Old 05-30-2022, 08:58 PM   #1
kraftyone
kraftyone's Avatar
Drives: 2020 Subaru BRZ Limited PP
Front hubs with extended wheel studs
Does anyone know of a vendor who sells wheel hubs with extended wheels studs already installed?
Sent from my SM-G986U using Tapatalk
kraftyone is offline   Reply With Quote
Old 06-01-2022, 09:08 AM   #2
Grady
Grady's Avatar
No but why? If you have the hubs in your hand studs are easy to swap out. If you have the tools/ability to change a hub I am sure you can change the studs.
The Following User Says Thank You to Grady For This Useful Post:
soundman98 (06-01-2022)
Old 07-05-2022, 01:34 AM   #3
coolhandluke
coolhandluke's Avatar
These cars do not face stud installation challenges of other cars, such as Honda, that require replacing the wheel bearings when upgrading to extended studs. The GT86 studs are simple in comparison, just press out each OEM stud and press in the upgraded extended stud.
Dave-ROR helped confirm ARP PN#100-7716 work well.
coolhandluke is offline   Reply With Quote
The Following 2 Users Say Thank You to coolhandluke For This Useful Post:
kraftyone (07-05-2022), Wally86 (07-05-2022)
Extended Wheel Studs? ModalSoul37 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 2 09-07-2018 05:55 PM
ARP Extended Wheel Studs FrSnake Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 2 11-17-2014 12:51 PM
WTB: ARP extended wheel studs mikep Canada Classifieds 2 05-22-2014 02:00 PM
non-extended wheel studs BadCompany235 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 4 05-14-2013 09:02 AM
Bolt Pattern, Wheel Hubs and Studs Jeff Lange Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 29 03-08-2012 03:49 AM
