Old 03-11-2022, 10:15 PM   #23549
soundman98
ProCrastinationConsultant
soundman98's Avatar
Oh but think of the exchanges at Kia dealers
"Hi I saw one of your sports cars the other day and would like more info"
"Oh yes sir the Stinger is right over here"
"No not that one. The small two door coupe"
"You mean the Forte? They don't make those anymore"
"No I mean the lower sleeker coupe"
"I have no clue what you are talking about"
"Well it clearly said KIA on the badge"
knowing kia dealers near me(the nearest is famous for the "lost the keys" game), i'd park a block away at the hardware store, they'd find a way to sell the car out of that lot, and i'd come out to an empty parking spot.
Old 03-17-2022, 11:29 AM   #23550
Cephas
Cephas's Avatar
Drives: 2017 Toyota 86 (860 SE)
Mounted up my new Avid AV6s with Conti DWS06 in 245/40/17. I think they look just about right!
Cephas is offline   Reply With Quote
The Following 4 Users Say Thank You to Cephas For This Useful Post:
JD001 (03-21-2022), MJones_RB (03-18-2022), SuperTom (03-17-2022), Wally86 (03-17-2022)
Old 03-17-2022, 02:26 PM   #23551
Sasquachulator
Pavement Grey
Or go all out and really mess with people!
the koreans are good at copying others, without outright copying others (unlike the chinese, who blatantly copy and just dgaf)
The Following User Says Thank You to Sasquachulator For This Useful Post:
soundman98 (03-17-2022)
Old 03-17-2022, 02:38 PM   #23552
The Japanese are not real creative either then.
Old 03-21-2022, 11:04 AM   #23553
mrchristopher
mrchristopher's Avatar
Drives: 2014 FRS
Did a correction and graphene sealant on the paint and vapor steamed the engine bay.
mrchristopher is offline   Reply With Quote
The Following 7 Users Say Thank You to mrchristopher For This Useful Post:
Kaotic Lazagna (03-29-2022), MJones_RB (03-21-2022), new2subaru (03-21-2022), RToyo86 (03-21-2022), SuperTom (03-21-2022), The Red One (03-22-2022), Wally86 (03-21-2022)
Old 03-21-2022, 12:49 PM   #23554
Wally86
Be Kind
Wally86's Avatar
Drives: 2020 86
Which steamer do you use? How do you like it?
[Insert clever signature here]
IG | WhiskyBlog | Photography
Wally86 is offline   Reply With Quote
Old 03-21-2022, 01:20 PM   #23555
mrchristopher
Drives: 2014 FRS
I have a Chief Steamer. The advantage to this one over the previous one I had is that this one uses tap water instead of distilled due to the heating element being on the outside of the boiler.
https://chiefsteamer.com/product/chi...steam-cleaner/
The Following User Says Thank You to mrchristopher For This Useful Post:
Old 03-21-2022, 11:47 PM   #23556
FSFRS
Drives: '13 FR-S Firestorm
So I've had a code on this car (p0420) for the past week. I bought a used oem header (10k miles) to replace the cat.
Replaced the header, and the CEL went away as I started the car.
The previous owner double gasketed the header to overpipe connection.... not sure if that was causing the code (it's right after the downstream o2)..or if the cat was truly bad.
The header that was on there itself didn't have any of the heat shields on it, nor did it have original hardware. Stud seems to be re-welded on, and fastened on with random nuts...
I gotta say reinstalling a stock header was quite annoying because of the studs. I first dropped the front pipe, then disconnected the overpipe from the front pipe and that finally did it. I can see how people install aftermarket headers easier because of the lack of studs on them.
FSFRS is offline   Reply With Quote
The Following 4 Users Say Thank You to FSFRS For This Useful Post:
MJones_RB (03-22-2022), RToyo86 (03-23-2022), Ultramaroon (03-23-2022), Wally86 (03-23-2022)
Old 03-23-2022, 06:35 AM   #23557
ACT86
ACT86's Avatar
Drives: English, French, Swedish & Japanese
WHAT DID YOU DO TO YOUR FRS TODAY?
Drove it 1200km today. She did great on the Highway, 3 on board and all our luggage
ACT86 is offline   Reply With Quote
The Following 4 Users Say Thank You to ACT86 For This Useful Post:
Dadhawk (03-23-2022), RToyo86 (03-23-2022), Ultramaroon (03-23-2022), Wally86 (03-23-2022)
Old 03-23-2022, 07:43 AM   #23558
RToyo86
RToyo86's Avatar
Drives: 17 Asphalt 86
Ordered a resonated catless front pipe, and going back to stock catback.
Wild times when all I can find are basically knockoff brands of stuff that's now discontinued
Edit: that was discontinued as well. Just found out FT86MS is about to release a buildable front pipe. Going to be ordering a dual resonated setup as one of their first orders.
The Following User Says Thank You to RToyo86 For This Useful Post:
Old 03-24-2022, 05:44 PM   #23559
Cedric
Cedric's Avatar
Drives: 2013 Scion FR-S 10 Series
100k
Cedric is offline   Reply With Quote
The Following 11 Users Say Thank You to Cedric For This Useful Post:
ACT86 (03-25-2022), BigHugeFatGuy (04-02-2022), Dadhawk (03-24-2022), jcw99 (03-25-2022), JD001 (03-29-2022), Jdmjunkie (03-24-2022), kevaughan (04-08-2022), MJones_RB (03-25-2022), Nails (03-25-2022), soundman98 (03-24-2022), weederr33 (03-27-2022)
Old 03-25-2022, 11:41 AM   #23560
FSFRS
Got an alignment today. I was surprised at how little the front was affected after installing RCE Yellows with 2020 shocks. Everything was still in spec. Surprised at ow little camber the fronts have from the factory. It's sitting at 0.2 degrees. I tried to add camber bolts, but the wheel started hitting the strut... lol.
My rear end is all out of whack though, one side is in spec, and the other side had like .30 degrees of toe, along with -2.5 degrees of camber lol. Didn't think I'd need LCAs but I guess I'll have to buy them.
Also added a duckbill, full replica STI kit, and replica TRD garnishes which you can kinda see in the photos.
Not sure how I feel about the garnishes, to be honest.. I can't find any c7p subaru garnishes. I'd have to repaint a 2017+ garnish c7p to complete the exterior conversion to BRZ.
The Following 3 Users Say Thank You to FSFRS For This Useful Post:
RToyo86 (03-25-2022), SuperTom (03-28-2022), Wally86 (03-25-2022)
Old 03-25-2022, 12:22 PM   #23561
RToyo86
RToyo86's Avatar
McPherson struts suck for camber. You effectively lose camber as the suspension goes through its compression stroke.
Lower offset wheels fix that issue, or you can go the route I did and add some ARP extended wheel studs with a slip on spacer.
The 2.5" can be installed on the rear without roving the hub(with minor trimming to the nipple at the end)
FSFRS (03-25-2022)
Old 03-25-2022, 01:11 PM   #23562
alex87f
Meow
alex87f's Avatar
Drives: GT86 (now sold)
I'm generally not a fan of duckbills, but in this case it works perfectly . Better than on gen 2s, even. I'd just lightly tint the reverse light, either in red or gray.
Does the duckbill affect rear visibility at all?
alex87f is offline   Reply With Quote
