Old 05-28-2022, 01:47 PM   #15
2020BRZtS
2020BRZtS's Avatar
Drives: '20 BRZ tS (15/300) / '09 Scion tC
Originally Posted by Ohio Enthusiast View Post
Same here - I have two floor jacks and I leave one under each lifting point once the weight is supported by the stands. I also made a small wooden cube out of scrap 2x12 that I put next to me when I'm working under the car.
A valid point, but keep in mind that when manufacturing in China you typically can specify the level of QC you want (and pay accordingly (and keep a close eye on the manufacturer so that they adhere to your QC level)). The HF recall was blamed on worn cast iron molds, so I can easily imagine the new molds being used for the pricier brands and as they wear out moving down the line to the budget brands.
Still, it did make me wish I bought stands with a locking pin...
You can make a locking pin for piece of mind. I like the wooden block idea too.
2020BRZtS is offline   Reply With Quote
Old 05-28-2022, 10:22 PM   #16
DarkSunrise
DarkSunrise's Avatar
Originally Posted by Capt Spaulding View Post
I'll second the harbor freight jack, but I went with Esco 10498 stands.
https://esco.net/product/3-ton-perfo...ck-stand-pair/
Rock solid is an understatement.
I use this combo as well. Both great IMO.
2022 BRZ Build
2013 FR-S Build
Old 05-29-2022, 02:03 AM   #17
Decep
Drives: 2013 FR-S Series 10
The daytona jacks from harbor freight are actually super nice.
https://www.harborfreight.com/3-ton-...red-57589.html
I got that one, overkill and kind of big to be honest. Knock off of a snap-on jack. But i bet it will last me forever. Has zerk fittings too for lubrication. It unfortunately does not fit my lowered ~1inch FR-S. But stock you'd be fine. As is i need to use ramps first (or 2x6's).
I had sworn off HF jacks since the last jack i bought puked it's hydaulic fluid everywhere on its first use, but i heard good things about these and they come with a standard 3 year warranty rather than the usual shitty 90 days. Aside from this, Costco would be a good option. They usually have a low profile jack you can order, and you can basically return it whenever you want when it pukes.
For jackstands i second everyone's recommendation, the esco's are great. 3 ton per stand, whereas some other jackstands rate their weight capacity in terms of pairs.
2013 FR-S 10 Series ~75k (SOLD)
RCE SS-1 Coilovers
Corsa Catback
Edelbrock Supercharger installed @ 50k
The Following User Says Thank You to Decep For This Useful Post:
Wally86 (06-01-2022)
Old 06-01-2022, 04:49 PM   #18
ajacob
ajacob's Avatar
Drives: 2020 BRZ
Will these fit under stock height BRZ and if I lowered with coilovers in the future too? Watched a few YouTube reviews and said they’ll go under SUVs easily but smaller cars no.
ajacob is offline   Reply With Quote
Old 06-01-2022, 08:17 PM   #19
BRZrkr
Drives: 2017 BRZ PP
I'm not aware of any jack that will fit under any of the 3 front jacking points of a lowered 86 (even a mild drop like RCE Yellows) without driving the car onto blocks/ramps first.
BRZrkr is offline   Reply With Quote
The Following 2 Users Say Thank You to BRZrkr For This Useful Post:
Dzmitry (06-07-2022), Wally86 (06-07-2022)
Old 06-07-2022, 11:51 AM   #20
Dzmitry
Dzmitry's Avatar
Drives: 2018 Subaru BRZ Limited with PP
I would be there is. I'm on RCE Yellows with a pretty large front lip (HT Autos) and I have a small low profile jack from HF that gets pretty close to reaching the front jack point. Seems like the only reason it can't get there is my large front lip getting in the way, but it's very close. A long low profile jack would do the trick likely, but I can't say for sure.
Dzmitry is offline   Reply With Quote
Old 06-07-2022, 01:45 PM   #21
DarkSunrise
I could reach the front jack point on my frs with the low profile 3 ton jack from HF. My frs was lowered 0.8”-1.0” over the years.
2022 BRZ Build
2013 FR-S Build
The Following User Says Thank You to DarkSunrise For This Useful Post:
Old 06-07-2022, 02:15 PM   #22
Wally86
Be Kind
Wally86's Avatar
Drives: 2020 86
I have the tom's style lip and as long as you're okay with bending it quite a bit, the long reach low pro HF jack will do the trick. That said, I'll push the car up ramps if I just need to reach the front.
[Insert clever signature here]
IG | WhiskyBlog | Photography
Wally86 is offline   Reply With Quote
The Following User Says Thank You to Wally86 For This Useful Post:
Old 06-07-2022, 02:24 PM   #23
Dzmitry
Dzmitry's Avatar
Yeah I've still been trying to figure out my next step with that. Thought about buying some ramps. Thought about building some custom ones instead as well. Or just skip all that goodness and jump to buying a QuickJack (which if I remember correctly from your photos, you own one). I don't have a very even pavement currently until I move to a new home. So I've been thinking it through for a while without making any moves. Been sticking to the classic - jack up each side and stick a jack stand under it.
Old 06-07-2022, 05:31 PM   #24
Wally86
Be Kind
Wally86's Avatar
Drives: 2020 86
The quick jack slides right under even with the rubber pinch weld risers. The car could be lowered 2" and still accommodate the quick jack. Maybe a smidge more.
Dzmitry (06-08-2022)
Old 06-08-2022, 01:53 PM   #25
ajacob
ajacob's Avatar
Drives: 2020 BRZ
I’ve also seen the ESCO 3 ton Performance Shorty Style jack stands as well. The minimum/max clearance is 11”/17” compared to the standard ESCO 3 ton jack stands which have a min/max clearance of 13.2”/21.5”. I assume the shorty jack stands would be better for when I plan to lower my suspension to get rid of most of the wheel gap, but I still want comfortable clearance for when I go Stage 2 tune with UEL headers/new exhaust. Would I still be okay with the standard ESCO 3 ton jack stands?
https://www.homedepot.com/p/ESCO-3-T...0499/306368900
Old 06-08-2022, 03:10 PM   #26
Ohio Enthusiast
Drives: 2018 BRZ
I don't see how the suspension height is related to jack stand height. So long as you can lift the car high enough, use a jack stand for that height. For the sake of working under the car I would opt for the highest possible jack and jack stands.
The only impact of lowering the car is on which jacks can reach the lifting points, but that's easily solved with low ramps (one or two inches) that you roll you car onto before using the jack to raise it.
Ohio Enthusiast is online now   Reply With Quote
The Following User Says Thank You to Ohio Enthusiast For This Useful Post:
Wally86 (06-09-2022)
Old 08-04-2022, 08:24 PM   #27
jeepmor
Drives: 84 CJ7, 08 Duramax, 2014 FRS
I have four 12 ton jack stands because I need the height for my jeep. Not even sure I can fit them under this car. I have a pair of old 3 ton jack stands from back in the day I use for the car. I've had my 2500 Diesel front axles on them, they're worthy for this car.
And yes, please do take safety seriously. My cousin was a heavy truck mechanic who in June had some sort of equipment failure and the rig came down and crushed him to death. Not making that up for affect, such a shame, good man.
https://www.legacy.com/us/obituaries...ry?id=36081418
jeepmor is offline   Reply With Quote
The Following 2 Users Say Thank You to jeepmor For This Useful Post:
Jdmjunkie (08-04-2022), soundman98 (08-04-2022)
Old 08-05-2022, 03:27 PM   #28
PenGun
Drives: Red 2019 Subaru BRZ
I use ramps for oil changes. I'm about to do my second, the first took well under 10 minutes.
PenGun is offline   Reply With Quote
Jack Stand Placement Robert97 Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 4 03-08-2022 07:52 PM
Changing oils by myself, are these a recommended jack+jack stand? btan219 BRZ First-Gen (2012+) — General Topics 67 10-23-2021 03:54 PM
Max Jack Stand Size? Hamza Scion FR-S / Toyota 86 GT86 General Forum 16 04-05-2021 09:10 PM
WTB: Low profile floor jack and jack stands! lupindub Want-To-Buy Requests 2 11-26-2015 11:03 PM
Jack stand points xxscaxx Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 3 09-12-2013 09:01 PM
