#4537 |
Drives: 2013 FR-S, Edelbrock Supercharger
Edelbrock Supercharger Bypass Valve
Hi I've got an Edelbrock E-Force Supercharger on my FR-S, and my Bypass Actuator Valve recently went out. I bought a new one from Edelbrock that will come in tomorrow and I was curious if anyone in the group has replaced it before? And if so I've got a few Questions:
1. How hard is it to replace? 2. Do I need to remove the supercharger or is it possible to replace the valve with it still on? 3. Are there any tips or anything I should be on the lookout for when I replace it |
#4538 | |
Drives: 2013 FRS
Enkei TS9 18 X 8, Michelin Sport 4S 225 40 18, Flex Fuel, Edelbrock Supercharger, P & L header, Nameless front pipe, V1 cat back, Aluminum Driveshaft, pvc delete, med duck bill, KW V3, Whiteline 20 and 18 mm bars, Buddy Club and SPL control arms, Toe Arms, motor and trans mounts, Whiteline bushings, SHR stage II tune.
| The Following User Says Thank You to shr133 For This Useful Post: | B T (04-28-2022) |
#4539 | |
Drives: '14 Ultramarine Fr-S
2. It IS possible to change it with the Edelbrock still on, at least somewhere here on this forum there was a confirmation that it was possible. never personally tried to do it this way. 3. Follow the supplied instructions. Always use a battle buddy, and drink water. |
| The Following User Says Thank You to Pgh_Area For This Useful Post: | CallmeDave (04-26-2022) |
#4540 | |||
Drives: 13 BRZ, 07 WRX
There are photos in that link, not sure why I cant just quote it with the photos
13 BRZ Premium. 07 WRX.
#4541 | |
#4542 | |
Drives: 14 BSP Edelbrock BRZ
The brake booster line is always under vacuum. At full throttle that vacuum level goes down, which lets you use that same line for the bypass actuator. If you tie in the Manifold Absolute Pressure sensor into that line it will only see vacuum, not the absolute pressure in your manifold. Engine go boom as it goes super lean under boost. Connect the MAP sensor to the nipple on the back of the supercharger (after the scrolls where boost is present) that used to connect to the actuator. |
| The Following User Says Thank You to toast For This Useful Post: | B T (05-01-2022) |
#4543 | |
Drives: 2013 BRZ Limited 6MT
#4544 |
Drives: 2018 BRZ tS
@B_T do you have any extra MAP relocation kits left? Taking a new job and might have the spare cash for one now.
#4545 |
Drives: 15 BRZ, 2003 MR2, '70 Elky, 06 TBSS
Sorry, Think someone is in the process of buying the last one right now. If I don't hear from them by the end of the day, I'll let you know. The only one left is the slightly marred surface finish from the vice I had it in.
| The Following User Says Thank You to B T For This Useful Post: | Side (05-05-2022) |
#4546 |
Drives: 2021 Supra / 2022 Tundra
I'm about to install my Ptuning flex fuel kit this week. I already got my tune from CSG and at low gas ready for E85 post install. Any install advice from someone that's done it with an Edelbrock SC? Looks pretty straightforward and nothing obvious would need to be different with the SC but there is so much good info here I figured I'd ask since I didn't find anything in my searches.
TomR
#4547 |
Drives: 2017 BRZ Series. Yellow
Be careful routing the new fuel lines if they are the stock style hard plastic lines. They can crimp if you bend them too far.
#4548 |
It went pretty smoothly. Just mounting the "brain" on the bracket above the brake pedal was a pain. Nothing about the install including the injectors is any different because of the supercharger.
TomR
| The Following User Says Thank You to ABQautoxer For This Useful Post: | CSG Mike (05-10-2022) |
#4549 |
Wrapped up tuning with CSG Zach. If you are somewhere with 91 but have easy access to pump E85, 100% upgrade to flex fuel. Big change and at my altitude (5600') allowed me to go to the 3" pulley. Already burned through a tank of E85 finding excuses to drive it.
TomR
#4550 | |
Drives: 2015 FR-S
| Vortech Owner Thread & Setup Questions | reyruiz191 | Forced Induction | 340 | 05-17-2022 01:44 PM |
| Edelbrock E-Force Supercharger | itsibarra | Forced Induction | 938 | 07-31-2021 05:48 PM |
| Most annoyingly over-asked questions on FT86 forums | mit_peid | Off-Topic Lounge [WARNING: NO POLITICS] | 36 | 01-16-2014 03:48 PM |
| Brz Info/Specs (helpful info for questions asked often) | Gaen | BRZ First-Gen (2012+) — General Topics | 0 | 05-24-2012 11:09 PM |
