Old 05-22-2022, 12:50 AM   #1
eyeballs
Drives: '22 BRZ
Preloading the driver seat
Just curious as to what you guys use to get your body weight in the driver seat for proper preload when setting up new suspension parts. I've used kids plus exercise weights, wife plus kid, and trash can filled with water. Neither seemed ideal.
eyeballs is offline   Reply With Quote
Old 05-22-2022, 07:21 AM   #2
DarkPira7e
Rust bucket enthusiast
DarkPira7e's Avatar
Originally Posted by eyeballs View Post
wife plus kid
How does people weight not seem idea? Usually people work together with a friend or a tech who knows what they are doing. The driver of the car sits in the seat while they work on the suspension.
Old 05-22-2022, 07:25 AM   #3
steverife
Drives: 2016 Scion FRS
I don't. It's fine.
steverife is offline   Reply With Quote
The Following User Says Thank You to steverife For This Useful Post:
strat61caster (05-25-2022)
Old 05-22-2022, 08:55 AM   #4
racingfool
racingfool's Avatar
Drives: Miata
Now that's a lot of work.
Similar sized human is my go to.
racingfool is offline   Reply With Quote
The Following User Says Thank You to racingfool For This Useful Post:
timurrrr (05-26-2022)
Old 05-22-2022, 06:58 PM   #5
BarryOtt
I use a couple bags of concrete, each wrapped in a trash bag that's held on with racer tape.
BarryOtt is offline   Reply With Quote
Old 05-23-2022, 07:42 AM   #6
Eric1855
Drives: LP DSP / CSP '13 BRZ
the shop that does my alignments (The Winning Formula) asks my weight then stacks ballast plates, and other weights, in the drivers seat to match when doing alignment and corner balance.
Eric1855 is offline   Reply With Quote
Old 05-23-2022, 11:52 PM   #7
eyeballs
Drives: '22 BRZ
I usually have to bribe or listen to complaining, so not ideal. And the timing rarely works out to have someone available when I'm working on it.
I actually thought about concrete bags, but then thought about the dust. Trash bags solve that, plus I can save the receipt and return then after I "use" them so they aren't taking up garage space.
Old 05-24-2022, 01:00 PM   #8
Matt93SE
Drives: 2013 FR-S, 2017 BRZ
ballast plates, bricks, sand bags, etc.. concrete bags work too, but leave behind lasting residue over sand bags.
the issue with ballast plates, bricks, etc are the sharp edges that poke into seat padding. maybe stack a couple sand bags in the bottom of the seat, then put weight plates or whatnot on top of them to reach your desired weight.
The problem with organic ballast as mentioned above is getting them to sit still for 3 hours while I fidget with everything--- and last time I did a FULL setup, it was from 11pm to about 4am. My wife and kids would absolutely not put up with that so I was scrounging the shop for lead, steel plates, wheels, etc to drop in the seat and floorboard.
Matt93SE is offline   Reply With Quote
Old 05-30-2022, 12:51 AM   #9
eyeballs
Drives: '22 BRZ
Well, I decided to bite the bullet and ended up buying a few 45lb plates from the sporting goods store. They're even formed with handles on the edges for easier carrying and fit nearly perfect in the drivers seat. They were crazy expensive ($80 each). At first I planned on returning them, but they were so easy to work with I may just keep them.
Old 05-30-2022, 09:05 PM   #10
Lynxis
Lynxis's Avatar
Drives: 2013 WRB BRZ 6MT
I'm fortunate that one of my roommates is of a roughly similar body weight to me (within ~10lbs) so I just get them to sit in the drivers seat while I adjust preload. If there was a significant difference and no way to make it up, I'd show them how to set preload, sit in the seat and have them make the adjustment for me. It's not difficult anyways.
Lynxis is offline   Reply With Quote
Driver Seat Base Kestrel Want-To-Buy Requests 0 05-21-2018 09:12 PM
Sparco EVO Seat and Stock BRZ Cloth Driver Seat jonesy Interior Parts (Incl. Lighting) 4 08-25-2017 10:42 AM
Stock Driver seat skavengers412 Interior Parts (Incl. Lighting) 1 03-17-2016 02:14 AM
Driver seat problem Paewrblue Cosmetic Modification (Interior/Exterior/Lighting) 7 10-01-2014 12:25 PM
