Old 06-01-2022, 06:22 PM   #141
nextcar
Guilt free parts vulture!
Drives: 2024 GR86 Trueno Halo 6MT
Post install follow up and public service announcement....
So I ordered two of the 2017 revised door checks and installed the driver's side today. I no longer have to back into my sloped driveway to protect my shins! Fantastic!
Why didn't I install the passenger side? Here is the public service announcement: The two studs tack welded to the door check are made out of incredibly soft metal and can easily snap when tightening the nut by hand...
Ask me how I know.
Originally Posted by drewbot
Pull out
nextcar is offline   Reply With Quote
The Following 2 Users Say Thank You to nextcar For This Useful Post:
bcj (06-02-2022), FrickingReallySlow (06-02-2022)
Old 06-02-2022, 02:56 PM   #142
e_lunatic
Drives: 2015 Scion FR-S
Ask me how I know.
i'm doing the install of this next week. would it be worth it to throw a better tack on the nut or just be easy on it once it gets tight?
e_lunatic is offline   Reply With Quote
Old 06-02-2022, 03:19 PM   #143
nextcar
The tack did not break, the actual stud did. My guess (I was not using a torque wrench) is that it took much less than 20 ft/lbs of force to snap the stud... so take it easy with the two nuts.
Since these nuts do not bear any real load I would just snug them up and not really apply much force at all. If you want to torque them, I would not go past 10 ft/lbs <<< WRONG!!!
EDIT: as pointed out below, the correct spec is 5.5 ft/lbs.
Pull out
The Following User Says Thank You to nextcar For This Useful Post:
e_lunatic (06-04-2022)
Old 06-02-2022, 03:29 PM   #144
AJ32162
Drives: 2019 BRZ with Performance Package
The BRZ Shop Manual specifies 5.5 ft./lbs. (66 in./lbs.) for the door check nuts.
AJ32162 is offline   Reply With Quote
The Following User Says Thank You to AJ32162 For This Useful Post:
nextcar (06-02-2022)
Old 06-02-2022, 03:32 PM   #145
Originally Posted by AJ32162 View Post
The BRZ Shop Manual recommends 5.5 ft./lbs. for the door check nuts.
Dzmitry (06-08-2022), e_lunatic (06-04-2022)
Old 06-02-2022, 03:38 PM   #146
nextcar
Ha! I don't have a 3/8ths torque wrench that goes lower than 10 ft lbs... unless I break out the 1/4 inch one for my bike that is in inch lbs!
Without doubt the shop manual is the way to go if you have access to one, and you should always follow the manufacturers opinion!
And it does not take "guns" to exceed 5.5 ft lbs!
Pull out
Old 06-07-2022, 07:05 PM   #147
nextcar
Did we do this?
The 2017 revised part is currently unavailable anywhere in the US, and backordered...
Pull out
Ultramaroon (06-07-2022)
Old 06-07-2022, 08:14 PM   #148
I will check Canadian supplies if you want.
Old 06-07-2022, 08:54 PM   #149
nextcar
I'd be curious and it may help others, but in all honesty I personally will just wait. I fixed my driver's side, and rarely have a passenger so it is not that big a concern for me.
Pull out
Tcoat (06-07-2022)
Old 06-07-2022, 11:53 PM   #150
That's hilarious.
Old 06-08-2022, 07:33 AM   #151
That's hilarious.
Going to pull them off the wife's outback when we trade it in. Worth a fortune on the black market.
bcj (06-08-2022), Dadhawk (06-08-2022), ermax (06-08-2022), Ultramaroon (06-08-2022)
Old 06-09-2022, 11:38 AM   #152
e_lunatic
weird i must have gotten the last ones as my dad brought them for me last weekend
The Following User Says Thank You to e_lunatic For This Useful Post:
Tcoat (06-09-2022)
Old 06-09-2022, 11:58 AM   #153
FrickingReallySlow
Drives: 2015 FR-S
Lots of recyclers/dismantlers that have them. No one ever buys those things at the junkyard
FrickingReallySlow is offline   Reply With Quote
The Following User Says Thank You to FrickingReallySlow For This Useful Post:
Tcoat (06-09-2022)
Old 06-09-2022, 12:37 PM   #154
Probably like $5 if you pull yourself.
Door Open Switch Raz BRZ First-Gen (2012+) — General Topics 7 04-10-2022 05:07 PM
Door open light rosol16 Issues | Warranty | Recalls / TSB 6 11-22-2015 12:42 PM
Door wont stay open cregor Issues | Warranty | Recalls / TSB 21 06-11-2013 11:43 PM
Door Open Buzzer cmspooner Cosmetic Modification (Interior/Exterior/Lighting) 5 08-13-2012 10:20 AM
