Old 05-10-2022, 03:12 PM   #1
Krazyyykevin
Krazyyykevin's Avatar
Drives: 2020 BRZ
Revert FRS from push to start to regular key ignition
I bought a shell but the previous owner had installed a push to start(easy guard), I’d like to remove it and put it back to a key ignition would I just have to buy a steering column ignition assembly or do I have to buy all new ECUs and a whole new dash harness, I’m just trying to fix this because the shell was given to me with no keys
Thanks for reading and I appreciate any info!
Krazyyykevin is offline   Reply With Quote
Old 05-10-2022, 03:21 PM   #2
Ashikabi
Ashikabi's Avatar
There might be a key hidden in the steering column to defeat the immobilizer. I had a push start installed on mine for a while and it was not hard to revert. Essentially just unplugged it and respliced a wire in the ignition switch loom that was split. If you can't find a key that works, maybe a locksmith can help you make a new one
Sent from my ONEPLUS A5010 using Tapatalk
Old 05-10-2022, 03:30 PM   #3
Krazyyykevin
Drives: 2020 BRZ
It’s missing the part that you actually stick the key into on the column, like the cylinder lock that the key goes in. and I took apart the entire dash looking for the key and have not been able to find it
Old 05-10-2022, 04:26 PM   #4
soundman98
ProCrastinationConsultant
soundman98's Avatar
what does the vin decode as? limited or premium?
Old 05-10-2022, 04:48 PM   #5
Ashikabi
Ashikabi's Avatar
Oh.... Yeah it should have been right there. Sounds like they deleted that shit entirely... You've got quite a mess it seems
Old 05-10-2022, 05:10 PM   #6
Krazyyykevin
Drives: 2020 BRZ
Yea it’s a hassle I’m trying to figure out what I can replace to get it to work
Old 05-10-2022, 07:10 PM   #7
Grady
Grady's Avatar
Drives: BRZ Yellow, Ranger, Evora, WCM S2K
Find out what model it is and buy the kit. replace the brain and get new keys. That looks like a cheep Amazon version that can be had for under $100
Old 05-10-2022, 08:47 PM   #8
Krazyyykevin
Drives: 2020 BRZ
I actually tried this already and it didn’t work unfortunately
Old 05-11-2022, 08:16 AM   #9
Grady
Grady's Avatar
If that is the case then chances are there is another issue besides that. Get the wire diagram for your car a VOM and start checking.
Stall/No Re-start with push button start couver Scion FR-S / Toyota 86 GT86 General Forum 11 06-26-2020 10:32 PM
Help! STI push start button / Ignition switch Busybee Cosmetic Modification (Interior/Exterior/Lighting) 11 06-05-2020 01:55 AM
FS: STI engine start push start OEM plug and play sokol Interior Parts (Incl. Lighting) 5 06-13-2019 02:12 PM
Battery dies, push start car in gear.... push start button rhythmM Scion FR-S / Toyota 86 GT86 General Forum 7 02-27-2014 06:06 PM
Push Start Rough Engine Start Up joergasm Engine, Exhaust, Transmission 3 12-12-2012 03:44 AM
