Old 04-01-2022, 06:09 PM   #1
Skylerkma
Drives: 2016 frs
Angry Cam plate leak challenge
Alright time to get some help from the pros. So I bought a frs for a crazy good price. I knew something had to be wrong with it. After about 200 miles the cam plate started to leak. No big deal until I notice the top bolt is missing. And not just missing. The last owner snapped the piece of the motor off that had the threads for the top bolt to go into. Then it’s gets worse. The lower left bolt had half of its threads broken off. Grabbed a longer bolt from Home Depot that could reach the threads that are left and actually be torqued to spec. After pulling the cam plate off I can tell that they have had some trouble with it. It appears they have had leaks atleast 3 other times( I could tell just because of the different colors rtv’s used). Anyways it’s has a raceseng cam plate installed. No o-ring. So I contacted raceseng and they were nice enough to send me an o-ring. While I wait I figured I would just try some rtv and see if I could get lucky and get it to seal. No luck.. only made it 50 miles before I saw a slight leak. So once the o-ring comes I’m going to try that. But I have a feeling it’s not going to hold. So my question is. Has anyone taken this to the next level and sealed the hole behind the cam plate with a circular piece of metal. Like a huge washer or something. Obviously this will be my last resort. I’ve just read tons of stories about people not getting this cam plate to seal and I only have 2 of 3 bolts to work with. Any tips or tricks would be appreciated.
https://photos.app.goo.gl/Bd7Y5drxUqcxg9CZ9
Skylerkma is offline   Reply With Quote
Old 04-01-2022, 06:44 PM   #2
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
You talking about the OCV's on the timing cover? Roundish thing with a couple tabs and a plug coming out. On the stock setup there is an o-ring and a nylon backer ring.
Old 04-01-2022, 07:20 PM   #3
Skylerkma
Drives: 2016 frs
No talking about the cam plate. Behind the motor on passenger side of car
Old 04-01-2022, 07:30 PM   #4
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
Okay, I gotcha now. They call it a cam plate but it is actually nothing to do with the cams. It covers a passageway for the PCV.
Edit: Actually I am wrong on that. That covers where the vacuum pump goes for the automatics that is cam driven.
Old 04-01-2022, 08:20 PM   #5
norcalpb
norcalpb's Avatar
What is that big bolt you have the arrow pointing towards?
I’m wondering if you can drill new threads into where that mounting piece is missing.
Old 04-02-2022, 10:27 AM   #6
Skylerkma
Drives: 2016 frs
That’s the bolt I mounted to the block hoping I could mount either wire or hose clamp or something to hold the top of the cam plate where it needs to be. It’s either that or get a welder to weld me a place on the black and tap a knew bolt hole.
The Following User Says Thank You to Skylerkma For This Useful Post:
norcalpb (04-02-2022)
cam, leak, plate, rtv, snapped
Leak after Racseng Cam Plate jpeaslee Issues | Warranty | Recalls / TSB 5 12-06-2022 01:19 AM
Cam Plate Leak Repair Extreme86 DIY (Do-It-Yourself) Guides 52 06-14-2020 11:13 AM
Oil leak, cam plate replaced. Decep Engine, Exhaust, Transmission 4 05-30-2017 08:41 PM
Is Raceseng cam plate really works? No Oil leak yet. skyloran Engine, Exhaust, Transmission 16 06-03-2014 03:04 PM
Raceseng | Cam Plate - Stop your oil leak! Raceseng Groupbuys 63 10-18-2013 03:31 PM
