Old 06-15-2022, 08:36 PM   #1
BlaqkHavok
Drives: 2014 DGM BRZ
So what are yall using for gauges for ur boosted builds? (SHOW ME UR GAUGES!)
so, im trying to see what all everyone is doing for gauges for all of the important things... i know i would prefer to have OLED, and to that end looking at the AEM X-series as my fall back if i dont happen to find any other gauges that i like... i would love to have a full set of the GReddy Sirus gauges, but at around $800 a piece, that's just too much to have tied into a part that would easily get stolen.
so actual question is for yall that have gone boosted;1, what kind of gauges have you gotten to monitor your vitals. and 2;what company/line have you used, and liked/not liked, that is not AEM, Innovative, or Prosport gauges? oh, or OBD2, like the P3...
I would break em down into groupings of critical, necessary, and nice to have.
My critical are: wideband O2, Boost, and Oil pressure.
For me my necessary are: coolant/oil/trans/ temps, E%.
and for nice to have: would be diff/Air intake/ air compressed/ fuel/ temps, W/M fill level, and TMPS tire pressure and temps per tire.
what i would like is to find some good, clean, OLED gauges for the "critical" gauges. OLED/led scale and digital read out for the "necessary" gauges. And perhaps a screen/tablet used as a mulit-function display for the "nice to have"
i can see the critical costing the mos. the necessary being mid-level cost. and the "nice to have" be a custom build possibly based on an 8inch tablet with an arduino piping info to the screen.
im open to any and all suggestions, cuz my current search's have me finding the current main stream gauges to be overly... meh
thank you in advance!!!
BlaqkHavok is offline   Reply With Quote
Old 06-15-2022, 10:05 PM   #2
DarkPira7e
Rust bucket enthusiast
DarkPira7e's Avatar
I just have boost and a wideband. I plan to add oil pressure to the wideband (it has customizable inputs). I monitor everything else on the ECUtek Bluetooth app.
Old 06-16-2022, 12:44 AM   #3
Irace86.2.0
Irace86.2.0's Avatar
Drives: Q5 + BRZ + M796
Ortiz custom gauge pod with Defi oil and pressure gauges and vent Defi boost gauge.
Old 06-16-2022, 03:00 AM   #4
ojuniour
ojuniour's Avatar
Drives: Subaru BRZ 2017
you successfully completed the swap?
ojuniour is offline   Reply With Quote
Old 06-16-2022, 03:52 AM   #5
FunnyGopher
Drives: 2015 BRZ Limited
He's had those in his car for a good while now. Way before the K swap started.
Harrop Supercharger | Delicious Tuning Flex Fuel Kit | ACE Type-A 350 Header + OP | CSG Touring 86 Catback | RacerX Fabrication Catch Can | Jackson Racing Dual Radiator/Oil Cooler | Tuned by Zach from CSG
FunnyGopher is offline   Reply With Quote
Old 06-16-2022, 06:58 AM   #6
BlaqkHavok
@DarkPira7e Thank you! i haven't decided if i want to replace my factory head unit, but that one you have looks clean, and the ecutek Bluetooth is done via the Bluetooth dongle at the OBD2 port and bluetoothed to that head unit? apps on the head unit loaded via WIFI or on an SD card?
Old 06-16-2022, 07:03 AM   #7
BlaqkHavok
@Irace86.2.0 Thank you! wow! those Defi Gauges look great! and just about perfectly match the stock ones... i have a 17PP BRZ, but ill check Defi out, see what they got. its been a good while since i've looked into their product line. very clean setup!!!
Old 06-16-2022, 07:39 AM   #8
DarkPira7e
DarkPira7e's Avatar
With the ATOTO A6, it considers itself a tablet, rather than a headunit, so Ecutek loads and functions. I have the Ecutek Connect dongle, which plugs into the OBD port (just like any other dongle) and lets you datalog, set up dashboards, like the example one I have in my photo. The head unit also has 2 bluetooth channels, so the OBD dongle connects to 1 channel, and my phone connects to the other, it's pretty neat.
Irace86's gauge pod setup was my desktop background for quite a while at work, haha
Old 06-16-2022, 09:56 AM   #9
Muskoka800
Drives: 2016 Scion FRS Release Series 2#439
Just into the installation process so no pictures yet.
Going with the Blockhead dual gauge mount which snaps in replacing the side window vent.
Innovate digital oil pressure / oil temp and water temp / battery voltage gauges will be installed.
At this point my under hood sensors are installed only. Next is to route the leads through the firewall and up into the vent. The wire bundle for three sensors with there shielding is quite bulky so routing to the gauges is a bit of a challenge. Taking my time for an OEM clean installion.
Edelbrock S/C with CSG 94 & 91 maps
TRD Short Shifter, CTS-V/EvoX Brembos
Ohlin’s R&T Dampers, Hotchkis F/R Bars, Blox LCA & Toe Arms
235F/245R Conti ECS on TRD/Enkei wheels (street),
245/40 sq. ECF on 17x8 720Form GTF2 wheels (track)
Muskoka800 is offline   Reply With Quote
Old 06-16-2022, 12:38 PM   #10
Just waiting for the first person that recommends gauges on the A pillar!
Old 06-16-2022, 04:59 PM   #11
Muskoka800
Yes, airbag propelled gauges could be exciting.
Old 06-17-2022, 08:53 AM   #12
Grady
Grady's Avatar
Drives: BRZ Yellow, Ranger, Evora, WCM S2K
I did it!
Old 06-17-2022, 10:23 AM   #13
BirdTRD
Simply Forgotus
BirdTRD's Avatar
Drives: 2014 Supercharged SSM BRZ Limited
Similar to @Irace86.2.0, Ortiz gauge pod with Defi Racer N2 boost and oil pressure.
BirdTRD is offline   Reply With Quote
Old 06-17-2022, 12:06 PM   #14
Irace86.2.0
It can be removed.
Gauges j_ros94 Cosmetic Modification (Interior/Exterior/Lighting) 20 08-06-2019 11:55 AM
BRZ gauges in an FRS? salvega83 Southern California 2 12-19-2017 05:56 PM
Gauges Lunatic DIY (Do-It-Yourself) Guides 14 07-04-2014 02:59 PM
WTB: Gauges AtlasMick Engine, Exhaust, Bolt-Ons 2 03-29-2013 12:04 AM
Gauges CyberFormula Scion FR-S / Toyota 86 GT86 General Forum 45 07-24-2010 06:26 PM
