Old 05-02-2022, 04:15 AM   #1107
soundman98
ProCrastinationConsultant
soundman98's Avatar
So you're saying the solution is to remarry once to avoid too much painting!
Old 05-02-2022, 07:00 AM   #1108
spcmafia
spcmafia's Avatar
Drives: 2018 Subaru BRZ
Ya, I hear that!
Back in Missouri, I bought a 4,000 sq ft house. My wife (now ex) wanted it all painted or wall papered so it would be personalized. So, I did that.
A few years later she took off. So, I met the present mrs humfrz and we sold her condo and she and her daughter moved into my house with my two sons. She wanted the whole house re-painted or wallpapered so it would be personalized (different from the old mrs humfrz's tastes). So, I did that, again, yep the whole 4,000 sq ft.
A couple of years after that we moved to Washington. I let her and our daughter pick out the house that we bought. Shortly after we moved in, she decided that the whole house needed to be repainted. I reluctantly agreed to do that, with the stipulation that I was only going to paint it ONCE, so she better be sure of the colors she wanted for each room (of course, they all had to be different - ).
So, for the next few weeks, she had swatches of different colors of paint all over every room.
FINALLY, I said that I was only going to paint the house once and if she couldn't make up her mind within a couple of weeks, I was going to paint the whole damn house "doeskin"!
She decided, I painted - end of story.
After we were done, mrs mafia blurted "We still need to do the ceiling". I'm paying someone to do that. They can break their neck staring at the ceiling.
spcmafia is offline   Reply With Quote
Old 05-02-2022, 07:01 AM   #1109
spcmafia
spcmafia's Avatar
Is more of a don't get married so that you're not painting a 4000 sq ft house twice in case the first wife doesn't quite work out.
Old 05-02-2022, 08:46 AM   #1110
Sapphireho
Famous Potatoes
Sapphireho's Avatar
Drives: '15 ultramarine
Old 05-02-2022, 10:06 AM   #1111
Bought a new Honda GCV170 over the weekend.
OK, it was a pressure washer but still a Honda engine.
Pulled it out of the box, attached the handles, added oil and fuel, switched the power setting to on and it started with basically half a pull and ran flawlessly for about 4 hours, including one fuel up.
Porch is all clean from pollen season now, although I'll likely have to do it once again. That's OK when you've got the right tool it isn't really that much work.
Oh and it does match both the FRS and the Mustang, with it's nice red color.
Old 05-02-2022, 10:12 AM   #1112
dragoontwo
dragoontwo's Avatar
Drives: 22 BRZ limited
Just use an old mower.
Old 05-02-2022, 10:31 AM   #1113
That's pretty slick but wouldn't work on my front porch unfortunately. Would work for the driveway, but my old self propelled mower is designated to be converted into an airplane tug, if I ever get around to working on it.
Old 05-02-2022, 11:31 AM   #1114
Capt Spaulding
Persona Non Grata
Capt Spaulding's Avatar
Drives: '15 BRZ (WRB)
I bought one about 5 years ago, same engine. Be sure to drain the carb after each use or run something more powerful than Stabil in the gas. Mine ran flawlessly the first 3 or 4 times I used it. Then it sat for a couple of months with Stabil in the gas and afterward refused to run on anything but 1/2 choke. I've had the carb off twice to clean it, without success. So now, when I use it, half choke it is.
Slow is smooth, and smooth is fast
Capt Spaulding is offline   Reply With Quote
Old 05-02-2022, 11:46 AM   #1115
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
Run the marine stabil, it is blue. Works much better.
Old 05-02-2022, 01:04 PM   #1116
Oh, yes, time to stand your ground. For the past 30 years, mrs humfrz has "hinted" for me to remove the popcorn from the ceilings in our house. I asked "why"? She says because it is asbestos! My reply has been "if you don't mess with the asbestos, it won't mess with you". Then she says "and, because it's dirty" - my reply is "don't look up".
Old 05-02-2022, 01:19 PM   #1117
Or - have them sign a prenup -
Old 05-02-2022, 01:28 PM   #1118
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
Show her what abatement cost
Old 05-02-2022, 01:57 PM   #1119
Old 05-02-2022, 02:23 PM   #1120
Capt Spaulding
Persona Non Grata
cnc'r? i barely know er!, have you turned it off/on, i heart my boxer, i still hate you all, kiss me, maple syrup, multipass, next one is a prequel, ow my balls, special_k abandoned you, the search for more money
Random Thoughts - Part Deux [NO POLITICS] Ultramaroon Off-Topic Lounge [WARNING: NO POLITICS] 84004 03-07-2022 11:00 AM
OEM BRZ spark plug part number? qqzj Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 3 05-26-2017 11:33 PM
Random search on bing sdwagonjp Off-Topic Lounge [WARNING: NO POLITICS] 11 11-19-2014 07:35 PM
