Old 04-02-2022, 12:06 AM   #1
B-R-Z
I love peanut butter
B-R-Z's Avatar
Drives: 2013 SWP BRZ Limited
Header nuts coming loose
Every 2 years or so I need to tighten my header nuts because I start hearing an exhaust leak. I want to add lock nut washers so I won't have to worry about it anymore, what size are the studs?
B-R-Z is offline   Reply With Quote
Old 04-02-2022, 08:23 AM   #2
https://www.ft86club.com/forums/show...fairly%20tight.
Old 04-02-2022, 10:07 AM   #3
B-R-Z
B-R-Z's Avatar
Thinking of adding only lock washers, I will go with M8 size?
https://www.homedepot.com/b/Hardware...vZc294Z1z0rvsl
Old 04-02-2022, 10:55 AM   #4
KillerBMotorsport
KillerBMotorsport's Avatar
Try some high temp copper anti-seize. It will reduce the thread friction which will increase the clamping force, at the same torque spec. If there is too much friction on the bolt threads, you will not reach the proper clamping force, and without the proper clamping force, you don't have the right amount of bolt stretch. Bolt stretch IS what prevents fasteners from loosening.
Or, get Nord-Locks. This is what the rally guys use, and if you don't use them, you're tightening everything between stages. The vibration is THAT bad under those conditions.
KillerBMotorsport is offline   Reply With Quote
Old 04-02-2022, 11:55 AM   #5
LimitedSlip
Senior Citizen Member
LimitedSlip's Avatar
Drives: Then-1977 Celica GT Now-2017 860SE
Originally Posted by KillerBMotorsport View Post
Or, get Nord-Locks.
Thanks! I learned something. Was not familiar with Nord-Locks. Here is a really good explanation/demonstration video.
LimitedSlip is offline   Reply With Quote
Old 04-02-2022, 12:00 PM   #6
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
The nord lock, lock nuts(that's a mouthful) are a lot better. I buy them in bulk for work, just not in metric sizes.
Or just get top locks. They are a distorted lock nut. This is what I run and mine have never come loose. They are a lot easier to find. I run these at all exhaust connections and on my sway bar endlinks.
Old 04-02-2022, 03:50 PM   #7
B-R-Z
B-R-Z's Avatar
Where do you get nord locks
Will steel lock washers not work?
Old 04-02-2022, 04:12 PM   #8
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
Online for nord locks. Spring lock washers don’t hold well for long.
Old 04-02-2022, 05:15 PM   #9
B-R-Z
B-R-Z's Avatar
I can't find them top locks. Does this look right?
Bike Boltz 8 Nord Lock 5/16" M8 8mm Vibration Proof Lock Washer - Tension Tighting Fasteners https://www.amazon.com/dp/B016C5AZVU...ing=UTF8&psc=1
Old 04-02-2022, 05:33 PM   #10
dragoontwo
dragoontwo's Avatar
Drives: 22 BRZ limited
No. You want 10mm for the header. Just checked a bolt with a header nut.
The Following User Says Thank You to dragoontwo For This Useful Post:
NoHaveMSG (04-02-2022)
Old 04-02-2022, 05:34 PM   #11
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
Those will work.
Old 04-02-2022, 06:00 PM   #12
B-R-Z
B-R-Z's Avatar
Does an 8mm bolt need 2 mm of extra space?
Old 04-02-2022, 06:02 PM   #13
dragoontwo
dragoontwo's Avatar
The studs on the head are 10mm, not 8mm. Other exhaust hardware, idk.
Old 04-02-2022, 06:23 PM   #14
B-R-Z
B-R-Z's Avatar
You're referring to the studs on the bottom of the block for the header, correct? Not head studs. Thanks buddy
Toe arms keeps coming loose Butterballz Cosmetic Modification (Interior/Exterior/Lighting) 1 07-15-2018 01:37 AM
Endlink nuts keep getting loose BlackNBlue Suspension | Chassis | Brakes -- Sponsored by 949 Racing 10 12-06-2017 12:12 AM
Grill keeps coming loose Vicgbbjj Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 2 12-03-2017 09:30 PM
Spec d spoiler keeps coming loose select20 Cosmetic Modification (Interior/Exterior/Lighting) 3 10-23-2015 12:28 PM
Red stitching is coming loose. Chip Issues | Warranty | Recalls / TSB 7 11-01-2012 10:02 AM
