Old 08-01-2012, 05:03 AM   #57
HKS Australia
Australia HKS Distributor
HKS Australia's Avatar
Drives: Fast One
Originally Posted by cruzinbill View Post
could you post a different pic of it, its hard to see anything behind the S/C due to the angle of the one.
Is this any better. Might give you a better idea.
Cheers
HKS Australia
HKS Australia is offline   Reply With Quote
The Following 2 Users Say Thank You to HKS Australia For This Useful Post:
cruzinbill (08-01-2012), MSTiFK8R (08-01-2012)
Old 08-01-2012, 05:14 AM   #58
cruzinbill
Drives: Argento 6spd FR-S
Cheers
HKS Australia
ah ok thanks much better, they basicly mounted it between the alt and the ac, vs removing the ac. Are you liking it overall? It does look pretty sweet.
cruzinbill is offline   Reply With Quote
Old 08-01-2012, 05:21 AM   #59
MSTiFK8R
MSTiFK8R's Avatar
Drives: BRZ WRB
Thanks for clearing that up!
Which ECU\Fuel management remapping is planned to use in your package?
The reason why I ask is I would love the out-of-the box bolt-on solution without necessity for countless extra dyno runs and notebook magic dances around the car as we lack serious tuners in here
MSTiFK8R is offline   Reply With Quote
Old 08-01-2012, 10:01 AM   #60
Don@Accelerated
Don@Accelerated's Avatar
I do but only from testing 6 months ago. I'm also not able to post that up on here sorry. It made 251hp at 6500rpm but as you are probably finding out with your EcuTek there is issues (with more boost to make this power figure) trying to control the 2 injectors per cylinder. On a race car it doesn't matter and you can make up to 300hp without engine issue BUT retaining factory driveability with 8psi and the direct injection is not easy. So far HKS are only controlling the upstream injector and fitted a restrictor on the Supercharger intake to limit power because of this.
Cheers
HKS Australia
WE haven't run into that particular issue yet. We had others. We've been able to keep driveability 100% so far. No buggy issues. We'll be turning up the hp in the next week to come.
Don
Don@Accelerated is offline   Reply With Quote
Old 08-01-2012, 10:58 AM   #61
subatoy
subatoy's Avatar
Drives: subatoy
Originally Posted by Don@Accelerated View Post
Do you have a graph that we can overlay and compare to one another. Thus far I only have the turbo setup working at 3 creeping to 4. I'd imagine that once we can solve the ecu issues, I'll be able to pick up another 20-30 hp. Don't quote me on that yet until I do it.
Any idea what costs are going to be on the supercharger kit. I have a customer interested in supercharging. I've heard prices all over the place and as high as 8500 usd.
Don
This is just me but I would never spend $8,500 on ANY kind of FI. that's a 1/3rd the price of the car for just a few horses that you could gain in an already turboed car for $500 reflash.
subatoy is offline   Reply With Quote
The Following User Says Thank You to subatoy For This Useful Post:
SkAsphalt (08-01-2012)
Old 08-01-2012, 12:57 PM   #62
yuli8466
Drives: MX5
Originally Posted by sw20kosh View Post
Then you don't want this HKS system. Not all superchargers are the same.
A centrifugal supercharger like HKS's builds boost slowly and only reaches max boost by redline.
Here is a good example of boost generation by a centrifugal s/c. Look at the bottom portion of the graph where it says boost on the Y axis.
As for Roots style superchargers (which Toyota likes to use) you get boost nearly right away like this Stillen Supercharger. Again look at the bottom portion where it says boost on the Y-axis. It holds 6-7 psi throughout the rev range.
Here is another Roots blower at ~20 psi
Here is the "spool up" of a turbo. Notice its exponential build up.
thank you for the information.
whatever we have to wait for the HKS centrifugal supercharger (for 86)
dyno map to know the exact result.
I think they don't have a high boost horsepower, only 250hp. So it "should" boost very early of the RPMs. like original N/A setup.
yuli8466 is offline   Reply With Quote
Old 08-01-2012, 01:01 PM   #63
yuli8466
Drives: MX5
Originally Posted by wcbjr View Post
That's why transmissions have gears. Put it in the right gear and lag is a non-issue.
wow , that would be a racing style, not everyday drive keep a high rpms.
Old 08-01-2012, 01:24 PM   #64
MiguelAE86
Drives: NB Miata
Thank You HKS Australia for answering all of these questions, and all the other vendors out here on this forum (most). I love how they're pretty involved with their market. Rare in the world these days.
Guess it comes with the enthusiast mentality
MiguelAE86 is offline   Reply With Quote
Old 08-01-2012, 07:29 PM   #65
HKS Australia
Drives: Fast One
Currently the GT Supercharger Kit will be offered with the F-Con iS and plug in harness. This is because HKS haven't yet finished their Flash Tuner for this car. Because the F-Con iS only controls the upstream injector the HP will be limited with a restrictor. I'm trying to find out if we can buy the kit less computer and restrictor to allow 250+ HP as the setup is good for 300hp, then customers can source their own tuning if needed. Otherwise you can buy the whole plug and play kit.
Cheers
HKS Australia
Old 08-01-2012, 07:30 PM   #66
HKS Australia
Drives: Fast One
Don
Thanks Don and looking forward to the results.
Cheers
HKS Australia
Old 08-01-2012, 07:37 PM   #67
HKS Australia
Drives: Fast One
Well then my friend this kit is not for you and I completly understand. Everyone will have their own opinion and options to personalise their own vehicle however they see fit and I encourage it. The HKS kit will not be for everyone and neither will a turbo kit. Each to their own.
It's just fantastic to see a manufacturer finally building a vehicle that is cheap enough for the aftermarket tuners of the world to play with on a global scale. It means there will be many options for everyone.
Cheers
HKS Australia
Old 08-01-2012, 07:38 PM   #68
HKS Australia
Drives: Fast One
Thanks for the kind words.
Cheers
HKS Australia
The Following User Says Thank You to HKS Australia For This Useful Post:
MiguelAE86 (08-01-2012)
Old 08-03-2012, 09:28 AM   #69
MANDALAY
Drives: MR2
Im biased as i have a SC car. Its great and better than any Turbo IMO. I enjoy the Throttle response etc etc.
Only issue i have with the HKS unit is that it is small. Great lay out.
With a Centrifuge SC bigger is better as you want as much air as possible. Then just control max PSI
Whats that unit make ? I call its probably only 0.24 Kg/sec
MANDALAY is offline   Reply With Quote
Old 08-05-2012, 04:14 AM   #70
Rocketogre
Drives: 240sx
I've been lucky enough to ride in a few and drive one GTM supercharged Z-cars and I learned that especially with Rotrex superchargers, you cannot judge an SC by it's compressor cover. The ones in the stage one GTM cars are smaller than the cover on my disco potato(on my SR20 powered 240sx) and they make a good 100whp more than my car makes. I would not at all be suprised to hear that the HKS SC has 300whp in it with the right mods/tuning.
Rocketogre is offline   Reply With Quote
Vortech Supercharger denverizzles Forced Induction 176 10-19-2013 07:48 PM
Supercharger or Turbo ? #87 Forced Induction 192 01-25-2013 11:20 AM
HKS Supercharger getting closer gtauto AUSTRALIA 166 09-03-2012 08:11 PM
TRD Supercharger anyone?? poormans_LFA Engine, Exhaust, Transmission 48 04-28-2012 12:42 AM
Supercharger for Infiniti G25 Lottta Other Vehicles & General Automotive Discussions 2 02-12-2012 10:10 PM
