Old 06-09-2021, 07:27 PM   #253
BrahmaBull1990
Howdy
BrahmaBull1990's Avatar
Drives: 2020 BRZ PP
Originally Posted by 86TOYO2k17 View Post
Stock limiter is 7,400 most tuners raise to 7,500.
Shift 50rpm before limiter. Shift at the last possible moment to still not hit limiter/fuel cut but rev as high as possible.
I specified mechanical torque to the wheel.
Not torque or hp on a dyno graph.
Mechanical torque is calculated after all gear ratio, wheel size etc… are factored in.
You want to shift gears at the RPM when the current gear you are in has LESS mechanical torque at the wheel than the next gear will have at the RPM it will land in after shifting.
On most cars the mechanical torque to the wheel is always higher in the numerically lower gear all the way to rev limiter. You’d need to make like 400ft lbs at 5k and 200ft lbs at 6,500rpm to benefit from short shifting. A 20-30% drop in torque is more than made up for by torque multiplication through numerically higher gearing.
Thank you! I’m learning, bit-by-bit. Thank you for the help and patience. I need to get over my fear of revving it out. I went FI to have fun and let this car live! Saving for a IAG short block now haha
There's a point at 7,000 RPM... where everything fades. The machine becomes weightless. Just disappears. And all that's left is a body moving through space and time. 7,000 RPM. That's where you meet it. You feel it coming. It creeps up on you, close in your ear. Asks you a question. The only question that matters. Who are you?
BrahmaBull1990 is offline   Reply With Quote
Old 09-10-2021, 02:20 PM   #254
pmcoffee
Finally got a decent tune and on a dyno.....
pmcoffee
2013 BRZ Limited AT
- Perrin Vortech V3 SC Kit
- 93 oct
- 9 psi at 7500 rpm
- Perrin oil cooler, JDL UEL header, Perrin 2.5" exhaust from header back, high flow cat in Perrin front pipe, 245/35x18 square
- Tuner - Ed at Fast Performance Tuning using OFT/Rom Raider
https://www.facebook.com/FastPerformanceTuning/
high temp in the test area - 99F SAE correction is 279 hp
Tuner commented on the good lockup/low loss with the AT
- tuned on Dynocom 5000 fx
pmcoffee is offline   Reply With Quote
The Following User Says Thank You to pmcoffee For This Useful Post:
Aztec (09-10-2021)
Old 09-10-2021, 05:16 PM   #255
Aztec
Lost in the twisties
Aztec's Avatar
Drives: 2014 BRZ Dark Gray Metallic
Originally Posted by dynarun55 View Post
Quite literally the reason I will go with a Jackson racing C30 supercharger
But why not Edelbrock
NEW CAR!🚨🏎️⛽
2014 BRZ: Edelbrock SC, CSG ZachTune, Jackson Radiator/Oil cooler, lightweight flywheel, CNT UEL, Berk OP/FP, Ark Grip Catback, Carbon fiber Driveshaft
Aztec's Build Thread
Aztec is offline   Reply With Quote
Old 04-14-2022, 04:56 AM   #256
reign-AU
Drives: 2019 BRZ tS STi
HKS gt3rs kit on 98.
reign-AU is offline   Reply With Quote
Old 04-18-2022, 04:11 PM   #257
dynarun55
dynarun55's Avatar
Drives: 2015 midnight blue limited edition.
JRSC- Pump gas (93) on Mustang dyno.
- Jackson Racing C-30 supercharger kit.
- OEM headers and exhaust.
- IAG Stage 2 10.5:1 Compression ratio
- AEM 340 Fuel pump
- ID1050x Fuel injectors
- Conditions: Really hot - 85 C ambient. Fuel - 93 Octane pump gas
- Tuner - Junior Barros- JRTuned using Mustang dyno
Installed at ShiftFast automotive and performance, SC-29730
https://www.facebook.com/shiftfastau...andperformance
dynarun55 is offline   Reply With Quote
Old 04-18-2022, 09:17 PM   #258
dynarun55
dynarun55's Avatar
Has anyone here measured an OEM header, exhaust setup on a mustang dyno ? Curious to know if these numbers are on the lower side...
I'm not nearly concerned about the absolute number but just a little concerned if there is potentially a problem... Never had the time to do a baseline without the kit on the car...
- AEM 340 Fuel pump
Old 04-19-2022, 07:19 AM   #259
StraightOuttaCanadaEh
Wes
Mustang dynos are known to read lower than most others
Instagram: @gt86ws
Old 04-19-2022, 07:44 AM   #260
tomm.brz
Drives: brz 2017 hksv2
- AEM 340 Fuel pump
buddy why dont you at least decat it and raise boost with a smaller pulley to take advantage of the reduced compression?
You have at least a potential 350HP at the crank to be reached with your good quality 93 octane fuel, it s a shame to let the car be so underpowered
Not saying you have to max it out and risk the engine, but you could easily have more ignition timings with some minor work
Old 04-19-2022, 07:50 AM   #261
dynarun55
dynarun55's Avatar
Ha! Ikr... Have a baby boy due in 7 weeks so I wanted a factor of safety of 2 on basically every parameter This build has been a nightmare but that's a story for another time but yes that is something I would want to do in the future..
Sent from my Pixel 3 using Tapatalk
Old 07-06-2022, 11:37 AM   #262
grumpysnapper
grumpysnapper's Avatar
Harrop.
The latest power run, Motec, on E85, temp at around 15c on a Dynapack.
65mm pulley, IAG 2.5 10.5:1 comp. , ACE headers, no cat, custom 2.75 single exhaust, 4.66 diff. (motor with about 10,000km hard use)
418.85 Nm @ 5035 rpm
374.27 hp (279 KW) @ 7000 rpm
grumpysnapper is offline   Reply With Quote
The Following 2 Users Say Thank You to grumpysnapper For This Useful Post:
DarkPira7e (07-06-2022), PulsarBeeerz (07-06-2022)
Old 07-09-2022, 12:45 AM   #263
gen3v8
30 minute maintenance
gen3v8's Avatar
Drives: My18 wrxsti
SME Spec S (Pulsar G25-550)
98ron
E85
8/12psi
3"dump 2.75" Overpipe, High flow catted front pipe and Q300. ID 1050x injectors
PVS Tuning ( Standard cars typically make from 100-110kw on this dyno)
The Following User Says Thank You to gen3v8 For This Useful Post:
DarkPira7e (03-31-2023)
Old 10-07-2022, 03:01 PM   #264
PTrain
Drives: 2014 FRS
2014 FRS MT
- HKS GT2 supercharger kit
- 93 octane
- ecutek tune
- everything else on the car is 100% stock. Stock exhaust. Stock intake box. No idea what clutch is in it, I assume it was replaced at some point in the cars life but it holds ok so far.
PTrain is offline   Reply With Quote
Old 03-31-2023, 05:00 PM   #265
Ignore Your Doctor
Ignore Your Doctor's Avatar
Drives: 2015 BRZ WRB
2015 BRZ
JRSC C38 w/ HBP
Walbro 450 pump
ID1050x
Delicious tuning e85 kit 68-70% ethanol
JDL 4-2-1 EL headers w/ Nameless combo pipe and perrin 3" CBE
Ignore Your Doctor is offline   Reply With Quote
The Following 2 Users Say Thank You to Ignore Your Doctor For This Useful Post:
DarkPira7e (03-31-2023), StraightOuttaCanadaEh (03-31-2023)
Old 08-18-2023, 04:43 PM   #266
canyons
canyons's Avatar
Drives: 2013 Supercharged BRZ, E85, Ohlins
2013 Limited JRSC
2013 car, JRSC kit installed 2016
Seven trouble free years so far!
A few ponies have escaped but not too bad!
Pump gas 92 Octane
290WHP/211 Tq.
I expect the E85 numbers will be +15-20HP
canyons is offline   Reply With Quote
The Following 2 Users Say Thank You to canyons For This Useful Post:
Lantanafrs2 (08-19-2023), Teseo (08-18-2023)
Dyno numbers list from Evasive Motorsports Meet/Dyno Fish Southern California 29 02-24-2013 03:16 AM
Dyno Compilation - dyno testing results and recommendations Illusive Engine, Exhaust, Transmission 82 02-08-2013 07:00 PM
Bolt-ons dyno comparisons thread? seven Engine, Exhaust, Transmission 6 11-25-2012 10:28 PM
Base line dyno figure (dynapak Hub dyno) gtauto AUSTRALIA 16 10-08-2012 08:06 AM
