Old 05-25-2022, 02:43 PM   #29
Originally Posted by jrhudson View Post
It might be the TOB still since the car is warmed up and i dont really hear it and/or its not as bad. I suspect it the retainer clips, its probably barely holding onto the TOB. I only drove around for a short time but there wasn’t any whining or weird noises.
Are you sure that it is properly filled with oil? Have to ask.
Old 05-25-2022, 04:03 PM   #30
jrhudson
Drives: 2016 scion frs
The motor and trans were put in together btw (mated/bolted the motor and trans outside of car, this is alot easier IMO than only installing the motor to the trans inside the car) dropped in the motor/trans in under 2 hours) I did drain and fill the transmission . Filled until it was dripping out of the fill opening. Ill post a pic of the clutch fork/TOB/clips whenever i do pull the motor again.
jrhudson is offline   Reply With Quote
The Following User Says Thank You to jrhudson For This Useful Post:
Ultramaroon (05-25-2022)
Old 05-25-2022, 04:18 PM   #31
The motor and trans were put in together btw (mated/bolted the motor and trans outside of car) I did drain and fill the transmission . Filled until it was dripping out of the fill opening. Ill post a pic of the clutch fork/TOB/clips whenever i do pull the motor again.
Sounds good. I'll stay tuned.
Old 06-18-2022, 07:01 PM   #32
jrhudson
Okay so i only dropped the trans. Anyways the clutch fork didnt look bad and TOB was still silently spinning when spun. Clips looked okay, the TOB does hang a little but even after i replaced the clips with brand new ones along with a new TOB, the TOB still hangs a little.
Took a photo of my verus clutch fork as well for comparison. The verus fork seems have a slightly tighter grip on the TOB.
Installed the clutch fork with new clips and new TOB. I would say that rattling/ clicking noise still happens but at a much lower leveler. Also i believe its my ac compressor maybe going out? The rattling is primarily from the compressor.
Ill post videos a little later.
Old 06-19-2022, 01:32 AM   #33
Nothing wrong with those components. What do you think? Do you want to just find a used transmission, or take yours to a shop and crack it open?
edit: Can you feel anything when you turn the input shaft by hand?
Old 06-19-2022, 09:57 PM   #34
jrhudson
i suspect it might just be the clutch disc itself. the clutch i have in it is some junk OEM one with over 70k miles, and when received it, it didnt look so great.
i dont recall feeling anything but i didnt really turn the input shaft by hand much.
i did put my fingers into the clutch disc splines and they had faint rattle noise when i was moving them around. i did the same did to my South bend stage 3 daily clutch and it was solid, no noises.
Well, hopefully ill know if its the trans or just the clutch disc later when i do pull the motor and stick it in another FRS. the other FRS im dropping the motor in has another aftermarket clutch, i was planning on taking out the junk OEM on and putting in that aftermarket one. I probably wont have time to do this for a while tho.
Ultramaroon (06-20-2022)
Old 06-20-2022, 12:42 AM   #35
Ooo... That would be great if it's the disc. Good thought.
Old 06-26-2022, 07:32 PM   #36
jrhudson
Its probably the clutch disc. Pulled the motor swapped out jank oem clutch disc and put in the aftermarket south bend. Dropped it in and got the car button up and no rattles. Even with the ac on. So yea its likely the poop clutch i had.
https://youtube.com/shorts/lOnh8wTGa5c?feature=share
The Following 2 Users Say Thank You to jrhudson For This Useful Post:
FrickingReallySlow (06-27-2022), Ultramaroon (06-26-2022)
Old 06-26-2022, 08:13 PM   #37
Yes! Thanks for sharing your experience. We'll have to remember this for other folks. Would've been tragic to dig into the trans for nothing. I'm super relieved that you checked up on where I was steering. Thank God!
Old 06-27-2022, 01:38 PM   #38
FrickingReallySlow
Drives: 2015 FR-S
Put that on TikTok with the title "How to finger your clutch" -> go viral -> profit
FrickingReallySlow is offline   Reply With Quote
Transmission Noise in Neutral @ Cold Start Jackal84 Issues | Warranty | Recalls / TSB 57 03-01-2021 03:21 PM
FRS Rattle when clutch engaged in neutral savioita Issues | Warranty | Recalls / TSB 20 11-26-2017 04:00 AM
cluck cluck clutch rattle in neutral to engagement??? Packofcrows Issues | Warranty | Recalls / TSB 32 11-14-2015 11:28 PM
Car rattle at neutral. IloveBaldEagles Issues | Warranty | Recalls / TSB 3 12-23-2012 06:55 PM
Weird rattle when put into neutral SleekMachine Issues | Warranty | Recalls / TSB 1 10-18-2012 10:25 AM
