Go Back   Toyota GR86, 86, FR-S and Subaru BRZ Forum & Owners Community - FT86CLUB > 2nd Gens: GR86 and BRZ > BRZ Second-Gen (2022+) — General Topics
BRZ Second-Gen (2022+) — General Topics General topics for the second-gen BRZ
Old 05-02-2022, 03:55 PM   #407
NikolaiCherepanov
Drives: 1997 BMW Z3 2.8, 2022 BRZ Premium
Originally Posted by staples323 View Post
17x9 +45 with a 10mm spacer on the front. 255/40/17 Maxxis RC-1
How much camber? Been trying to build some wheels and have held off for the past 6 months to figure out fitment I want to go 18X9 ET35 up front and ET38-40 in rear. I like the way your fitment looks just hardly anyone posts how much camber they are running.
NikolaiCherepanov is offline   Reply With Quote
The Following User Says Thank You to NikolaiCherepanov For This Useful Post:
timurrrr (05-02-2022)
Old 05-02-2022, 04:18 PM   #408
staples323
staples323's Avatar
Drives: '22 GR86
-3° in the front, a hair under -2° in the back.
2022 Toyota GR86 Halo NASA TT5
2015 Subaru BRZ Crystal White Pearl NASA TT5 SOLD
staples323 is offline   Reply With Quote
Old 05-02-2022, 05:23 PM   #409
NikolaiCherepanov
Thanks so much!
Old 05-04-2022, 11:05 AM   #410
ravenwrx
Drives: 2018 brz
Are you on the stock RLCA?
ravenwrx is offline   Reply With Quote
Old 05-04-2022, 08:29 PM   #411
staples323
staples323's Avatar
Drives: '22 GR86
Yes. Little less than 1 inch drop. About the same effect as on my last gen.
Old 05-05-2022, 10:23 AM   #412
OkieSnuffBox
Drives: '23 BRZ Limited
Just do ET40 and space the front 5mm. Then you can still rotate the wheels for tire wear.
"95% of the time, more throttle is the answer. 5% of the time, it ends the suspense."
The Following User Says Thank You to OkieSnuffBox For This Useful Post:
timurrrr (05-05-2022)
Old 05-05-2022, 11:04 PM   #413
bradsm87
Drives: It has 4 wheels
Originally Posted by mlarz41 View Post
Adding my car to share fitment
BC Racing BR Coils, have a finger gap all around (1.5ish in drop i think)
Gram Lights 57dr 17x9 +38 on 245/40/17 indy500s
-1.5 degrees of camber all 4 corners, no rubbing anywhere that i can find or hear. rear is pretty flush, front could take maybe a 3-5mm spacer to get completely flush with fender.
This kinda conflicts with all other info out there. The consensus is 9" +38 with 245s would definitely rub at the rear, especially with only -1.5 camber. I can see it's not very low which would help clearance. Have you pushed it hard yet?
It looks great by the way!
bradsm87 is offline   Reply With Quote
Old 05-06-2022, 09:00 AM   #414
mlarz41
Drives: 2022 Subaru BRZ
Thanks, I've driven it decently hard. I did finally hear what sounded like some rubbing hitting a pretty large bump I didn't see to avoid yesterday. But haven't gone to a canyon since install to really test, planning to do that this weekend. I'm just not seeing any evidence yet of wear on tires or fenders to suggest there is consistent rubbing. I have driven about 700 miles so far with the new wheels and tires.
mlarz41 is offline   Reply With Quote
The Following User Says Thank You to mlarz41 For This Useful Post:
bradsm87 (05-06-2022)
Old 05-06-2022, 06:38 PM   #415
bradsm87
Thanks. Your setup gives me hope, especially considering that I plan to trim the plastic bit and the sheetmetal behind it.
I plan to lower it about an inch, -2.2 front and -1.5 rear camber. I think I'll go 17x9 ET43 or ET42 with 245/40 all round and 6-7mm spacers up front.
Old 05-14-2022, 03:50 PM   #416
staples323
staples323's Avatar
Drives: '22 GR86
Was at the track yesterday. With my camber settings and ride height, -3F -2R 1 inch drop, there was no rub. No fender modifications.
The Following 2 Users Say Thank You to staples323 For This Useful Post:
Pat (07-19-2022), PrayForRain (05-15-2022)
Old 05-14-2022, 07:42 PM   #417
Petah78
Drives: 2022 BRZ sport-tech
Thanks. Do you think you will rub if rear camber was less than -2?
Thanks.
Daijiro Katoh - Champion Forever!
Past: 92 EG w/JDM B18C, 00 EK w/JDM B18C, 04 600RR, 97 ITR #421, 10 Acura CSX-S, 17 BRZ
Current: 22 BRZ, 00 S2K - #0220
Petah78 is offline   Reply With Quote
Old 05-15-2022, 05:29 AM   #418
staples323
staples323's Avatar
Drives: '22 GR86
Thanks.
Unsure, It's very close looking. Would have to pull spring from coilover to fully compress and see and I'm far too lazy for that
Old 05-15-2022, 09:53 AM   #419
jbug187
Drives: 2022 Subaru BRZ Limited MT
I've had this car for almost three months and have had a great time doing some small mods (PowerStop brake pads, Castrol SRF brake fluid, K&N Air Filter, TRD Duckbill Spoiler) and taking it to the track for a couple of HPDE1 events. I live in the Northeast and want to get a separate set of wheels / tires for non-Winter daily driver and track day duty and could really use some advice as I've read through this entire thread and am still not confident about fitment.
I'd like to get flush fitment and avoid replacing the stock suspension or rolling / pulling fenders if possible. I like the Aodhan AH09 (and its price) which comes in 18", 8.5", ET35, but I'm not sure if the offset is too aggressive on a 8.5" wide wheel (I know it would be on a 9.5" wheel). In this post from Panda Grahams it looks like he was able to achieve flush fitment with a 0.5" thinner wheel and I'd be using the same 225 tire size. With that being said I don't see any Gen2 BRZs or 86s with the AH09 wheels online, which doesn't make me hopeful.
To throw another variable into the mix I'll also be installing these fender flares which say they "add another 8mm" (inspiration here). The installation guide for the fender flares requires minimal drilling inside the wheel well so I think this is something I could do on my own without any invasive cutting / welding. I guess it's fairly obvious the tires will looks more 'tucked' with the additional 8mm added to fender? Ultimately, I'm looking for a flush fitment without any rubbing. If anyone sees any obvious mistakes with AH09 / 225 + 40R / fender flare setup, please let me know.
jbug187 is offline   Reply With Quote
Old 05-15-2022, 08:47 PM   #420
bradsm87
When you say flush, do you mean flush with the new over fenders? You'll need plenty of cutting to get that. At least cut the invasive part that the fender tab thing usually mounts to.
I think 225s on 8.5s with +35 offset would probably be OK with the above mod, presuming you'll be running no camber adjustment (exact camber depends on how lowered it is).
Rear wheel alignment issues... HELP! Rambo305kid Issues | Warranty | Recalls / TSB 10 07-05-2020 10:05 PM
Wheel Fitment Issues. Need help. hay_frs Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 8 04-06-2020 06:09 PM
Fitment issues Neal86 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 2 05-07-2019 07:08 PM
Tire/Wheel fitment (rear) rikixass Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 1 01-17-2018 04:09 PM
Fitment Issues Silp3 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 19 01-02-2013 03:34 PM
