Old 06-08-2022, 01:36 PM   #57
Matt93SE
Drives: 2013 FR-S, 2017 BRZ
Originally Posted by blsfrs View Post
I don't know what Element Tuning does, but my OP is over 100psi when I'm over 4000rpm. When my engine was rebuilt after the rocker arm/timing chain disaster, my new engine guy didn't see anything unusual with the oil pump or other components except an aftermarket oil pick up tube. Per Element's instructions, I run Mobil 1 10w30.
What engine temp are you seeing those oil pressures?
I'll see 120psi at idle in my car when it's cold, but only 10 or so at operating temp. I have like 40psi at 4000rpm when it's hot.. (redline 5w20 race oil)
thicker oil will surely make a diff here, but that high seems strange.
Matt93SE is offline   Reply With Quote
Old 06-08-2022, 05:59 PM   #58
blsfrs
blsfrs's Avatar
Drives: 2013 frs base
Damn, 100PSI !!!
Are you on an element block? I have my suspicions on a couple things they do. I need to figure something out before I start spinning 8k rpm.
Yes. Initial built was 3-4 years ago. Manley rods, JE pistons, Ferrea valves and springs and whatever mojo he does with machining. I would have taken the engine back to him but he has since moved to Florida.
The Following User Says Thank You to blsfrs For This Useful Post:
NoHaveMSG (06-08-2022)
Old 06-08-2022, 06:05 PM   #59
blsfrs
blsfrs's Avatar
Operating temperature taken at the sandwich plate. It does sound high but Element Tuning did alot of R+D on his FRS before he switched to an LS for more speed in TT. That's what sold me on their engines.
Old 06-08-2022, 08:04 PM   #60
100 PSI at test temp/speed with 10w30 feels about right. I reach the oil pressure plateau at around the same speed but it reaches 75 PSI and stays there with 0w20. That's why I focus on controlling temp with my unnecessary oil cooler. I figure I'm safe as long as it sheds enough heat to keep the numbers in line. I should stick a probe in the pan to see how hot the oil gets after it goes through the engine.
I see 115 PSI at idle when it's cold.
blsfrs (06-08-2022)
Old 06-08-2022, 09:54 PM   #61
CSG Mike
CSG Mike's Avatar
Originally Posted by FrickingReallySlow View Post
Mike you mean FA24 and not 2017+ shortblock right? was this during product development or testing the limits on a dyno? did they fail on the rod/bearing or did the failures look different from FA20
random FA24, on the street. Not surprising when you know the context of what they're doing.
blsfrs (06-09-2022)
Old 06-09-2022, 06:48 AM   #62
mike2100
mike2100's Avatar
Drives: 23 BRZ
"hooning"?
mike2100 is offline   Reply With Quote
The Following 2 Users Say Thank You to mike2100 For This Useful Post:
blsfrs (06-09-2022), TommyW (06-09-2022)
Old 06-09-2022, 10:09 AM   #63
TommyW
TommyW's Avatar
Drives: '13 Whiteout
Originally Posted by mike2100 View Post
"hooning"?
lol. When I hear someone say they blew their motor but they have never tracked their car…
TommyW is offline   Reply With Quote
The Following User Says Thank You to TommyW For This Useful Post:
Icecreamtruk (06-09-2022)
Old 06-09-2022, 12:57 PM   #64
Icecreamtruk
Drives: Track preped NA FRS
lol exactly. "I was just cruising at 50mph on the highway", in second gear, sure you were cruising...
Icecreamtruk is offline   Reply With Quote
The Following 2 Users Say Thank You to Icecreamtruk For This Useful Post:
TommyW (06-09-2022), Ultramaroon (06-09-2022)
Old 06-09-2022, 01:01 PM   #65
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
"the oil was full and golden."
The Following 2 Users Say Thank You to NoHaveMSG For This Useful Post:
Icecreamtruk (06-09-2022), Ultramaroon (06-09-2022)
Old 06-09-2022, 01:28 PM   #66
ZDan
ZDan's Avatar
Drives: '23 BRZ
100psi seems unusually high, excessive even...
https://www.rymax-lubricants.com/upd...w-to-solve-it/
The ideal oil pressure varies depending on the car brand and model, but generally, the ideal oil pressure is between 25-65 PSI. To an extent, oil pressure is required for the oil to be able to reach all components of the engine, however if the oil pressure reading is outside of this range, it is usually considered too high or too low. Since the oil pressure depends on how much resistance the oil faces when flowing through the passages, factors like the size of the engine, the diameter of the bores, and the viscosity of the oil have an impact on oil pressure. A PSI over 80 is usually considered too high for the engine to properly be protected from damage. High oil pressure is an indicator that the oil is not able to properly pass through the bores and reach all parts of the engine effectively.
The Following 3 Users Say Thank You to ZDan For This Useful Post:
blsfrs (06-09-2022), Icecreamtruk (06-09-2022), Ultramaroon (06-09-2022)
Old 06-09-2022, 02:12 PM   #67
I should have been clearer when I said "It feels about right." I meant that it's in range for 10w30 at normal temp. I agree that it's too high.
UOA... UOA... UOA
soundman98 (06-09-2022)
Old 06-09-2022, 03:00 PM   #68
RedReplicant
Drives: None
Proper oil pressure should probably come down to what the builder tells you.
The quoted text there is a generalization, 100psi is not abnormal in some stock motors. My stock K24 with K20A oil pump makes between 95 and 110psi at load and 35-45psi at idle.
RedReplicant is offline   Reply With Quote
The Following 2 Users Say Thank You to RedReplicant For This Useful Post:
blsfrs (06-09-2022), Ultramaroon (06-09-2022)
Old 06-10-2022, 08:32 AM   #69
Scargod
Track Day Junkie
Scargod's Avatar
Drives: 2022 BRZ Limited
No blown engines in 2017 track cars!
I bought my 2022 BRZ based on the success of my two track buddies with their BRZ's. They each have 2000-3000 track miles on their 2017's. The Yellow Special Edition has 11K on it and the white car with PP has 60K.
These guys are instructors and they thrash their cars every event trying to outdo each other.
They have oil coolers, aftermarket exhaust and are both tuned by EFI Logics to 190 HP. They have had no engine issues.
I have an oil cooler. I've done four track days and have 2K on my car.
We are all retired, know how to drive and take excellent care of our cars. They get regular oil changes when raced.
Them at Watkins Glen. If you're in the N-E you probably know them.Name:  steve jotham 9.png
The three of us at WGI before they got their BRZ's.
Name:  three muskateers-1.jpg
Scargod is offline   Reply With Quote
The Following 5 Users Say Thank You to Scargod For This Useful Post:
blsfrs (06-10-2022), MrSkubi (06-10-2022), new2subaru (06-10-2022), TommyW (06-10-2022), Ultramaroon (06-10-2022)
Old 06-10-2022, 10:26 AM   #70
blsfrs
blsfrs's Avatar
How was the change going from WRX to BRZ?
VR6 engines... dem00n Other Vehicles & General Automotive Discussions 29 01-25-2013 01:41 AM
100 hp/l NA engines einzlr Other Vehicles & General Automotive Discussions 95 11-15-2012 07:55 PM
What other engines fit our transmissions 1strwdcar Engine, Exhaust, Transmission 36 08-02-2012 04:45 PM
So you think you know engines? Ryephile Other Vehicles & General Automotive Discussions 43 02-04-2012 03:49 AM
