Elky, 06 TBSS
I'm running just the P3 gauge as well. I've also added an oil pressure sensor to it's inputs. It's been very useful clearing codes when I didn't have my scanner handy.
B T is offline   Reply With Quote
The Following User Says Thank You to B T For This Useful Post:
Old 06-22-2022, 10:52 PM   #19
villainous_frx
Off to the track!
villainous_frx's Avatar
Drives: '14 Lava 86, '13 WRB BRZ
TRD Sport Meter w/ Blitz gauges
villainous_frx is offline   Reply With Quote
The Following 2 Users Say Thank You to villainous_frx For This Useful Post:
BlaqkHavok (06-30-2022), Wally86 (06-23-2022)
Old 06-23-2022, 02:05 AM   #20
chicken tonight
Originally Posted by bree View Post
You can’t argue with our excellent spam posts
reported
Ultramaroon is online now   Reply With Quote
Old 06-23-2022, 06:55 AM   #21
reported
LOL "Bree"
Ultramaroon (06-23-2022), Wally86 (06-23-2022)
Old 06-23-2022, 09:23 AM   #22
Sapphireho
helmholtz resonator
Sapphireho's Avatar
Drives: '15 ultramarine
How do you read and clear codes with a P3?
Old 06-23-2022, 03:04 PM   #23
B T
You scroll through the readouts to where it shows active codes, then hold down the select button and it clears it. Been using it for about 5 years on mine.
Old 06-28-2022, 06:16 PM   #24
86TOYO2k17
Drives: 2017 toyota 86
Scangauge II for AFR, coolant temp, Oil temp, trans temp
Had drivers side air vent pod for boost gauge, and passenger side air vent pod for WMI flow gauge.
The Following User Says Thank You to 86TOYO2k17 For This Useful Post:
Old 06-30-2022, 05:24 PM   #25
BlaqkHavok
Drives: 2014 DGM BRZ
Thank you! yes that is very much my style as well, going for an OEM+ finish on the install of anything that has an aesthetic appeal.
personally i will also be looking for where in the fire wall that i can run a new batch of wiring. through that i will be running any signal wires as well as a dedicated power and ground lead that goes right to a split distribution block.. pos+ always on, pos+ ignition (relayed from dedicated + in), and negative.
i have half a notion to go with a threaded pass-through like a mil-spec plug.
Originally Posted by Muskoka800 View Post
Just into the installation process so no pictures yet.
Going with the Blockhead dual gauge mount which snaps in replacing the side window vent.
Innovate digital oil pressure / oil temp and water temp / battery voltage gauges will be installed.
At this point my under hood sensors are installed only. Next is to route the leads through the firewall and up into the vent. The wire bundle for three sensors with there shielding is quite bulky so routing to the gauges is a bit of a challenge. Taking my time for an OEM clean installion.
BlaqkHavok is offline   Reply With Quote
Old 06-30-2022, 05:30 PM   #26
BlaqkHavok
nice! and is that a zetronix ethanol content gauge in the vent?
Originally Posted by BirdTRD View Post
Similar to @Irace86.2.0, Ortiz gauge pod with Defi Racer N2 boost and oil pressure.
Old 06-30-2022, 05:35 PM   #27
BlaqkHavok
WMI flow gauge? i don't think I've seen that b4, do you have a link to the gauge or how to set one up?
Old 06-30-2022, 06:54 PM   #28
86TOYO2k17
I passed a lot of stuff through the sound tube opening once that was deleted.
I also used a tap a fuse wired to a new mini fuse box for easy access to eng on fuses. Alternatively you could do tap a fuse to a relay to have added fuse box wired directly to battery if you planned on running more current through it than a tap a fuse can handle. Or a split box for always on and eng on.
BlaqkHavok (07-01-2022)
Gauges j_ros94 Cosmetic Modification (Interior/Exterior/Lighting) 20 08-06-2019 11:55 AM
BRZ gauges in an FRS? salvega83 Southern California 2 12-19-2017 05:56 PM
Gauges Lunatic DIY (Do-It-Yourself) Guides 14 07-04-2014 02:59 PM
WTB: Gauges AtlasMick Engine, Exhaust, Bolt-Ons 2 03-29-2013 12:04 AM
Gauges CyberFormula Scion FR-S / Toyota 86 GT86 General Forum 45 07-24-2010 06:26 PM
