Go Back   Toyota GR86, 86, FR-S and Subaru BRZ Forum & Owners Community - FT86CLUB > 2nd Gens: GR86 and BRZ > BRZ Second-Gen (2022+) — General Topics
BRZ Second-Gen (2022+) — General Topics General topics for the second-gen BRZ
Old 03-26-2022, 10:28 AM   #295
scuzzy
Drives: 22 BRZ limited MT
Originally Posted by Robotaz View Post
Try pushing the middle of the dash down up at the windshield and see if it stops. If it does I at least have a partner to help me figure out
Gave this a try and no change. Definitely the right front side reverberates through the dash only on rough surfaces (rpm not a factor). It may be time to make this the dealer's problem.
scuzzy is offline   Reply With Quote
Old 03-26-2022, 11:23 AM   #296
Robotaz
Drives: 2022 GR86 Premium
Yes but I don’t have a local dealer and don’t have time to be dropping the car off an hour away and not having the car for days over a rattle. Pretty ticked off. All cars rattle way too much now other than F150s and most Hondas. The rest drive me nuts. And this is T even going into the stereo rattles from bass apparently coming from all of the speakers. Sounds like a 1980 Kraco special from Big Lots, if you’re old enough to know how bad that is.
Thankfully the road noise is so awful it drowns most the rattles out. Now that it’s warming up I roll the windows down and generally don’t hear it all, but when it rains and I’m driving very far the dash rattle drives me crazy.
Robotaz is offline   Reply With Quote
Old 03-29-2022, 11:30 AM   #297
scuzzy
Turns out my windshield isn't fully sealed causing the ticking sound which is reverberating through the dash.
Old 03-29-2022, 04:28 PM   #298
AK2112
AK2112's Avatar
Drives: 22 BRZ
How did you figure that out? I just started getting a pretty hollow plastic tick from the center of the dash near the windshield.
AK2112 is offline   Reply With Quote
The Following User Says Thank You to AK2112 For This Useful Post:
Yoshoobaroo (03-29-2022)
Old 03-29-2022, 09:02 PM   #299
Lemming
Drives: 2022 GR86 - Halo White
Turn stalk is defective after 380 miles. It will no longer do 3-blink with a soft press for lane change.
Lemming is offline   Reply With Quote
Old 03-29-2022, 10:18 PM   #300
jvincent
jvincent's Avatar
I have mine turned off, but is that one of the settings that gets reset when the head unit resets?
Assuming you use it, did the gear indicator stop working?
The Following User Says Thank You to jvincent For This Useful Post:
DocWalt (03-30-2022)
Old 03-30-2022, 09:07 AM   #301
Desertnate
Spelling Impaired
Drives: 2022 BRZ Limited WR Blue
Do you have an leaks when washing the car or driving in the rain?
Desertnate is offline   Reply With Quote
Old 03-30-2022, 10:00 AM   #302
scuzzy
I started gently tapping around the edge of the windshield outside the car and near the lower right corner I heard clicking. I used a piece of foam insulation cut down and wedged it between the frame and the glass and went for a drive and the dash vibration was gone. So now I will get it into the dealer and ask them to remedy the problem.
No leaking from rain or car wash.
Old 03-30-2022, 12:30 PM   #303
otter
Drives: 22 BRZ
I don't think this warrants its own thread so posting here - anybody figure out a solution for routing a USB cable from the center console to somewhere useful? I'm about to rip it out and start drilling holes, hate having the cable sticking out of the clamshell doors and phone gets too hot sitting in the console with the cover closed.
otter is offline   Reply With Quote
Old 03-30-2022, 01:07 PM   #304
Interceptor777
Interceptor777's Avatar
Drives: 2022 BRZ, 1999 "touge-spec" Miata
Get wireless dongle for either Carplay or AA, there are products for both.
This is the best solution I've found. I also have a fast charger in my glovebox for when I need to charge the phone. End result is no visible cables unless I need to charge.
Interceptor777 is offline   Reply With Quote
Old 03-30-2022, 01:21 PM   #305
Yoshoobaroo
TRACKBREAD
Yoshoobaroo's Avatar
I have yet to find a CarPlay adapter that works well. I’ve tried 3 and none of them connect reliably for more than a week.
Old 03-30-2022, 02:03 PM   #306
otter
Drives: 22 BRZ
Yeah, every AA wireless adapter I've found has pretty bad review feedback, it's kept me from going that route. I'm likely going to drill a hole inside the console and route a USB cable to somewhere more useful/out of the way.
Old 03-30-2022, 02:24 PM   #307
dragoontwo
dragoontwo's Avatar
The Motorola MA1 has been pretty good for me. The only issue is being able to get one at MSRP.
Old 03-30-2022, 02:33 PM   #308
mr.whiskers
Drives: '22 BRZ
A guy in the other thread did this:
https://www.ft86club.com/forums/show...&postcount=790
mr.whiskers is offline   Reply With Quote
The Following User Says Thank You to mr.whiskers For This Useful Post:
otter (03-30-2022)
Anyone not buying to avoid early issues like 1st gen FRS? stocktc1 GR86 General Topics (2nd Gen 2022+ Toyota 86) 203 09-23-2021 09:11 PM
Buying an early build in the fall, but some issues with these cars are worrying me... RyMi BRZ First-Gen (2012+) — General Topics 34 02-27-2019 08:56 PM
New 2014s still have early issues? Prospective buyer Lord09 Issues | Warranty | Recalls / TSB 25 06-14-2014 04:42 AM
Early problems - speaker rasp and long turnover Hawaiian Issues | Warranty | Recalls / TSB 44 08-30-2013 04:39 PM
Initial Issues / Problems JDMSushi AUSTRALIA 56 09-30-2012 10:21 PM
