Drives: 2013 Scion Frs
Power steering failure
My power steering quit working and is showing a current code of C1528 which is motor rotation angle sensor. This issue was mostly intermittent but has recently been happening a lot. I tried unplugging the harnesses going to the power steering ECU with no luck, and looking at live data, the rotation angle is all over the place and is showing little to no amps to the motor. The vehicle had an alignment issue with the power steering working when I bought it but then stopped. I replaced the struts, control arms, and steering rack to fix the alignment issue thinking that the power steering issue was related but it was not. Has anybody experienced this issue or has any insight as to what to do? Thanks!
#2 |
I've never had it quit working but I did have the angle wrong when reattaching the rack and it lit up my dash. I knew right away what the issue was cuz my steering wheel was pretty crooked. Reattached the rack and lights went away. Not sure if that anecdote will be useful to you or not
Sent from my ONEPLUS A5010 using Tapatalk |
#3 | |
#4 |
This is a purely electrical issue. I've never seen this one in particular but it boils down to one of three things.
POWER ASSIST SYSTEMS: POWER STEERING SYSTEM: C1528; Motor Rotation Angle Sensor Malfunction; 2013 MY FR-S [03/2012 - ]
| The Following User Says Thank You to Ultramaroon For This Useful Post: | bcj (05-03-2022) |
| 2013 Subaru BRZ -- Another Power Steering Failure & Troubleshooting Help | BrettRS | Issues | Warranty | Recalls / TSB | 43 | 10-08-2025 12:19 PM |
| Electric power steering and steering column part info | raspec | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 0 | 10-12-2021 05:27 PM |
| Power steering failure and code issues | RyanOlsen05 | Scion FR-S / Toyota 86 GT86 General Forum | 1 | 09-18-2021 12:46 AM |
| Power Steering | rosol16 | Issues | Warranty | Recalls / TSB | 15 | 12-15-2015 09:44 AM |
| Electronic Power Steering Failure | tjdiz92 | Issues | Warranty | Recalls / TSB | 17 | 06-18-2014 01:34 AM |
