Go Back   Toyota GR86, 86, FR-S and Subaru BRZ Forum & Owners Community - FT86CLUB > 2nd Gens: GR86 and BRZ > BRZ Second-Gen (2022+) — General Topics
BRZ Second-Gen (2022+) — General Topics General topics for the second-gen BRZ
Old 04-14-2022, 03:33 PM   #869
AK2112
AK2112's Avatar
Drives: 22 BRZ
Originally Posted by 22 BRZ View Post
I'd like something between the two different OEM options. My Subaru front flap is so long that it hits the ground over every big bump and even under hard cornering. Its flexible, but even still its permanently bent backwards now from all the impacts.
Appreciate hearing that info about the Subaru ones.
I was set on the Toyota ones but they look a little chunkier than they need to be and it doesn't seem like they'll do much (especially with the front side vent getting the doors messy whenever it rains). I'm back to leaning towards the Subaru ones but I'm not sure.
AK2112 is offline   Reply With Quote
Old 04-14-2022, 03:46 PM   #870
DocWalt
DocWalt's Avatar
Drives: '22 BRZ
I'd have done the Subaru ones but @Kado told me he was dragging his flaps everywhere. The Toyota ones could definitely have used a little better coverage but it's "fine"
Old 04-14-2022, 04:29 PM   #871
kaesu
Drives: 22 BRZ
Originally Posted by joemysterio View Post
I really want the Fujitsubo A-R exhaust but even now it's still just too crazy expensive. I guess I'll keep waiting for my HKS to arrive in August, even that one is pushing how much I'd like to spend on an exhaust.
I'm so impatient though, I'm tempted to get something that's available now and use it temporarily until my HKS arrives, but that's contradictory to my penny pinching lol.
I know how you feel haha. You could always just grab a used first gen until then, resale shouldn't be too bad
kaesu is offline   Reply With Quote
Old 04-14-2022, 08:56 PM   #872
22 BRZ
22 BRZ's Avatar
Drives: 2022 Subaru BRZ 6MT IR
More info here if you're interested, not sure if you've seen it.
https://www.ft86club.com/forums/showthread.php?t=148138
2022 BRZed, Red, Base, Manual, Simple
22 BRZ is offline   Reply With Quote
Old 04-21-2022, 08:19 PM   #873
dragoontwo
dragoontwo's Avatar
Drives: 22 BRZ limited
Installed Killer B exhaust tip extensions.
Old 04-21-2022, 08:40 PM   #874
Yoshoobaroo
TRACKBREAD
Yoshoobaroo's Avatar
Looks great!
Old 04-23-2022, 09:04 AM   #875
foshjowler
Drives: 2022 BRZ; 2014 BRZ
New wheels came in. They were the last complete set of 17x8 of the 6ULs. Will be going on Monday with the stock Primacys. Was planning on putting either PS4S or AS4s, but I'm getting a real good deal on an engine for the Miata, so money is short at the moment. Especially after buying the car and another set of wheels/tires for autox.
2022 BRZ (sold)
2014 BRZ
2014 Cayman
Autox Videos
foshjowler is offline   Reply With Quote
Old 04-23-2022, 05:37 PM   #876
22 BRZ
22 BRZ's Avatar
How well do the stock 215s fit on an 8inch wheel?
Old 04-25-2022, 02:03 AM   #877
joemysterio
Drives: Mini
Today I installed the Cerwin vega spare wheel subwoofer, it worked on the first try so was thankful I didn't have to troubleshoot anything. But I am considering redoing the power though because the kit I got said the power cable was 8 gauge but it's definitely smaller wire, closer to 12 I would say. I'm uncomfortable with that so need to look for better option while I have everything removed inside.
Another problem is that I have no spare wheel currently so the sub sits low and because of that when I temporarily put back the foam pieces and the trunk floor board to test fit, it sunk with any weight on it, basically. So i need to find a way to support that now.
I'll post a pic tomorrow, it got late and I was in a hurry to clean up.
joemysterio is offline   Reply With Quote
Old 04-25-2022, 03:12 AM   #878
Flarpswitch
Flarpswitch's Avatar
Drives: 2022 BRZ Ltd, 2025 Ascent Touring
I bought a front license plate mount from Subaru and it seemed to be overkill for my BRZ, so I put it on the front of my Ascent and it was an improvement there. I used the supplied well nuts. I also replaced the hex head screws on the rear license plate with pan-head screws which won't snag the wash mitt and shred it. The rear license mount has four plastic anchors built into the tail gate. Square one with the BRZ and then the license plates showed up earlier that I expected. On the front, I did not want to drill new holes at the indicated dimples, so I just go some metric stainless steel screws to fit the threaded inserts already there and drilled the license plate to match. Simple and neat. The dealer had already drilled two of the four holes on the rear to install their dealer frame and advertising insert. I could have just run some screws right into the plastic, but I decided to install the well nuts also sporting stainless steal pan head screws. I did not install the two lower ones as just the top two seem to hold the license plate flat and secure. I am not into fancy frames and extra hardware that manages to collect dirt and bugs. I am glad that dealers don't drill holes and rivet mount their trademarks and logos on the body or trunk lid like they used to.
The ants are our friends, they’re blowing in the wind, that ants are blowing in the wind.
Flarpswitch is offline   Reply With Quote
Old 04-25-2022, 07:44 AM   #879
KillerBMotorsport
KillerBMotorsport's Avatar
Call them dated, but I'm traditionalist so I went with RPF1s and the stickier Pilot Sport 225/40/18 (Porsche Spec PS2). Heat cycled them first day, then yesterday took them for an aggressive mountain road rip. Seems nice a bit more grip than stock with no downside that I can tell. Pegged the G-Meter many times without issue.
KillerBMotorsport is offline   Reply With Quote
Old 04-25-2022, 08:04 AM   #880
dragoontwo
dragoontwo's Avatar
Offset and width?
Old 04-25-2022, 10:09 AM   #881
KillerBMotorsport
Offset and width?
stock offset 8" wide. I may bump up to 235 tires next go around.
Old 04-25-2022, 12:00 PM   #882
joemysterio
Drives: Mini
I still need to add some sound deadening, and like I said, I may redo the power cable once I find a suitable replacement.
WHAT DID YOU DO TO YOUR FRS TODAY? KalbiCool88 Scion FR-S / Toyota 86 GT86 General Forum 1 11-04-2015 10:36 PM
Do you know what today is? Yruyur Off-Topic Lounge [WARNING: NO POLITICS] 26 01-21-2015 02:51 PM
just got my OFT today...help please! carlitosway6891 Software Tuning 9 02-20-2014 10:05 PM
TODAY, TODAY, I GET IT TODAY!!!! :D Trashed675 Scion FR-S / Toyota 86 GT86 General Forum 54 02-14-2013 01:16 AM
