Old 06-01-2022, 10:26 PM   #29
Danny318
Drives: 2019 BRZ
I really messed up this with my car. Even though I am running a smaller wing and splitter setup I didn't anticipate how much higher the loads would be and my current suspension setup is not up to the task. So even though the car ended up around 2 sec a lap quicker at most tracks, it's a handful in some situations and really hasn't had all it's performance unlocked.
What suspension and spring rates do you run?
Danny318 is offline   Reply With Quote
Old 06-02-2022, 04:57 PM   #30
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
RCE T2’s in 7kg springs.
Danny318 (06-05-2022)
Old 06-06-2022, 10:27 AM   #31
M0nk3y
Originally Posted by TommyW View Post
Correct. However it depends on how much downforce you have dialed in. Too much to where at low speeds it's noticeable then it's most likely compromising speed in the straights so you need to find that balance. Plus as discussed, less planted in slower corners is faster
Positive rake a lower speeds, neutral or slightly neg at high speeds.
Spring Rates, Wing, AOA of Wing etc etc all play into effect when trying to properly setup a car to be balanced at all speeds possible.
Can you bolt on a wing and be faster? Sure maybe. Can you maximize the impact it can offer? No
Kyle H. - #89 STX
The Following 2 Users Say Thank You to M0nk3y For This Useful Post:
Icecreamtruk (06-06-2022), NoHaveMSG (06-06-2022)
Old 06-06-2022, 09:40 PM   #32
Danny318
Drives: 2019 BRZ
Me too. Do you think 8k or 9k would be enough to compensate the aero?
The Following User Says Thank You to Danny318 For This Useful Post:
jflogerzi (06-10-2022)
Old 06-06-2022, 09:50 PM   #33
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
I dunno. It’s going to depend on your setup. I am trying 10kg based on what others are running but may try some different rates down the road.
The Following 2 Users Say Thank You to NoHaveMSG For This Useful Post:
Danny318 (06-06-2022), jflogerzi (06-10-2022)
FS: SARD LSR Style Carbon wing **wing only* brzzy Canada Classifieds 3 03-23-2017 09:58 PM
Does anybody have seibon gt wing or apr gtc200 universal wing on their car? spicyricecake Cosmetic Modification (Interior/Exterior/Lighting) 6 03-17-2016 08:38 AM
FS: Used OEM Limited Wing - Dark Grey Metallic - with STi wing gurney Enalband24 Exterior Parts (Aero, Lighting, Etc.) 10 01-03-2016 12:24 PM
Wing or no wing? (rear spoiler) quik1987 Scion FR-S / Toyota 86 GT86 General Forum 123 12-12-2011 06:11 PM
