Old 05-25-2022, 01:52 AM   #1
DoubleAKash
Drives: 2019 Subaru BRZ - JDL Turbo Kit
Using Open End Lug Nuts/Center Cap Recommendations for Wedssport TC105X
Hi All,
So I recently just put on my Weddsport TC105X with some open ended lug nuts (yes I should have bought closed ends) from Project Kics R40 (16+4 Locks) - 12x1.25. I was wondering if I should be worried about rust on these living in Northern California or if there is anything I should do before washing my car or after I wash my car to prevent rust from happening.
I'm also running the wheels without a center cap and I know a lot of people say this is fine but wondering if I should buy some center caps and if I should be worried about rust there as well.
DoubleAKash is offline   Reply With Quote
Old 05-25-2022, 05:04 AM   #2
bradsm87
Drives: It has 4 wheels
Get some Weds center caps with integrated hub centering rings.
Type-D 65mm > 56mm - Part Number 52904
bradsm87 is offline   Reply With Quote
The Following User Says Thank You to bradsm87 For This Useful Post:
DoubleAKash (06-07-2022)
Old 05-25-2022, 09:58 AM   #3
YCK
Drives: Toyota 86 GTS 2019
I am running the same setup. For the lug nuts I use anti seize copper grease. If you don't, the rust will stain your wheels. I painted the hub with vht black caliper paint and prefer that look to the hub center caps.
https://www.repco.com.au/en/oils-flu...005/p/A9307309
https://www.vhtpaint.com/high-heat/vht-caliper-paint
YCK is offline   Reply With Quote
The Following User Says Thank You to YCK For This Useful Post:
CrowsFeast (05-26-2022)
Old 05-26-2022, 09:40 AM   #4
CrowsFeast
CrowsFeast's Avatar
Drives: 2013 BRZ Sport-Tech
You may be on to something with the VHT caliper paint. center caps for my wheels are non-existent as far as I know (SAR V.2) and I just never seem to get around to taking measurements to have someone 3D print some.
CrowsFeast is offline   Reply With Quote
Old 05-28-2022, 02:55 AM   #5
G-Man
G-Man's Avatar
Drives: 1980 corvette, 2014 Subaru BRZ
been running tc105n with open mutegi sr48s + long arp studs for the past 7 years, Texas and Colorado. they are fine. I did end up picking up the wed centercaps cause i wasnt happy with the open center look
G-Man is offline   Reply With Quote
The Following User Says Thank You to G-Man For This Useful Post:
Wheel Directory: WedsSport TC105X 17x8.0 +42 timurrrr Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 19 03-21-2021 07:22 PM
CA: Wedssport TC105X 18” 5x100 SOLD gnofx Wheels and Tires 1 09-25-2020 07:58 PM
New Season - New Wheels Enkei TS5, WedsSport TC105X, RAYS G025 eMCee Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 37 05-28-2020 08:41 PM
WedsSport TC105X 17x9 +35 and TRD Springs JeffFAFA Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 22 01-10-2020 09:46 AM
Tire specs for Wedssport tc105x 18x9.5 kyto31 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 4 10-26-2019 12:52 PM
