Old 08-01-2012, 10:09 AM   #197
Dave-ROR
Site Moderator
Dave-ROR's Avatar
Drives: Stuff
Originally Posted by kwood9000 View Post
Still would like to see a Dyno without the AP pulley to see what the exhaust system gains.
They still haven't posted that?!?! I swear they said they were going to?
-Dave
DD: 2005 Acura TSX
Tow: 2022 F-450
Old 08-01-2012, 10:17 AM   #198
xjohnx
Grip>Slip
xjohnx's Avatar
It was supposed to go up monday.
Old 08-01-2012, 10:26 AM   #199
EZWood
BAMF
EZWood's Avatar
I should stop by a buddys MD and do a pull.. "look at my 240whp STOCK BRZ!!! OMG!"
You are supposed to be the voice of reason as a moderator. I made that statement because of how rediculous it is. I have two minor modifications, and to me what I said sounds as rediculous as what has been said about the quality of this exhaust system, but not quite as bad as a moderator that indulges in what he is supposed to prevent. I'm done with this thread untill after the tenth.
Old 08-01-2012, 10:36 AM   #200
Dave-ROR
Site Moderator
Dave-ROR's Avatar
Drives: Stuff
You clearly missed the point. The point was that a dyno can read high or low and the numbers themselves don't mean anything. The differential is what matters.
In other words, everyone needs to stop being so concerned with peak numbers, they don't mean *anything*.
-Dave
DD: 2005 Acura TSX
Tow: 2022 F-450
The Following 3 Users Say Thank You to Dave-ROR For This Useful Post:
Motordyne (08-03-2012), TouchMyHonda (08-01-2012), ultra (08-01-2012)
Old 08-01-2012, 11:04 AM   #201
EZWood
BAMF
EZWood's Avatar
I didn't miss anything, peak horsepower isn't the end all, be all. Midrange is more useable in every day driving, but peak horsepower does mean something. If you don't look at the whole picture you are limiting your perspective, and if Dyno numbers don't mean anything, why then do we run our cars on them to get power numbers? There is nothing for you to prove to me. I'm just here trying to help Educate others with my experience. Isn't that why we are all here? To find information on what others have experienced with the same car we have, and find help on what course of action we should take for our cars. That's why I am here.
Old 08-01-2012, 11:12 AM   #202
denkigrve
Random Internet dad
denkigrve's Avatar
Drives: 2013 FRS and 2010 Mini Cooper
They posted each piece individually, and then some combination pieces, and then all exhaust + pulley. What more do you guys want/need. There is officially more information in this thread than any other exhaust thread.
It's still the same few people causing issues here. It's geting a little ridiculous.
denkigrve is offline   Reply With Quote
The Following 5 Users Say Thank You to denkigrve For This Useful Post:
CBR600RR (08-01-2012), Coultergeist (08-01-2012), EZWood (08-01-2012), fenton (08-01-2012), Lonewolf (08-01-2012)
Old 08-01-2012, 11:43 AM   #203
kwood9000
kwood9000's Avatar
Drives: Limited WRB AT6 BRZ
As the pulley appears to have a significant gain, I would like to see a dyno run with only the exhaust kit and no pulley to remove the affect of the pulley and get a true impact of the exhaust. Not sure why this is so difficult to do. Having the pulley added seems to inflate the numbers. I cannot compare this exhaust with others when the pulley is added.
kwood9000 is offline   Reply With Quote
The Following User Says Thank You to kwood9000 For This Useful Post:
mike2100 (08-01-2012)
Old 08-01-2012, 12:02 PM   #204
SkullWorks
Drives: SSM LT MT BRZ
Originally Posted by E92M3Guy View Post
You make some great points and I'm sure you have good intentions. I wanted to clarify that so the noobs wouldn't walk away with the wrong information.
Much appreciated and refreshing
Thank you
Old 08-01-2012, 12:04 PM   #205
Tainen
Drives: First SWP BRZ-L
I'm not sure you're understanding his point. Your car made what, 177whp stock? Ok, cool. On a different dyno, it might pull 155. or 160. or any number in the world. The baseline number is near meaningless, because every dyno reads significantly different. That 177 number is pretty much the highest baseline number anyone has ever seen, which clues us in, that the dyno seems to read a little higher than the other baseline runs we've seen around the forums. Now with that said, the parts you have (or had) on the car did +24whp. Great. That's a good measurable number, you have your baseline(your control group), your variables (the parts) and your test (the runs with parts). If you look at this from basic science perspective, the control/baseline doesn't matter- what matters is the differential, the gain.
I hope that helps explain. Basically- I could go run my car on some dyno that reads high and shows 230whp and say I have the fastest BRZ in the world, but the truth is, the only fact we can truly measure and compare is HP gains, not the total number, due to dyno variance and many, many other variables (temp, humidity, etc)
First white BRZ in the country
Limited SWP BRZ, 35% tint, clear bra, Nameless Performance downpipe, axelback, headers
Tainen is offline   Reply With Quote
The Following User Says Thank You to Tainen For This Useful Post:
kwood9000 (08-01-2012)
Old 08-01-2012, 12:11 PM   #206
xjohnx
Grip>Slip
xjohnx's Avatar
FULL exhaust, otherwise stock (read: no pulley), like they promised from the start.
Old 08-01-2012, 12:22 PM   #207
milenko11
Drives: no
Why bother at this point? Even if their exhaust made 40 whp like they originally tried to claim I wouldn't buy anything from.
milenko11 is offline   Reply With Quote
Old 08-01-2012, 12:23 PM   #208
Dave-ROR
Site Moderator
Dave-ROR's Avatar
Drives: Stuff
To see gains/losses. That's the only reason to dyno. Not trying to prove anything to you either. Not attacking vivid or their parts either, nor you allowing your car to be used for further testing.
-Dave
DD: 2005 Acura TSX
Tow: 2022 F-450
Old 08-01-2012, 12:25 PM   #209
Dave-ROR
Site Moderator
Dave-ROR's Avatar
Drives: Stuff
What I wanted to see (along with many others who requested it) was each exhaust piece, combinations and then the entire exhaust (port back) with no other changes. Mike was planning on doing that so I'm assuming he just forgot to post the dyno. Since I have no desire to run a pulley the lack of that dyno means he hasn't provided the information I need to make an educated decision in regards to Agency Power's exhaust setup. As for all the butt dyno type stuff, it's worthless. :shrug:
-Dave
DD: 2005 Acura TSX
Tow: 2022 F-450
The Following 2 Users Say Thank You to Dave-ROR For This Useful Post:
kwood9000 (08-01-2012), xjohnx (08-01-2012)
Old 08-01-2012, 12:50 PM   #210
Lonewolf
Lonewolf's Avatar
Drives: Moped
Or maybe Mike got sick of dealing with the same ol bs despite the effort he spent to correct his initial mistake.
The Following User Says Thank You to Lonewolf For This Useful Post:
Agency Power Exhaust vividracing Engine, Exhaust, Bolt-Ons 17 07-23-2012 02:40 PM
Agency Power (headers) Polo Engine, Exhaust, Transmission 1 07-21-2012 06:27 PM
Enjuku Racing - Agency Power - New Products Released Enjuku Racing Engine, Exhaust, Bolt-Ons 0 07-16-2012 04:46 PM
FRS on a heartbreaker dyno (Vivid Racing car) Lonewolf FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 21 06-14-2012 06:29 AM
