#29 |
Drives: brz 2017 hksv2
i know that, that s why i have myself a A350
it gives me a good torque when under 5k eith my supercharger but at high rpm peak HP a guy with skunk2 header blows me up I just answered to Teseo who wrote Ace 350 headers give maximum HP, that s not true, they are restrictive at high rpm, they give you Torque under the curve you d need A150 or anaconda or crossfire ace to reach maximum HP |
#30 | |
Drives: 2018 Subaru BRZ
There's someone selling an almost new ACE header. https://www.ft86club.com/forums/show...70#post3521270
#31 |
Drives: 24 GR Yaris, 23 GR86
#32 | |
it is pretty proved that A350 gives more mid scavenging but top-end is affected by the longer runners i have 2 friends other than me, that i tuned and we all have similar boost around 0.9Bar.. same fuel, they have HKS EL and SKUNK2 4-1 EL, i have the ace A350 They easily get 20+ HP as peak power more than me, but i get much more low and mid torque.. the skunk2 one still has an evident torque dip but reaches the highest ignition timing at high rpm with the same AFR So yes, both real life performance and dyno figures, short EL give more peak power than ace a350 same happens for NA stock engine , it s not like a new discover |
| The Following 7 Users Say Thank You to tomm.brz For This Useful Post: | Breezio (05-06-2022), DocWalt (08-18-2022), Lantanafrs2 (05-06-2022), PulsarBeeerz (05-15-2022), RedReplicant (05-06-2022), Spawn_Of_Creation (05-06-2022), Teseo (05-06-2022) |
#33 |
I can’t speak for FI application but I do have slightly different real life experience with tracking my NA ACE equipped car against another BRZ with HKS EL (both cars tuned by the same tuner, custom maf corrected CAI in the other car, similiar peak hp numbers iirc, more weight in my car - passenger).
| The Following User Says Thank You to MrSkubi For This Useful Post: | tomm.brz (05-06-2022) |
#34 |
Drives: C5, GT-86, '24 Colorado TrailBoss
Any issues with a weld cracking most likely using old motor mounts shifting around. My mounts were new and I still switched over to more solid Perrin mounts
#35 | |
Human
Drives: 2015 BRZ Black
Not to mention that the only difference between the 350, 250, and 150 are the overripe, and they are designed with the idea to be swappable for their designed use case at a cheaper install cost and labor time than a whole header.
"Always listen to experts. They'll tell you what can't be done, and why. Then do it." - The Notebooks of Lazarus Long
| The Following User Says Thank You to Spawn_Of_Creation For This Useful Post: | RedReplicant (05-06-2022) |
#36 | |
Drives: Q5 + BRZ + M796
Based on the welds I saw, my guess is they are using the same type of cheap, low-skill, cold welding technique demonstrated in the videos below. It can be done by machine or low-skill laborer. It leaves prettier welds with uniform size and shape with minimal heat/staining into the metal, so sanding/finishing may not be necessary. The process results in poorer penetration, which is why cracks happen along the fisheyes. It results in less fill of the joint too and more of a concave joint, especially when filler rod isn’t used, and while some concavity is typical of thick joints, it isn’t ideal on 16g, thin-walled pipe. I could be wrong, but I have my suspicions. I would love to be proven wrong. Example: Explanation: Ace inside and out compared to a custom turbo manifold I had made. Maybe the guys at Ace are like a cold welding machine in their technique. It is possible.
| The Following 3 Users Say Thank You to Irace86.2.0 For This Useful Post: |
#37 |
Drives: 87 Supra, 13 FRS, 05 FXT
I purchased my ACE 350 headers back in 2017. I have had them on my car since then and when I went to the track the welds on the flanges failed, causing one of the runners to pop out from the flange on my second to last run. I contacted CSG and we were able to get the manifold replaced under warranty with a new and improved version. The new version had thicker flanges and better welds! I still have it on my car now, and I think it is time for an updated tune to take advantage of the crack free manifold.
| The Following User Says Thank You to thatfilipinoguy For This Useful Post: | Irace86.2.0 (05-14-2022) |
#38 | |
Drives: '14
Anecdotally I agree with this. Mine cracked, and the only other person I knew with Ace also had multiple cracks + repairs. Headers shouldn't be a yearly maintenance item
Always learning.
| The Following 4 Users Say Thank You to itschris For This Useful Post: |
#39 | |
Drives: AP2 S2000, 91 Miata 1.8L Rotrex 5MT
A. They provide similar if better performance B. The quality is absolutely top notch and they do not have common cracking issues C. They are LOL cheaper - IDK why ACE thinks they can charge so much for an inferior product
2022 Hyundai Elantra N 6MT SCCA TT S3//Will be back in an 86 eventually
#40 | |
Drives: 2017 BRZ
And though I haven't run a JDL header, I've had issues with everything else I've purchased from them (header-back for my '14 had cracking and other failures, front-pipe on my '17 wouldn't even bolt up to the stock header/overpipe - maybe it'd have bolted up to a JDL header? not sure; but despite numerous attempts to reach them I never heard a peep and ended up having it modified locally). Failure rates may still be lower than Ace (no idea, my Ace so far seems to be holding up just fine, but it doesn't get a lot of miles so who knows... then again, neither did the header-back) based on volume, but I'm not sure I'd buy from them again. As always, YMMV. Price is what it is. This car attracts a very cheap crowd, I'm surprised JDL is even able to sell enough.
#41 |
Drives: 15 BRZ, 2003 MR2, '70 Elky, 06 TBSS
My ACE A350 header has twice melted my passenger side sway bar bushing.
| The Following User Says Thank You to B T For This Useful Post: | Goingnowherefast (05-17-2022) |
#42 | |
Drives: None
The non ceramic coated one melted the right side steering rack bellow and yellowed the paint everywhere around the overpipe. Neither have ended up cracked, Cusco mounts on one car and Perrin on the other. Both have been tracked, the one that melted the bellow was uncoated and had a supercharger on it. Just some data.
| The Following 4 Users Say Thank You to RedReplicant For This Useful Post: |
| Tags |
| ace, ace 350, aceheader |
| STI Lip Kit Discontinued? | ADabOfOppo | BRZ First-Gen (2012+) — General Topics | 12 | 10-15-2015 11:08 AM |
| Top Speed Auto UEL Header Discontinued | raven1231 | Engine, Exhaust, Transmission | 11 | 09-28-2014 12:42 PM |
| FR-S / BRZ Discontinued? | Thatruth2001 | Northwest | 16 | 06-27-2014 03:30 AM |
| BRZ MIGHT BE DISCONTINUED AFTER ONE GEN?? | airjonny | BRZ First-Gen (2012+) — General Topics | 37 | 06-24-2014 01:47 PM |
| openflash header replica? | toby714 | Engine, Exhaust, Transmission | 30 | 06-05-2014 02:11 AM |
