Old 06-01-2022, 04:31 PM   #15
Ohio Enthusiast
Drives: 2018 BRZ
Originally Posted by Matt93SE View Post
Modern Japanese cars use torque on the nut to put some tension on the threads and keep the nut from loosening. Murican cars (and earlier Japanese) use a castle nut and cotter pin at much lower torque.
The Twins use a castle nut and cotter pin. Would that still benefit from your explanation?
Old 06-02-2022, 08:46 AM   #16
Matt93SE
Drives: 2013 FR-S, 2017 BRZ
Strange. neither my 13 nor 17 had castle nuts. they just had a standard flange nut with a cotter pin.
But yes- any ball joint or tie rod end that uses a tapered pin will work this way. shove the pin farther into the taper and it won't spin as easily. Once the nut is removed, then wail on the side of the knuckle around the pin with a hammer. a few good whacks will deform that taper just enough that the pin comes loose. voila.
Matt93SE is offline   Reply With Quote
The Following User Says Thank You to Matt93SE For This Useful Post:
Ohio Enthusiast (06-02-2022)
Old 06-02-2022, 09:04 AM   #17
Ohio Enthusiast
Drives: 2018 BRZ
Oh, I might have incorrectly interpreted the picture from the repair manual...
Old 06-02-2022, 11:13 AM   #18
series.trackday
series.trackday's Avatar
Drives: '17 Subaru BRZ series.Yellow
Nope, mine is a '17 and it had castle nut + cotter pin on a tapered shaft. Matt's may've been replaced at some point with the incorrect nut?
series.trackday is offline   Reply With Quote
Old 06-02-2022, 11:16 AM   #19
Matt93SE
Very well coulda been. used cars and all that jazz.
Old 06-02-2022, 11:35 AM   #20
series.trackday
That's always the way. I replaced mine with the setup from SPLParts, so now it's just a locknut. I put some paint on it to detect if the nut slips.
Old 06-02-2022, 12:19 PM   #21
Matt93SE
Same here. I alternate white, orange, and yellow paint pens as I do service work so it's easier to tell which mark is the latest.
Old 06-02-2022, 06:32 PM   #22
Grady
Grady's Avatar
"If I ever met the engineer that designed this I'd give them a good choke."
Who the hell comes up with an integral ball joint without a keyed shaft or something?
Nothing wrong with the design, almost all ball joints have been that way forever. Sounds more like a corrosion issue or most likely an improper install issue. I have never had the taper fit break free before the nut. I would have tried to retighten or even overtorque the nut then heat/penetrant to remove.
Cross threading the worlds free loctite.
Front end noise- not bearings or ball-joint... in_sherman Issues | Warranty | Recalls / TSB 6 07-19-2020 01:24 AM
ball joint leak msaikhan Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 5 05-01-2019 11:17 AM
Front lower control arms, buddy club ball joints, RLCA devildriver.ab Brakes, Suspension, Chassis 4 09-13-2018 10:52 PM
Front ball joint dimensions J-W Suspension | Chassis | Brakes -- Sponsored by 949 Racing 0 12-02-2013 05:31 PM
loose ball joint Grip Ronin Issues | Warranty | Recalls / TSB 15 07-09-2013 01:16 PM
