Old 06-02-2022, 01:21 PM   #1
darkofrs
Drives: 14 frs; drift spec
slow crank, followed by clicks, no start
battery has already been replaced, i’m thinking it’s most likely something in the wiring harness or maybe bad spark plugs? not my car it’s a friend’s
https://streamable.com/pbjal2
darkofrs is offline   Reply With Quote
Old 06-02-2022, 02:34 PM   #2
DarkPira7e
Rust bucket enthusiast
DarkPira7e's Avatar
Did you put a new battery in and try right away? Old "new" batteries sometimes still need to be charged. Slow crank to clicking is indicative of not enough power. Get a battery pack on it or let it charge on jumper cables for a while
Old 06-02-2022, 02:54 PM   #3
fableluke
Drives: BLue 2013 frs
Sounds like battery is dead.
fableluke is offline   Reply With Quote
Old 06-02-2022, 06:10 PM   #4
Grady
Grady's Avatar
Drives: BRZ Yellow, Ranger, Evora, WCM S2K
Battery/Battery connections. Clean everything up.
I think we need a sticky of how to use a volt meter!
Old 06-03-2022, 02:29 AM   #5
In addition, I suggest the battery be put on a charger fer ah few hours.
Old 06-03-2022, 03:39 AM   #6
soundman98
ProCrastinationConsultant
soundman98's Avatar
Don't know why, but got called an a hole last time I brought up that unless everyone was bitten by a special radioactive spider, none of us can see electricity...
Old 06-03-2022, 02:54 PM   #7
Grady
Grady's Avatar
So you calling me an A-Hole?
Old 06-03-2022, 08:33 PM   #8
soundman98
soundman98's Avatar
welcome to the club?
we meet on tuesdays.
Old 06-04-2022, 01:35 AM   #9
Bubba can. He just puts one end of a piece of baling wire where the electricity is supposed to be coming from and scratches the other end of the wire to ground - then observe the sparks. A few weak sparks means low voltage; many bright sparks means high voltage. Iffen the wire tries to weld itself to the last connection - get a bigger wire.
Old 06-08-2022, 09:15 AM   #10
Opie
Opie's Avatar
Drives: 2023 Toyota GR 86 Cup
Car driven through water recently? Hydrolocked engines sound like that...
2023 GR Cup Car
Opie is offline   Reply With Quote
Old 06-08-2022, 11:19 AM   #11
DarkPira7e
DarkPira7e's Avatar
Originally Posted by Opie View Post
Car drivien through water recently? Hydrolocked engines sound like that...
That's actually a good thought..
Old 06-08-2022, 02:40 PM   #12
Old 06-08-2022, 02:43 PM   #13
Those cable ends look like crap!
Old 06-08-2022, 08:49 PM   #14
RZNT4R
Professional Mechanic
Drives: 2017 86 6MT Oceanic
Spark plug don't make an engine crank slowly, they fail to ignite, the cylinders get flooded and washed with gasoline, compression drops, cranking goes faster.
Get voltmeter, place positive lead on the starter B+ terminal, put negative lead on starter body, get your friend to crank it, note voltage. Do the same with the positive and negative leads directly on the battery posts. A good battery should still crank in the high 11V range, it's not, it's dead. the voltage while cranking at the starter shouldn't be more than half a volt below what you measured at the battery posts. If it's significantly lower you've got a voltage drop. Figure out if it's on the positive or ground side. Positive lead on batter post, negative lead on starter B+ terminal, crank, note voltage, should be a small fraction of a volt. Positive lead on the starter body, negative lead on the battery negative post, crank, note voltage, should be a small fraction of a volt.
Changed battery - slow start? lumbeardjack Issues | Warranty | Recalls / TSB 3 09-19-2020 10:45 AM
Car clicks but won't crank. Battery or Starter? JERM^ Issues | Warranty | Recalls / TSB 93 09-14-2019 10:11 AM
Car slow to start? ericmpena Issues | Warranty | Recalls / TSB 10 08-28-2013 02:29 PM
Sales start to slow down? motofan Scion FR-S / Toyota 86 GT86 General Forum 37 04-03-2013 07:39 PM
slow start GREATNEESSS Scion FR-S / Toyota 86 GT86 General Forum 8 12-30-2012 08:49 PM
