Old 04-16-2022, 11:53 AM   #1
shr133
shr133's Avatar
Drives: 2013 FRS
Tuning for Grams 72mm Throttle Body
So what is the consensus on tuning for the Grams TB?
Some people have just installed with no problems and other people have had tons of problems.
I'm supercharged and had to warranty my Jackson radiator and decided to upgrade the TB while I had it apart.
It was working great for a few drives, then boom went into limp mode and won't reset. codes P0122 P0222.
I have an accelerator position sensor on the way, it could be that...
Or do I have to tune for the TB and what map needs to be calibrated??
Thanks.
EDIT: LOOKS LIKE IT WAS THE ACCELERATOR SENSOR replaced it with one from a 2022 and everything is working great. Sensor must have been worn out. So if you put one in and are having trouble replace your accelerator sensor and go from there...
Enkei TS9 18 X 8, Michelin Sport 4S 225 40 18, Flex Fuel, Edelbrock Supercharger, P & L header, Nameless front pipe, V1 cat back, Aluminum Driveshaft, pvc delete, med duck bill, KW V3, Whiteline 20 and 18 mm bars, Buddy Club and SPL control arms, Toe Arms, motor and trans mounts, Whiteline bushings, SHR stage II tune.
shr133 is offline   Reply With Quote
Old 04-16-2022, 12:44 PM   #2
tomm.brz
Drives: brz 2017 hksv2
No real need to tune , so probably it s electrical problem
Old 04-16-2022, 04:28 PM   #3
PulsarBeeerz
Drives: JRSC BRZ SOLD
Check the adapter harness that comes with it and make sure its secure. Also you'll need to re-tune anyway as the amount of air coming it at idle is different. CSG was surprised by how much richer they needed to make my tune with just a 2mm bore on the stock TB. I never ran into electrical issues while using the Grams unit but I have heard stories of it.
PulsarBeeerz is offline   Reply With Quote
The Following 2 Users Say Thank You to PulsarBeeerz For This Useful Post:
jeepmor (12-23-2024), shr133 (04-16-2022)
Old 04-16-2022, 04:51 PM   #4
shr133
shr133's Avatar
Drives: 2013 FRS
Wire harness was good. Car ran great. I'll change out the accelerator sensor and go from there. I'll have to tune the idle and fuel, but first data logs we good... My fuel map was so good I hated to change anything, but keep moving forward... If I get it to work it will be worth it...
Old 04-16-2022, 05:58 PM   #5
tomm.brz
that s actually True, but shouldnt cause voltage DTCs
Quite more possible it s a loose Connector that loses contact
Old 04-16-2022, 06:11 PM   #6
PulsarBeeerz
Oh, I agree. There have been folks that had error codes in the past with this TB. Usually it was a faulty harness. Perhaps the pins weren't locked in, who knows but people had to request a second harness to alleviate their issues. I remember I had to push the connector quite firmly in order to get them to lock.
The Following User Says Thank You to PulsarBeeerz For This Useful Post:
shr133 (04-20-2022)
Old 04-20-2022, 06:22 PM   #7
shr133
shr133's Avatar
Drives: 2013 FRS
I'll ck out the harness. thanks..
Old 04-24-2022, 04:08 PM   #8
shr133
shr133's Avatar
Drives: 2013 FRS
Looks like it was the accelerator position sensor. Replace with one off ebay, they are on 2 month backorder, but got one off a 22...
So far working great...
The Following User Says Thank You to shr133 For This Useful Post:
tomm.brz (04-25-2022)
Grams 72mm Throttle Body gbula8 Engine, Exhaust, Bolt-Ons 5 07-06-2021 04:46 PM
Brz throttle body issue (Grams 72mm) Tomomi Engine, Exhaust, Transmission 17 08-22-2020 02:21 AM
grams throttle body install, won't start jdair28 Engine, Exhaust, Transmission 34 06-26-2019 11:31 AM
OFT and Grams throttle body 86Speedy Software Tuning 27 05-05-2017 05:21 PM
