Old 09-08-2017, 02:24 AM   #29
Turdinator
Señor Member
Turdinator's Avatar
Originally Posted by DandoX View Post
I know I'm posting in an old thread but this isn't worth a new thread.
I'm replacing my clutch kit and I wanted to know if anyone's knows the weight of the stock flywheel on 2012-2013 model FRS/BRZ?
I know they released a lighter one and they don't sell the older more heavy flywheel my car came with. I'm looking for the same weight and quality flywheel as I have I don't want anything more light, that being said is this a good one to go with, anyone with experiences https://www.86speed.com/products/exe...-flywheel.html
From memory the stock flywheel is around 22 - 26lbs. I can go weigh one if you need a more accurate weight. If you need a replacement and you want the same weight why not just get a stock unit? Otherwise an Exedy one will be as good quality as OEM.
1974 TA22 Celica
2013 86 GT
The Following User Says Thank You to Turdinator For This Useful Post:
DandoX (09-08-2017)
Old 09-08-2017, 11:08 AM   #30
DandoX
Senior gif poster
DandoX's Avatar
Drives: 2013 Asphalt FRS
Thanks, I would get a stock flywheel but I can't seem to find one for a good price the Exedy one seems like a good price and if you say I can expect good quality I may get that one. The Exedy is 20lbs so slightly lighter but I will probably just deal with it for the better price.
DandoX is offline   Reply With Quote
Old 09-08-2017, 11:58 AM   #31
Cockatoo
TALLY FT86
Cockatoo's Avatar
Drives: 2014 FR-S Monogram -- SBD Turbo --
This is the OEM clutch...
Cockatoo is offline   Reply With Quote
The Following User Says Thank You to Cockatoo For This Useful Post:
why? (09-10-2017)
Old 05-10-2022, 08:56 PM   #32
Wingnutt
Drives: Pearl White 2014
To chime in..
I have the ACT street lite combo and I HATE IT. The car has tons of driveline noise below 3000rpm.. and by lots I mean it sounds like clattering garbage. It's also a lot more touchy off the line and harder to get a good launch, this is after 6 months with it. Can't wait to ditch it and go with OEM. Flywheel and a stage 1 clutch (lots of mods, E85)
Wingnutt is offline   Reply With Quote
The Following User Says Thank You to Wingnutt For This Useful Post:
Tcoat (05-11-2022)
Old 05-11-2022, 12:57 AM   #33
gpvecchi
gpvecchi's Avatar
I have the TRD flywheel, it's wonderful. No noise or vibrations, just a little chatter in neutral when oil is cold.
Old 05-11-2022, 09:42 AM   #34
RToyo86
RToyo86's Avatar
Drives: 17 Asphalt 86
What is the weight on the TRD?
The heaviest LW flywheel I could find was around 12.5 pounds.
RToyo86 is online now   Reply With Quote
Old 05-11-2022, 04:31 PM   #35
gpvecchi
gpvecchi's Avatar
It's 6 kg, while the stock is 10 kg.
Old 05-11-2022, 08:45 PM   #36
x808drifter
LMGTFY
x808drifter's Avatar
Drives: 13 FRS, 91 Miata
It's 13.2lb, while the stock is 22lb.
Your welcome.
Old 05-17-2022, 09:59 PM   #37
FRS2017
Enthusiast 86
FRS2017's Avatar
I have a lightweight flywheel and sports clutch. I would never go with lightweight again as I constantly fight for control at the traffic lights.
Next time I will go with a more expensive clutch and flywheel.
FRS2017 is offline   Reply With Quote
Old 05-18-2022, 07:12 PM   #38
clio
Drives: 2013 Subaru BRZ
It's difficult to compare flywheels I guess. In theory a 6Kg flywheel could have a greater rotational mass than a 10kg one. It all depends on the distribution of that mass from center - doesn't it?
clio is offline   Reply With Quote
Old 05-19-2022, 12:54 AM   #39
gpvecchi
gpvecchi's Avatar
Lightened flywheels are lightened near the edges, so less rotational mass for sure.
Old 05-19-2022, 01:00 AM   #40
DarkPira7e
Rust bucket enthusiast
DarkPira7e's Avatar
I love my fidanza lightweight flywheel. With a Southbend stage 3 daily, it's not difficult to manage in stop and go traffic. Way more responsive than stock. Registers a lot of fake misfires though (no impact on performance)
Old 05-19-2022, 01:34 AM   #41
nikitopo
nikitopo's Avatar
Drives: '15 BRZ RA
I had a TODA RACING lightweight flywheel and clutch. The car was more difficult to ride in city and there wasn't any difference in performance. I went back to the OEM flywheel and clutch and the car is drivable again.
The Following 2 Users Say Thank You to nikitopo For This Useful Post:
Tcoat (05-19-2022), tomm.brz (05-19-2022)
Old 05-19-2022, 11:08 AM   #42
DarkSunrise
DarkSunrise's Avatar
I have the Exedy stage 1 lightweight flywheel and clutch combo and love it. Pros are the engine free revs much quicker for easier rev matching. In fast up shifts, the clutch grabs immediately which feels great, especially combined with stiffer trans and rear diff bushings. Overall the car feels more responsive. Downsides are pretty minimal IMO. Slight increase in chatter at a stop. Stiffer clutch feel. If you tend to stall the engine, this will only make it worse due to the grabbier clutch and lack of weight in the flywheel. The rhythm/timing of shifts speeds up, so if you prefer lazy/slow shifting, this isn’t for you. That’s about it I can think of.
I’ll definitely miss this mod on my gen 2.
2022 BRZ Build
2013 FR-S Build
Flywheel Rattle? CB762 Issues | Warranty | Recalls / TSB 119 11-16-2016 10:09 PM
Anyone replace rotors yet? NickFRS Suspension | Chassis | Brakes -- Sponsored by 949 Racing 7 01-16-2013 02:38 PM
Looking to replace my sedan carbonBLUE Other Vehicles & General Automotive Discussions 5 01-11-2013 08:41 PM
Which ones do you like to replace the stock rikdrt1 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 11 11-11-2012 09:53 PM
SPEC Flywheel wootwoot Engine, Exhaust, Transmission 15 11-09-2012 09:08 AM
