#43 | |
Sent from my Pixel 5a using Tapatalk
2013 Series 10 FRS #553
#44 | |
The grip will blow your mind compared to your SS1LE. |
| The Following User Says Thank You to CSG Mike For This Useful Post: | evanescent03 (04-20-2022) |
#45 |
Off to the track!
Drives: '14 Lava 86, '13 WRB BRZ
I have Gloc R12 in my fronts and I must say, the pad cut on them is pretty trash. All 4 are a different shape compared to the OEM and Endless pads I have. Also, they drag on the rotors at low speeds resulting in squeaking while driving around... this was solved by sanding them all level on confirmed smooth table (granite). [Before someone comments, my calipers are not the issue as I have no pad dragging issues on any other brake pad and the fronts are freshly rebuilt].
| The Following User Says Thank You to villainous_frx For This Useful Post: | kevaughan (05-06-2024) |
#46 |
When I used to compete in a FWD platform, I ran XP10/XP8 so it was easier to trail brake into corners and the car also didn't have fancy TCS/VSC/EBD for me to worry about. Do people usually run square or staggered pad setup? I don't know if staggered compounds will mess with this car's brake balance or risk triggering "ice mode".
Trying to go for mixed track/street setup so I'm thinking of using R8/R6 or R10/R8. |
#47 |
Drives: '13 FRS - STX
This chassis is designed around square pads, staggered will cause the ebd to work overtime. Xp10s are my first track pad, I wouldn’t bother with r8 unless you know you’re light on brakes.
| The Following User Says Thank You to strat61caster For This Useful Post: | SCFD (04-02-2022) |
#48 |
Drives: Crapcan
When you get into some of the more high friction pads a slight stagger is needed. rice_classic runs St47/43 in a stagger because he was getting rear lockup. Because of my wing I bought 47's F&R and it was too much. Just some brief street testing I get rear ABS to trigger quite a bit.
| The Following User Says Thank You to NoHaveMSG For This Useful Post: | SCFD (04-03-2022) |
#49 | |
#50 | ||
Drives: Halo 860
I've been extremely happy with my CSG C2s and probably won't bother with anything else moving forward, but I understand if people aren't ready to take the plunge on them. |
| The Following 2 Users Say Thank You to deca For This Useful Post: | evanescent03 (04-20-2022), kevaughan (05-06-2024) |
#51 | |
Drives: '23 BRZ
#52 |
Drives: Crapcan
I ran square up until these pads.
#53 | |
![]() Albeit, Brembo front stock rear. I wanted more rear response. |
| The Following User Says Thank You to CSG Mike For This Useful Post: | NoHaveMSG (04-05-2022) |
#54 | |
Drives: Crapcan
I’m thinking of trying a different compound on each corner
#55 |
Drives: '23 BRZ
#56 |
Drives: Nevermorange FRS
Find the pad that maximizes the front tire deceleration then use a rear pad that compliments that; in my case a rear pad that induces “just enough” rear abs as the very limit or under late stage trail braking is ideal.
Think about heat. Stock brakes with no cooling and r-comps = lots of heat. BBK with brake ducks and 200tw tires = very little heat. Run the corresponding pad. Tracks with unique conditions can induce strange realities too. Example, on the racecar the ST43 rear pads will last a full race season+ on PacNw tracks (and california) but in (1) 40 minute race at Road America they got destroyed. RA has 3 hard decel zones from 120+mph which is unique vs most other tracks. If I raced at RA often I would either run a “hotter” pad in the rear or add rear brake cooling.
SCCA T4 - FRS
| The Following User Says Thank You to rice_classic For This Useful Post: | NoHaveMSG (04-05-2022) |
| Recommendation for GTA PDR? | 1Cor10:23 | CANADA | 12 | 11-08-2014 10:08 PM |
| Brake pad and fluid install shop recommendation(south florida)? | becauseracecar1 | Southeast | 3 | 04-21-2014 11:32 AM |
| FS: FRS OEM E-Brake (Emergency Brake) Hand Brake Boot | CamryDS | Interior Parts (Incl. Lighting) | 0 | 06-25-2013 12:26 AM |
| Non LED recommendation for DRL | boredom.is.me | Cosmetic Modification (Interior/Exterior/Lighting) | 13 | 05-11-2013 06:34 PM |
| Redline360: Brake Lines, Brake Rotors, Brake Pads for BRZ/FRS | Redline360 | Brakes, Suspension, Chassis | 12 | 01-05-2013 11:20 PM |
