Old 08-01-2012, 01:47 AM   #1
Entropy
Oversteer > Understeer
Entropy's Avatar
Drives: GT86
Weight Loss Potential Thread
I was bored this evening so I put together a weight loss potential list. Some weight losses are exact and some are estimated (erred on the conservative side).
I used this thread for most of the stock weights for comparison. Other weights are from threads on this forum.
I left out most of the miscellaneous <.5lb items.
All weights are total (i.e. wheel weight reduction is all 4 corners, not per-side), and estimated weights have a "~".
Code:
Item____________________________Stock___Aftermarket___Reduction
Battery_________________________29.6____~15___________~15
SRT Header-Back Exhaust_________55.5____38.5__________17
Agency Power Header_____________20.8____12.3__________8.5
RPF1 Wheels w/22lb Tires (4)____41.4____~38___________~12
Spare Tire & Foam (remove)______25.8____0_____________25.8
Tools, Jack, Hook (remove)______5.8_____0_____________5.8
Essex Sprint BBK (AP Racing)____61.6____41.6__________20
Rear Speakers (remove)__________?_______0_____________~5
Front Seats/Brackets____________82.8____~45___________~38
Rear Seats (remove)_____________22.2____0_____________22.2
Owners Manual___________________2.8_____0_____________2.8
Perrin Crank Pulley_____________4.9_____1.2___________3.7
Flywheel (n/a yet!)_____________20.6____~12___________~8.5
CF Driveshaft (n/a yet!)________24.1____13.9__________10.2
Windshield Washer Fluid Bottle__~7______0_____________~7
This list puts us near a 200lb reduction, while still remaining 100% daily driveable. I understand there are some more serious mods for reducing weight, such as stripping the interior or gutting the AC, but for now I'm trying to keep most of the comforts of owning a brand new car.
Post up and I'll add to the list when I can! I know there is more un-needed weight that can be lost!
Sources:
http://www.ft86club.com/forums/showthread.php?t=7881
http://www.ft86club.com/forums/showp...0&postcount=11
http://www.ft86club.com/forums/showp...62&postcount=1
http://www.ft86club.com/forums/showp...63&postcount=7
http://www.ft86club.com/forums/showp...99&postcount=4
http://www.ft86club.com/forums/showp...84&postcount=1
http://www.ft86club.com/forums/showp...97&postcount=2
http://www.ft86club.com/forums/showp...67&postcount=3
http://www.ft86club.com/forums/showp...4&postcount=31
http://www.enkei.com/size_chart/RPF1.pdf
http://fecompetition.wordpress.com/
http://www.essexpartsblog.com/news/b...-shaves-10-lbs
http://www.ft86club.com/forums/showthread.php?t=18364
Entropy is offline   Reply With Quote
The Following 14 Users Say Thank You to Entropy For This Useful Post:
Anthonytpt (02-19-2013), Auto-Hauss (08-01-2012), Black Tire (02-09-2013), Blokatos (05-02-2016), blu_ (08-01-2012), GTB/ZR-1 (11-10-2012), JRitt (08-01-2012), LeavingNormal (08-01-2012), PoorMansRacing (12-05-2013), Scooby South (08-08-2012), suaveflooder (12-28-2013), SuperTom (01-09-2020), TRD_07 (01-12-2013), wsites (03-01-2017)
Old 08-01-2012, 02:28 AM   #2
Captain Snooze
Because compromise ®
Captain Snooze's Avatar
Drives: Red Herring
Windscreen washer fluid. approx 7 pounds.
Old 08-01-2012, 08:54 AM   #3
JRitt
JRitt's Avatar
Drives: 2012 BRZ Premium WRB 6MT
Nice post, thanks.
You were definitely a bit conservative on your battery weight loss potential. We were able to knock 25 lbs. off with current lithium-ion technology, while still maintaining 100% daily utility. Finding that extra 10lbs. elsewhere without impacting usability will probably not be super easy.
Essex Parts Services- AP Racing / Ferodo / Spiegler / Versodeck
Jeff Ritter|Mgr.- High Performance Division
www.essexparts.com
JRitt is offline   Reply With Quote
Old 08-01-2012, 08:57 AM   #4
TSLRich
Drives: FJ Cruiser
Your calc is off on the wheels... 41-38 is 3, not 12.
TSLRich is offline   Reply With Quote
Old 08-01-2012, 09:11 AM   #5
ZDan
ZDan's Avatar
Drives: '23 BRZ
3x4=12
Old 08-01-2012, 09:43 AM   #6
7thgear
i'm sorry, what?
7thgear's Avatar
Drives: Canada
do the seats have airbags in them?
if yes, does removing them affect the functionality of the airbag system?
Old 08-01-2012, 10:00 AM   #7
JohnATL
JohnATL's Avatar
Drives: 2013 Scion FR-S MT Raven
What are the lowest pulse cranking amps and amps/hour reserve to keep this a daily driver?
JohnATL is offline   Reply With Quote
Old 08-01-2012, 10:17 AM   #8
Entropy
Entropy's Avatar
Drives: GT86
Didn't think about that one. That's something that I've removed or hasn't worked on my past cars. Not a problem for DD unless your driving on roads with lots of sand/grit (i.e. snowy roads that have melted!). Thanks!
Originally Posted by JRitt View Post
Nice post, thanks.
I have seen that battery and it is AMAZING! However, it's very much on the pricey side, which is why I went conservative with the number. Prices should eventually come down, though, like they do for just about all new-tech items
Old 08-01-2012, 10:26 AM   #9
JohnATL
JohnATL's Avatar
Braille has a few lightweight batteries for much less. I'm just not sure if they're any good. Anyone have any experience with them?
http://www.braillebattery.com/index....batteries/b106
The Following User Says Thank You to JohnATL For This Useful Post:
GenkiElite (09-09-2012)
Old 08-01-2012, 10:30 AM   #10
7thgear
i'm sorry, what?
7thgear's Avatar
Drives: Canada
that would depend entirely on the climate of where you live.
Old 08-01-2012, 10:33 AM   #11
JohnATL
JohnATL's Avatar
Between Hot and Stupid Hot.
Old 08-01-2012, 10:37 AM   #12
7thgear
i'm sorry, what?
7thgear's Avatar
Drives: Canada
you can probably get away with just using a lemon and some copper wire
The Following 4 Users Say Thank You to 7thgear For This Useful Post:
fuddbutter (09-10-2012), Ingen (02-12-2013), Keenercarguy (01-16-2017), SuperTom (01-09-2020)
Old 08-01-2012, 10:42 AM   #13
JohnATL
JohnATL's Avatar
I think I'll try that Braille B106 out. At 6.9lbs and $148 it's worth a shot.
Old 08-01-2012, 11:36 AM   #14
SemperFi
Drives: Its a scion....FRS
Taking a dump before getting in the car 5 to 8 lbs.
Born to fight, Trained to kill, Ready to Die, But I never will. Semper Fi.
93 Integra GSR (Sold), 2007 Toyota Fj Cruiser (Sold), 2007 Aston Martin V8 Vantage, 2008 VW R32 (Sold), 2013 Toyota FR-S
SemperFi is offline   Reply With Quote
The Following 10 Users Say Thank You to SemperFi For This Useful Post:
20valvewynn83 (08-01-2012), czar07 (09-10-2012), eddieflyinv (08-29-2016), ericmpena (03-05-2014), gdi2290 (09-11-2012), Keenercarguy (01-16-2017), NJ10 (03-31-2015), Obja (09-21-2012), sierra (09-19-2012), werswaldo (02-13-2019)
Official Component Weights & Weight Reduction Thread JRitt Tracking / Autocross / HPDE / Drifting 381 10-03-2024 08:02 AM
Official Weight Reduction Thread - Sort of... merlin2111 Off-Topic Lounge [WARNING: NO POLITICS] 77 10-07-2012 05:09 PM
Potential Group Buys Thread eleu2166 Australia Classifieds 95 07-25-2012 05:53 AM
Weight loss potential? SevenTenSplit Engine, Exhaust, Transmission 10 12-10-2011 02:16 PM
weight loss cynic Scion FR-S / Toyota 86 GT86 General Forum 36 10-24-2011 04:04 AM
