Old 03-19-2022, 05:31 AM   #1
Theodorable
Drives: 2015 Scion Frs
Fitment help needed
Ok so I’m planning to buy 18x9.5 35 offset wheels for my 86 the standard/most common fitment for this platform. I was wondering if I needed LCA or anything to run this fitment. Because I want to just slap these boys on and camber them for the flush fitment. If I need to get my fenders rolled then that’s fine but I want to know if I needed anything else for suspension to run this fitment. Does coilovers and camber do the job. Or do I need more?
Theodorable is offline   Reply With Quote
Old 03-19-2022, 08:43 AM   #2
x808drifter
LMGTFY
x808drifter's Avatar
Drives: 13 FRS, 91 Miata
Not sure if troll post or not.
If not...
The Following User Says Thank You to x808drifter For This Useful Post:
NoHaveMSG (03-19-2022)
Old 03-19-2022, 03:35 PM   #3
Theodorable
IM NOT TROLLIN LOL IM NEW TO wheels and stuff so I really don't know. This is my first car as well. From most examples i see they dont need it and if you have coilovers you have enough clearance without having to worry about rubbin unless you go lower then 1 inch. But i wanted confirmation cause I don't want to fuck up. I'm not ashamed for not knowing this info because I'd rather be clowned then fucking it up lol.
The Following User Says Thank You to Theodorable For This Useful Post:
humfrz (03-21-2022)
Old 03-19-2022, 04:51 PM   #4
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
That is not the most common aftermarket wheel size, the most common is 17X9 by far. The reason for coils is with wide tire/wheel combinations you may end up with rubbing in the front as the spring and perch on the stock strut is pretty wide and coilovers have a much narrower spring and perch. It may fit depending on tire size. 17X9 is already tight with a 245 tire. There are sticky threads in the wheel/tire section that have pictures and specs of what people have done.
Old 03-19-2022, 05:36 PM   #5
Theodorable
Do you think you can send a link for that thread you mentioned?
Old 03-19-2022, 05:41 PM   #6
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
There are two with lots of pictures, detail. Your answer may take some digging though I am sure there are others with this setup that can chime in.
https://www.ft86club.com/forums/showthread.php?t=15007
https://www.ft86club.com/forums/showthread.php?t=7535
Old 03-21-2022, 02:16 AM   #7
Well now, Theodorable, I commend you on being a good sport -
It is good to ask questions, since you are new to cars and this platform. -
My recommendation is to leave the wheels and suspension alone, ain't nutten wrong with the way it came out of the box. just maybe change the tires, depending on what you want the car to do better -
The Following 4 Users Say Thank You to humfrz For This Useful Post:
Jdmjunkie (03-21-2022), Wally86 (03-24-2022), x808drifter (03-21-2022), Yoshoobaroo (03-21-2022)
Old 03-24-2022, 12:34 AM   #8
gabe.rivas1323
Drives:
I have 18x9.5 +38 RPF1’s with 255/35/18 federal tires all around and it’s I’m sure if I get sweaty and rolled fenders and some spacers I could get cleaner fitment but it’s perfect for me right now. You do need coil overs though the stock ones are too big and will rub on aftermarket wheels.
gabe.rivas1323 is offline   Reply With Quote
Not needed Clutch Dog Want-To-Buy Requests 0 06-24-2019 05:05 PM
How's the fitment of 1320's dual res fp fitment on AT aznchris Engine, Exhaust, Transmission 0 04-16-2019 07:02 AM
Assistance needed w/ wheel fitment. assistanceNeeded. Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 8 05-01-2014 02:06 AM
San Antonio, TX BRZ needed for clear bra template fitment switchlanez Southwest 4 08-06-2012 10:10 PM
Official wheel/tire fitment thread needed empower-auto Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 4 06-22-2012 02:40 AM
