Old 04-20-2022, 02:07 PM   #4537
SuperFR-S
SuperFR-S's Avatar
Drives: 2013 FR-S, Edelbrock Supercharger
Edelbrock Supercharger Bypass Valve
Hi I've got an Edelbrock E-Force Supercharger on my FR-S, and my Bypass Actuator Valve recently went out. I bought a new one from Edelbrock that will come in tomorrow and I was curious if anyone in the group has replaced it before? And if so I've got a few Questions:
1. How hard is it to replace?
2. Do I need to remove the supercharger or is it possible to replace the valve with it still on?
3. Are there any tips or anything I should be on the lookout for when I replace it
SuperFR-S is offline   Reply With Quote
Old 04-25-2022, 11:58 PM   #4538
shr133
shr133's Avatar
Drives: 2013 FRS
Originally Posted by shr133 View Post
Hey guys, so does anyone know what I need to change to calibrate a grams throttle body. I had to get my radiator warrantied and while I had it apart decided to upgrade the TB. it ran great last night and today until it didn't. It's throwing codes p0122 and p0222... and won't relearn the TB and keeps going into limp mode.
I think I should replace my pedal sensor to make sure because it was running perfectly and all of a sudden when into limp mode... Any help would be great... It fits perfectly just need a 3.25" to 3.5" adapter
https://www.amazon.com/dp/B091521446...t_details&th=1
IT WAS MY ACCELERATOR PEDAL SENSOR, don't know if it just went bad or was worn out, but that was the problem. running great with grams on the Edelbrock..... Now the supercharger is only 65mm so it needs some port matching, doesn't even match the stock throttle body.... Now we will find out if its faster...
Enkei TS9 18 X 8, Michelin Sport 4S 225 40 18, Flex Fuel, Edelbrock Supercharger, P & L header, Nameless front pipe, V1 cat back, Aluminum Driveshaft, pvc delete, med duck bill, KW V3, Whiteline 20 and 18 mm bars, Buddy Club and SPL control arms, Toe Arms, motor and trans mounts, Whiteline bushings, SHR stage II tune.
shr133 is offline   Reply With Quote
Old 04-26-2022, 08:15 AM   #4539
Pgh_Area
Pgh_Area's Avatar
Drives: '14 Ultramarine Fr-S
1. With the Edelbrock off its easy.
2. It IS possible to change it with the Edelbrock still on, at least somewhere here on this forum there was a confirmation that it was possible. never personally tried to do it this way.
3. Follow the supplied instructions. Always use a battle buddy, and drink water.
Pgh_Area is offline   Reply With Quote
Old 04-26-2022, 08:43 AM   #4540
CallmeDave
CallmeDave's Avatar
Drives: 13 BRZ, 07 WRX
Originally Posted by CallmeDave View Post
We got the new bypass valve installed. We found it easier to remove the AC condenser to gain access to install the bypass with the bracket installed.
Also note the size the difference in the old and new bypass.
This might help.
https://www.ft86club.com/forums/show...postcount=4203
There are photos in that link, not sure why I cant just quote it with the photos
13 BRZ Premium. 07 WRX.
CallmeDave is offline   Reply With Quote
Old 04-28-2022, 11:00 AM   #4541
SuperFR-S
SuperFR-S's Avatar
Thx! I took it off a few days ago and it was not bad at all! Got everything back on and car is running a lot better!
Old 04-29-2022, 10:03 PM   #4542
toast
Drives: 14 BSP Edelbrock BRZ
Originally Posted by Chris3007 View Post
BTs kit has everything for the MAP relo to the bypass vlve vacuum line. To tee into the brake booster line you will need an extra tee, 3/8x1/4x3/8. I believe it should look like my napkin sketch, I am in the process of doing this now.
Um, huge no.
The brake booster line is always under vacuum. At full throttle that vacuum level goes down, which lets you use that same line for the bypass actuator. If you tie in the Manifold Absolute Pressure sensor into that line it will only see vacuum, not the absolute pressure in your manifold. Engine go boom as it goes super lean under boost.
Connect the MAP sensor to the nipple on the back of the supercharger (after the scrolls where boost is present) that used to connect to the actuator.
toast is offline   Reply With Quote
Old 04-30-2022, 08:09 PM   #4543
Chris3007
Drives: 2013 BRZ Limited 6MT
Originally Posted by toast View Post
Um, huge no.
Okay awesome, huge thanks on the clarification. I deleted my post too not cause any confusion. Thanks again!
Chris3007 is offline   Reply With Quote
Old 05-02-2022, 11:54 PM   #4544
Side
Side's Avatar
Drives: 2018 BRZ tS
@B_T do you have any extra MAP relocation kits left? Taking a new job and might have the spare cash for one now.
Side is offline   Reply With Quote
Old 05-03-2022, 10:03 AM   #4545
B T
Drives: 15 BRZ, 2003 MR2, '70 Elky, 06 TBSS
Sorry, Think someone is in the process of buying the last one right now. If I don't hear from them by the end of the day, I'll let you know. The only one left is the slightly marred surface finish from the vice I had it in.
B T is offline   Reply With Quote
Old 05-04-2022, 04:39 PM   #4546
ABQautoxer
ABQautoxer's Avatar
Drives: 2021 Supra / 2022 Tundra
I'm about to install my Ptuning flex fuel kit this week. I already got my tune from CSG and at low gas ready for E85 post install. Any install advice from someone that's done it with an Edelbrock SC? Looks pretty straightforward and nothing obvious would need to be different with the SC but there is so much good info here I figured I'd ask since I didn't find anything in my searches.
TomR
ABQautoxer is offline   Reply With Quote
Old 05-05-2022, 10:44 PM   #4547
aKaGorganZola
aKaGorganZola's Avatar
Drives: 2017 BRZ Series. Yellow
Be careful routing the new fuel lines if they are the stock style hard plastic lines. They can crimp if you bend them too far.
aKaGorganZola is offline   Reply With Quote
Old 05-06-2022, 01:21 AM   #4548
ABQautoxer
ABQautoxer's Avatar
It went pretty smoothly. Just mounting the "brain" on the bracket above the brake pedal was a pain. Nothing about the install including the injectors is any different because of the supercharger.
TomR
Old 05-11-2022, 11:02 PM   #4549
ABQautoxer
ABQautoxer's Avatar
Wrapped up tuning with CSG Zach. If you are somewhere with 91 but have easy access to pump E85, 100% upgrade to flex fuel. Big change and at my altitude (5600') allowed me to go to the 3" pulley. Already burned through a tank of E85 finding excuses to drive it.
TomR
Old 05-12-2022, 11:59 AM   #4550
FrickingReallySlow
Drives: 2015 FR-S
Are you on stock block and trans? any reliability mods? curious what he thought you were getting for HP/TQ
FrickingReallySlow is offline   Reply With Quote
Edelbrock E-Force Supercharger itsibarra Forced Induction 938 07-31-2021 04:48 PM
Most annoyingly over-asked questions on FT86 forums mit_peid Off-Topic Lounge [WARNING: NO POLITICS] 36 01-16-2014 02:48 PM
