Very aggressive engine braking all of a sudden
Yesterday, out of nowhere i noticed that my car has way more aggressive engine braking. Its very noticeable that as soon as you lift the throttle it slows down alot, before you could pretty much coast in gear with no gas and it would only decrease a tiny bit.
Even downhill, in gear with no gas it slows down unless the hill is very steep. Something feels wrong. I thought first that the brakes might be dragging on? I drove the car for 2 hours on the highway, stopped and put my hand around the wheels and there were no heat at all from any corner, so i dont think the brakes are dragging. The other part i would think would be an issue is the tune? But that has been the same for over a year so i dont see how that could be the issue. Next time im out i'll try and let it coast downhill not in gear, and i should be able to tell if its any brakes on. But i dont think this is the issue as mentioned above. |
#2 |
Drives: 2013 frs red
Auto I assume?
#3 |
Drives: 2016 BRZ Limited
The new engine braking behavior you're describing sounds more correct than the older description.
My total guess is that your throttle plate wasn't closing all the way before but now it is. My engine braking is strong enough that if I don't use it, I won't be able to slow down enough to make corners at the track even with upgraded pads. The only modification that might add power to my engine is a K&N filter. Are you able to collect any data through an OBD-II dongle or something? Addendum: Reading the reply above made me realize that I assumed your car is manual. |
#4 |
Geo Tyrebighter Esq
Drives: '13 scion fr-s
Is the air filter old or possibly got water into it recently?
Has Iceland been popping off again :/
"I gotta rock." -- Charley Brown |
| The Following User Says Thank You to bcj For This Useful Post: | JD001 (06-21-2022) |
#5 |
Did you move the floor mat?
#6 |
#8 |
Drives: Subaru BRZ
Have you checked/changed your cars fluids?
| Poor idle after engine braking, OFT | demasrv | Software Tuning | 3 | 11-13-2020 10:54 PM |
| Sudden lean 17AFR, but then sudden rich 10AFR??? No codes | D-VO | Software Tuning | 4 | 12-11-2019 12:17 AM |
| Engine Braking or lack thereof | arren123 | Issues | Warranty | Recalls / TSB | 28 | 03-14-2018 06:46 PM |
| Engine Braking - Questions | soulreapersteve | Engine, Exhaust, Transmission | 19 | 06-20-2015 03:08 AM |
| Engine Braking | Wattage | Scion FR-S / Toyota 86 GT86 General Forum | 75 | 01-16-2013 02:51 PM |
