Old 05-22-2022, 08:03 AM   #99
RToyo86
RToyo86's Avatar
Drives: 17 Asphalt 86
The rear spring seats for the BRZ are a separate piece.
- Andrew
Something I observed when I was refreshing things this spring. When I took my rear springs off and removed the dustboot, the bumpstop lifted the metal washer/tab seen at the top of the strut under the threads.
May not seem obvious if wrenching years later but it's vital to keeping the strut happy when the top hat is secured and under load.
You can see the tab missing from the strut
The Following User Says Thank You to RToyo86 For This Useful Post:
norcalpb (05-23-2022)
Old 05-23-2022, 09:01 PM   #100
Espi
Espi's Avatar
Drives: 17 BRZ
Question as I'm considering ordering B8s for my Spec R Swift springs. If down the road I decided to sell my twin... and I wanted to install my stock springs (STI Ts) would they fit? Would the added compression (I would assume) be a bad thing?
Espi is offline   Reply With Quote
Old 05-25-2022, 08:46 AM   #101
RToyo86
RToyo86's Avatar
Go with B6 in that case. The extra droop travel with the B6 vs B8 shouldn't be an issue. Swift springs are designed to work with OEM dampers.
The Following 2 Users Say Thank You to RToyo86 For This Useful Post:
Espi (05-25-2022), norcalpb (05-26-2022)
Old 05-30-2022, 07:32 PM   #102
teppey
teppey's Avatar
Drives: BRZ (in near future)
Any experience with the next gen BRZ and GR86? I remember they still use the same parts.
teppey is offline   Reply With Quote
Old 05-31-2022, 09:45 AM   #103
Originally Posted by Daily86 View Post
Andrew, I'm sure you're busy. Just wondering if you can try to take more pictures.
Thanks!
Didn't forget...just got COVID.
Almost better and will find time next week hopefully.
You will need to use 1st gen springs, possible 1st gen rear mounts (sorry brain is foggy). But they bolt up and would work well.
- Andrew
RToyo86 (05-31-2022)
Old 05-31-2022, 02:10 PM   #104
Decep
Drives: 2013 FR-S Series 10
Feel better Andrew, it hit me like a truck a few weeks ago. For a day i had an awful fever etc, but the back pain has not gone away. Hope you don't have any lingering effects.
2013 FR-S 10 Series ~75k (SOLD)
RCE SS-1 Coilovers
Corsa Catback
Edelbrock Supercharger installed @ 50k
The Following User Says Thank You to Decep For This Useful Post:
Racecomp Engineering (05-31-2022)
Old 07-03-2022, 02:08 PM   #105
norcalpb
norcalpb's Avatar
Replaced my old b6 struts with new ones, here is a picture of those “burn” marks.
I love how well new struts cancel out bumps that weak struts do not lol.
The Following 3 Users Say Thank You to norcalpb For This Useful Post:
Capt Spaulding (07-05-2022), Racecomp Engineering (07-03-2022), RToyo86 (07-03-2022)
Old 08-18-2022, 05:45 PM   #106
NorthernDriver
Drives: Civic Type R
If I'm trying to make a simple FR-S/BRZ to take to the track, would the RCE Yellow + B6 suffice? I'm just trying to get into the sport and learn the ins/outs of HPDE/track days, not set any lap records or be competitive.
Disclosure: I don't have a BRZ/FRS yet.
My plan is to eventually pickup an early FRS/BRZ, refresh the suspension, and leave the powertrain stock. It would only be to drive to track days and have fun. Most reviews seem to say people really enjoy the improvement, and it's how the BRZ should've come from stock.
NorthernDriver is offline   Reply With Quote
Old 08-18-2022, 09:31 PM   #107
ZDan
ZDan's Avatar
Drives: '23 BRZ
Absolutely. Will be a good setup but could be further improved with camber bolts to get a bit more front camber, and possibly Pedders top mounts to get a bit more, or camber plates to get more still. On a budget, IMO Bilstiens and RCE Yellows (or Swift Sport springs if you want to go a bit lower) and crash bolts and Pedders offset top mounts is gonna give a LOT of handling bang/$.
The Following 2 Users Say Thank You to ZDan For This Useful Post:
NorthernDriver (08-18-2022), Racecomp Engineering (08-19-2022)
Old 08-18-2022, 11:54 PM   #108
NorthernDriver
Thanks for the reply. I will take this into consideration. If I recall correctly you owned a 987.2 Cayman as well right?
I originally bought my daily (2020 FK8 Type R) to track it as well....but like it too much to risk any incidents at the track. So, I'm going to fallback to my second option at the time (FR-S/86) to satisfy the track itch...eventually.
Old 08-19-2022, 09:12 AM   #109
Agreed, Bilstein B6 with Yellows is a great easy solution for fun track time. Add the Pedders front top mounts and some camber/crash bolts and enjoy.
For wider tires or extra sticky tires then coilovers do make more sense, but if you want to keep it simple then you'll enjoy the Bilstein combo. Spend the rest of your budget on brake pads and mainetence stuff.
- Andrew
The Following 3 Users Say Thank You to Racecomp Engineering For This Useful Post:
NorthernDriver (08-19-2022), RToyo86 (08-19-2022), tobin (08-20-2022)
Old 08-19-2022, 09:35 AM   #110
NorthernDriver
Old 09-14-2022, 07:06 PM   #111
Spawn_Of_Creation
Human
Drives: 2015 BRZ Black
Got some fun stuff in the works. Wish the RCE Rally X springs went through, but got the next best option.
"Always listen to experts. They'll tell you what can't be done, and why. Then do it." - The Notebooks of Lazarus Long
Spawn_Of_Creation is offline   Reply With Quote
Old 09-15-2022, 03:24 AM   #112
LancePower
Drives: 2020 BRZ tS
People have commented that the B6's will raise a car lowered on springs.
I found even the B8's raised the right height coming from OEM shocks on Eibach Pro Kits.
LancePower is offline   Reply With Quote
Koni Yellow vs. Bilstein B6 vs. Bilstein B8 shattered_memory Suspension | Chassis | Brakes -- Sponsored by 949 Racing 15 01-04-2017 11:22 AM
AVCS Explained Rennmeister Engine, Exhaust, Transmission 3 03-15-2016 03:12 AM
STX Bilstein Double Adjustable Package - Bilstein PSS with Dual Bleed Shafts FRSport.com Suspension | Chassis | Brakes -- Sponsored by 949 Racing 10 02-25-2016 12:50 PM
Ok, who has stories that can't be explained? husker741 Off-Topic Lounge [WARNING: NO POLITICS] 143 11-26-2014 05:25 AM
Part of the problem explained. Suberman CANADA 95 01-28-2014 01:26 PM
