03-17-2022, 11:29 AM | #23577 |
Drives: 2017 Toyota 86 (860 SE)
Mounted up my new Avid AV6s with Conti DWS06 in 245/40/17. I think they look just about right!
03-17-2022, 02:26 PM | #23578 |
Pavement Grey
Drives: 2020 Toyota 86 GT, 2017 BMW X1
The Following User Says Thank You to Sasquachulator For This Useful Post: | soundman98 (03-17-2022) |
03-17-2022, 02:38 PM | #23579 | |
The Following User Says Thank You to Tcoat For This Useful Post: | soundman98 (03-17-2022) |
03-21-2022, 11:04 AM | #23580 |
Drives: 2014 FRS
Did a correction and graphene sealant on the paint and vapor steamed the engine bay.
The Following 7 Users Say Thank You to mrchristopher For This Useful Post: | Kaotic Lazagna (03-29-2022), MJones_RB (03-21-2022), new2subaru (03-21-2022), RToyo86 (03-21-2022), SuperTom (03-21-2022), The Red One (03-22-2022), Wally86 (03-21-2022) |
03-21-2022, 12:49 PM | #23581 |
Be Kind
Drives: 2020 86
Which steamer do you use? How do you like it?
03-21-2022, 01:20 PM | #23582 |
Drives: 2014 FRS
I have a Chief Steamer. The advantage to this one over the previous one I had is that this one uses tap water instead of distilled due to the heating element being on the outside of the boiler.
https://chiefsteamer.com/product/chi...steam-cleaner/ |
The Following User Says Thank You to mrchristopher For This Useful Post: | Wally86 (03-21-2022) |
03-21-2022, 11:47 PM | #23583 |
Drives: '13 FR-S Firestorm
So I've had a code on this car (p0420) for the past week. I bought a used oem header (10k miles) to replace the cat.
Replaced the header, and the CEL went away as I started the car. The previous owner double gasketed the header to overpipe connection.... not sure if that was causing the code (it's right after the downstream o2)..or if the cat was truly bad. The header that was on there itself didn't have any of the heat shields on it, nor did it have original hardware. Stud seems to be re-welded on, and fastened on with random nuts... I gotta say reinstalling a stock header was quite annoying because of the studs. I first dropped the front pipe, then disconnected the overpipe from the front pipe and that finally did it. I can see how people install aftermarket headers easier because of the lack of studs on them. |
The Following 4 Users Say Thank You to FSFRS For This Useful Post: |
03-23-2022, 06:35 AM | #23584 |
Drives: English, French, Swedish & Japanese
WHAT DID YOU DO TO YOUR FRS TODAY?
Drove it 1200km today. She did great on the Highway, 3 on board and all our luggage
The Following 4 Users Say Thank You to ACT86 For This Useful Post: |
03-23-2022, 07:43 AM | #23585 |
Drives: 17 Asphalt 86
Ordered a resonated catless front pipe, and going back to stock catback.
Wild times when all I can find are basically knockoff brands of stuff that's now discontinued Edit: that was discontinued as well. Just found out FT86MS is about to release a buildable front pipe. Going to be ordering a dual resonated setup as one of their first orders. Last edited by RToyo86; 03-23-2022 at 03:03 PM. |
The Following User Says Thank You to RToyo86 For This Useful Post: | Wally86 (03-23-2022) |
03-24-2022, 05:44 PM | #23586 |
Drives: 2013 Scion FR-S 10 Series
100k
The Following 11 Users Say Thank You to Cedric For This Useful Post: |
03-25-2022, 11:41 AM | #23587 |
Got an alignment today. I was surprised at how little the front was affected after installing RCE Yellows with 2020 shocks. Everything was still in spec. Surprised at ow little camber the fronts have from the factory. It's sitting at 0.2 degrees. I tried to add camber bolts, but the wheel started hitting the strut... lol.
My rear end is all out of whack though, one side is in spec, and the other side had like .30 degrees of toe, along with -2.5 degrees of camber lol. Didn't think I'd need LCAs but I guess I'll have to buy them. Also added a duckbill, full replica STI kit, and replica TRD garnishes which you can kinda see in the photos. Not sure how I feel about the garnishes, to be honest.. I can't find any c7p subaru garnishes. I'd have to repaint a 2017+ garnish c7p to complete the exterior conversion to BRZ. |
03-25-2022, 12:22 PM | #23588 | |
Lower offset wheels fix that issue, or you can go the route I did and add some ARP extended wheel studs with a slip on spacer. The 2.5" can be installed on the rear without roving the hub(with minor trimming to the nipple at the end) |
The Following User Says Thank You to RToyo86 For This Useful Post: | FSFRS (03-25-2022) |
03-25-2022, 01:11 PM | #23589 |
Meow
Drives: GT86, Volvo 996
03-25-2022, 02:48 PM | #23590 | |
I can see the duckbill in the rear view but doesn't really affect visibility any more than the third brake light does. I'm sure the TRD one doesn't affect it at all. This one is the legsport style one. |
The Following User Says Thank You to FSFRS For This Useful Post: | RToyo86 (03-29-2022) |
Tags |
:popcorn:, :popcorn: funny tags, nsfc, rice rice baby |
Similar Threads | ||||
Saw My First FR-S Today | Marrk | Scion FR-S / Toyota 86 GT86 General Forum | 26 | 05-15-2013 12:40 PM |
Got My Car Today!!!!! First 86!! #81 | Juanito08 | Scion FR-S / Toyota 86 GT86 General Forum | 7 | 05-22-2012 04:54 PM |
If my FRS was here already, today I would... | bestwheelbase | Scion FR-S / Toyota 86 GT86 General Forum | 101 | 05-12-2012 06:20 PM |
Sat in a FRS today!! | Ladnerd | Scion FR-S / Toyota 86 GT86 General Forum | 12 | 04-30-2012 01:48 PM |
Got my VIN today... | Enemies | BRZ First-Gen (2012+) -- General Topics | 63 | 04-12-2012 10:19 PM |
