Old 02-21-2022, 08:55 PM   #5769
wheelhaus
wheelhaus's Avatar
Well problem solved and lesson learned. MAF housing rotated back to approx 12-o-clock and everything runs fine again. I had no idea the MAF sensor was that sensitive, that simply having it in a slightly different position in the same tube section would cause an issue.
The Following User Says Thank You to wheelhaus For This Useful Post:
CSG Mike (02-22-2022)
Old 02-22-2022, 10:06 PM   #5770
CSG Mike
CSG Mike's Avatar
Originally Posted by wheelhaus View Post
Maybe you guys can help me troubleshoot something.
My JRSC has been running like a champ so far, except this morning. Throttle response was fine when in vacuum/below boost, but once I got into boost there was no power, just hesitation. No CEL. My Scangauge showed mileage was upwards of 47-48mpg, so its seeing way less fuel being used.
Only other thing thats occasionally caught my attention is cold starts. Sometimes they seem a bit labored and it doesn’t seem eager to fire up, kind of like an old radial airplane engine for just a split second. Once its started it smells rich. I’ve chalked this up to now also turning the tune, and laboring from the supercharger but was curious if it may be related.
Any ideas where to look first?
Actually at the time of writing this, I remember just yesterday I installed a new hood liner and rotated the MAF tube forward for better clearance, and I can’t recall if the MAF sensor orietation is critical- i.e. if it needs to be upright… Gonna check the instructions now.
Edit- The instructions do state MAF to be directly vertical. Would this actually cause the issue I’m experiencing if its rotated forward 90 degrees?
MAF should be vertical. The MAF works on assumptions, including orientation.
wheelhaus (03-25-2022)
Old 02-28-2022, 10:10 PM   #5771
AllThePeat
Drives: 2019 Autox BRZ & 2021 GTI (Daily)
Anyone else running the PTuning flex fuel kit and the JRSC — running into some fitment issues with the ethanol sensor and the oil reservoir needing much of the same space. Going to look at modifying the sensor bracket to give more room for the oil line and reservoir, but curious if others have solved in other ways.
2019 BRZ | Autocross focused, CSG tuned w/Jackson racing C38 & PTuning flex fuel kit
2021 GTI | Daily
AllThePeat is offline   Reply With Quote
Old 03-09-2022, 11:23 AM   #5772
ptuning
ptuning's Avatar
Drives: White FR-S
On my personal BRZ with a JRSC on the car I moved the oil reservoir to the passenger side cross bar next to the battery to be able to keep our flex fuel kit unmodified.
- Tom
ptuning is offline   Reply With Quote
The Following 2 Users Say Thank You to ptuning For This Useful Post:
AllThePeat (03-10-2022), CSG Mike (03-11-2022)
Old 03-15-2022, 02:24 PM   #5773
Sur
Sur's Avatar
Drives: GEN-1-86-MT-FI / 2022 KTM RC 390
Does this my come with an oil cooler? The FTspeed website shows that it does in the layout of all parts picture. But doesn’t actually mention it in the features portion of the page. Curious if this is just a standard jackson racing feature or not.
Sur is offline   Reply With Quote
Old 03-15-2022, 04:34 PM   #5774
JDMChris
Drives: 2016
Send a message via AIM to JDMChris
It has a oil cooler for the Rotrex Oiling System. NOT a Engine Oil Cooler. That is separate.
JDMChris is offline   Reply With Quote
Old 03-26-2022, 02:44 PM   #5775
AllThePeat
Thanks @ptuning for the suggestion on moving the oil reservoir. She’s all buttoned up and ready for some warm weather so I can start her up for the first time!
2021 GTI | Daily
Old 04-01-2022, 02:00 PM   #5776
KZBRZ
Drives: 13' Subaru BRZ
Hey guys,
New to the forums and this is my first post, but I had a hard time trying to take off the air intake to replace it with a new one. I loosened the clamp but could not pull out the intake. I had the supercharger kit professionally installed, so I am a bit new to how everything was installed. If anyone could give me any tips on how to take off the intake that would be great!
KZBRZ is offline   Reply With Quote
Old 04-01-2022, 02:11 PM   #5777
JDMChris
Drives: 2016
Originally Posted by KZBRZ View Post
Hey guys,
Should just pull off. No tricks.
Old 04-01-2022, 05:16 PM   #5778
Breadman
Breadman's Avatar
Drives: 2017 BRZ w/PP
This is how i did mine
Old 04-01-2022, 06:12 PM   #5779
CSG Mike
CSG Mike's Avatar
Off topic, but I love your charging setup.
AllThePeat (04-01-2022)
Old 04-04-2022, 04:01 PM   #5780
Breadman
Breadman's Avatar
Has anyone had this plastic neck crack before? It just happened to me after my datalog and wondering what alternatives are out there that fit
it is definately coolant too. I thought it was the rotrex coolant at first but was wrong
Old 04-04-2022, 06:14 PM   #5781
Pat
Pat's Avatar
Drives: 2023 BRZ
Mine did recently and is getting replaced this week. My car has 125,000 miles on it and is naturally aspirated. I suspect it is just due to age and heat cycling of plastic.
Old 04-04-2022, 07:13 PM   #5782
Breadman
Breadman's Avatar
Probably but i remember there use to be a JR part for this that was made out of aluminum but i opted out of it because i thought it was uncalled for. Then i go out there and crack it while data logging. better than on pocono i guess
Jackson Racing Rotrex Supercharger System Info and Discussion Jackson Racing Forced Induction 827 04-06-2020 04:56 PM
Jackson Racing Supercharger Press Release and Info CounterSpace Garage Forced Induction 110 01-03-2017 09:04 PM
jackson Racing engine oil cooler - modular to fit the Jackson Racing Supercharger! CSG Mike Forced Induction 24 04-27-2016 12:59 PM
Jackson Racing supercharger NoppyNop Forced Induction 241 06-26-2014 03:05 PM
Jackson Racing Supercharger Pre-Order Sale, $200 off! Xero-Limit Forced Induction 2 03-05-2014 04:14 PM
