Old 04-18-2022, 10:09 AM   #1
Code Monkey
Drives: Subaru BRZ
2022 Subaru BRZ hpde build
Ordered on 10/22/2021, picked up on 4/15/2022.
Premium trim, not a single accessory, just like I wanted.
This may turn out to be a more serious build than the previous one (from which many mods will transfer).
Up-to-date mod list:
Tomei oil pan baffle
MCS coilovers, 650/700 springs
Whiteline KCA416 camber bolts
Megan Racing OEM FLCA with spherical bushings and +15mm RCA
Hardrace RC tie rod ends +15mm
Karcepts FSB
STi flexible v-bar
RacerX rear UCA
MCA Suspension 86 Traction Mod
Removed RSB
APR 61" GTC-300 wing
custom splitter
DocWalt GR86 Cup replica hood vent
Jacks Transmissions transmission @13,625 miles
ACT 6 puck clutch
Verus clutch fork and pivot
STi transmission mount
Cusco motor mounts
AP Racing CP9660 Radi-CAL front BBK
AP Racing CP9451 Radi-CAL rear BBK
Ferodo DS3.12 brake pads
Advan Racing RS III, 18x9 +50
KYO-EI Project Kics Spacers 20mm in front
ARP wheel studs
255/35/18 tires du jour
Outbound Motorsports GR86 Cup intake
JDL EL header, overpipe, ultra quiet front pipe
CSG Spec Touring 86 catback
Gerald Just flex fuel kit
Tuned by Zach@CSG
GSpeed roll bar
OMP HTE-R 400 seats
PCI seat rails
Schroth 6-point harnesses
REAL leather steering wheel
Code Monkey is offline   Reply With Quote
Old 05-03-2022, 08:14 PM   #2
Code Monkey
Drives: Subaru BRZ
Lots of wrenching this month on both BRZs with the goal of taking the red BRZ to Road Atlanta on May 21-22.
Transferring over from the Series.Yellow:
MCS coilovers
RacerX rear UCA
STi flexible v-bar
OS Giken LSD, 4.3 gears
Dropped off the dampers today for service at MCS, should be ready next week. Used 550/550 springs before, will be running 550/650 springs.
Ordered the AP Racing CP9660 Radi-CAL front brake kit with Ferodo DS1.11 pads, should be arriving next week.
Still need to source OEM 18" wheels and pick decent 225/40/18 tires.
Old 05-03-2022, 09:43 PM   #3
Krokodil
Drives: Blue BRZ
Would you please elaborate on wheel choice?
Many people are going for wider 17”.
Krokodil is offline   Reply With Quote
Old 05-03-2022, 09:58 PM   #4
Code Monkey
Drives: Subaru BRZ
Need to accommodate the Radi-CAL BBK. OEM 18" wheels will work for now. I will figure out proper 18x9.5 or so later.
Old 05-05-2022, 11:35 AM   #5
Code Monkey
Drives: Subaru BRZ
Picked up dampers from MCS, two day turnaround!
Service note:
Both front guides needed replacement which is not a abnormal wear item on the BRZ chassis. The strut is relatively short on this chassis and the angle is fairly steep so it tends to wear the guide.
Old 05-05-2022, 01:53 PM   #6
jongers
Drives: 19 86, 22 BRZ
nice choice of mods - looking forward to your build
jongers is offline   Reply With Quote
Old 05-12-2022, 09:09 AM   #7
Code Monkey
Drives: Subaru BRZ
Got 18" wheels from the limited trim. Plenty of clearance for the Radi-CAL calipers.
Old 05-13-2022, 12:24 PM   #8
Code Monkey
Drives: Subaru BRZ
Radi-CAL brakes installed and bled with Castrol SRF, rear diff with OS Giken and 4.3 gears swapped in, and CSG Spec Touring 86 catback installed as well. 715 miles on the car.
Tackling coilovers this weekend with an alignment scheduled Monday.
Old 05-13-2022, 01:49 PM   #9
villainous_frx
Off to the track!
villainous_frx's Avatar
Drives: '14 Lava 86, '13 WRB BRZ
0-100 real quick, loving these updates!
villainous_frx is offline   Reply With Quote
Old 05-13-2022, 02:02 PM   #10
KillerBMotorsport
KillerBMotorsport's Avatar
You got right to it! Looking forward to seeing the progression.
KillerBMotorsport is offline   Reply With Quote
Old 05-13-2022, 06:40 PM   #11
andys_garage
Drives: 2022 GR86 Premium Track bRed
Lots of serious components!!
What made you want to change differentials? Is the OS Giken more suited to the gearing you need for your track of choice or did you just do it for durability?
andys_garage is offline   Reply With Quote
Old 05-16-2022, 07:01 AM   #12
mike2100
mike2100's Avatar
Drives: 23 BRZ
I'm curious as to why you chose the Radi-CAL over the smaller/lighter/cheaper Sprint or Endurance kits from AP Racing. Thanks!
mike2100 is offline   Reply With Quote
Old 05-16-2022, 12:54 PM   #13
Code Monkey
Drives: Subaru BRZ
Did it for performance; many threads on why the OS Giken outperforms the OEM Torsen. I moved the whole diff assembly from my 2017 Series.Yellow so 4.3 gears. Too lazy to open both diffs, swap the Giken into the 4.1, and check backlash.
Buy once, cry once. Just driving around rural GA the stopping performance is mind blowing.
Old 05-16-2022, 01:03 PM   #14
Code Monkey
Drives: Subaru BRZ
Suspension bits installed at 825 miles, alignment at 840 miles. Was hoping for more camber in front and could see -4.1 on the alignment rack, but once everything was tightened, could not get more than -3.5 on the passenger side.
Measured OEM ride height at approximately 6" pinch weld to floor. Dropped both front and rear 1" as scientifically measured by the coffee can (5.04" tall).
Almost ready for Road Atlanta this weekend.
2017 Subaru BRZ hpde build Code Monkey Member's Car Journals 207 04-18-2022 10:11 AM
2022 BRZ JDM Spec build at HKS USA for SEMA2021 143 BRZ Second-Gen (2022+) — General Topics 5 02-14-2022 12:27 PM
redSerpente’s HPDE/86CUP Street build redSerpente Member's Car Journals 10 04-26-2021 06:50 PM
LS3 HPDE / Time Attack Build RavioliG Member's Car Journals 17 02-11-2018 03:56 PM
86_Freak - Build for DD/C Street/HPDE duties 86_Freak Member's Car Journals 3 03-07-2016 09:15 AM
