#5769 |
Well problem solved and lesson learned. MAF housing rotated back to approx 12-o-clock and everything runs fine again. I had no idea the MAF sensor was that sensitive, that simply having it in a slightly different position in the same tube section would cause an issue.
| The Following User Says Thank You to wheelhaus For This Useful Post: | CSG Mike (02-22-2022) |
#5770 | |
| The Following User Says Thank You to CSG Mike For This Useful Post: | wheelhaus (03-25-2022) |
#5771 |
Drives: 2019 Autox BRZ & 2021 GTI (Daily)
Anyone else running the PTuning flex fuel kit and the JRSC — running into some fitment issues with the ethanol sensor and the oil reservoir needing much of the same space. Going to look at modifying the sensor bracket to give more room for the oil line and reservoir, but curious if others have solved in other ways.
2019 BRZ | Autocross focused, CSG tuned w/Jackson racing C38 & PTuning flex fuel kit
2021 GTI | Daily |
#5772 | |
Drives: White FR-S
- Tom |
| The Following 2 Users Say Thank You to ptuning For This Useful Post: | AllThePeat (03-10-2022), CSG Mike (03-11-2022) |
#5773 |
Drives: GEN-1-86-MT-FI / 2022 KTM RC 390
Does this my come with an oil cooler? The FTspeed website shows that it does in the layout of all parts picture. But doesn’t actually mention it in the features portion of the page. Curious if this is just a standard jackson racing feature or not.
#5774 |
It has a oil cooler for the Rotrex Oiling System. NOT a Engine Oil Cooler. That is separate.
#5775 |
Thanks @ptuning for the suggestion on moving the oil reservoir. She’s all buttoned up and ready for some warm weather so I can start her up for the first time!
2021 GTI | Daily |
#5776 |
Drives: 13' Subaru BRZ
Hey guys,
New to the forums and this is my first post, but I had a hard time trying to take off the air intake to replace it with a new one. I loosened the clamp but could not pull out the intake. I had the supercharger kit professionally installed, so I am a bit new to how everything was installed. If anyone could give me any tips on how to take off the intake that would be great! |
#5777 | |
#5778 |
Drives: 2017 BRZ w/PP
This is how i did mine
#5779 |
| The Following User Says Thank You to CSG Mike For This Useful Post: | AllThePeat (04-01-2022) |
#5780 |
Has anyone had this plastic neck crack before? It just happened to me after my datalog and wondering what alternatives are out there that fit
![]() ![]() it is definately coolant too. I thought it was the rotrex coolant at first but was wrong |
#5781 |
Drives: 2023 BRZ
Mine did recently and is getting replaced this week. My car has 125,000 miles on it and is naturally aspirated. I suspect it is just due to age and heat cycling of plastic.
Director of Rocky Mountain 86CUP
#5782 | |
Probably but i remember there use to be a JR part for this that was made out of aluminum but i opted out of it because i thought it was uncalled for. Then i go out there and crack it while data logging. better than on pocono i guess |
| Jackson Racing Rotrex Supercharger System Info and Discussion | Jackson Racing | Forced Induction | 827 | 04-06-2020 04:56 PM |
| Jackson Racing Supercharger Press Release and Info | CounterSpace Garage | Forced Induction | 110 | 01-03-2017 09:04 PM |
| jackson Racing engine oil cooler - modular to fit the Jackson Racing Supercharger! | CSG Mike | Forced Induction | 24 | 04-27-2016 12:59 PM |
| Jackson Racing supercharger | NoppyNop | Forced Induction | 241 | 06-26-2014 03:05 PM |
| Jackson Racing Supercharger Pre-Order Sale, $200 off! | Xero-Limit | Forced Induction | 2 | 03-05-2014 04:14 PM |
