Drives: the blue one
Assistance needed w/ wheel fitment.
Would one be able to fit staggered rpf1s
(17x9 front; 17x10 rear) offset around 35-38. Would one need spacers? roll fenders? Or any other modifications needed for the wheels to fit without rubbing. (functionally, not doing it for stance) Thank you guys. Any and all information, regarding my question, is greatly appreciated! |
KCCO From Canada
Drives: Asphalt FRS
fronts would fit fine, not sure about the rears.
Drives: RB v1 FRS
depends on tire size and the height you are at...
yea. I've been reading around, saw people fitting 17x9 no problem. Idk about x10 still.
what aspect ratio? not that i have the answer but its an important consideration. if you are doing it for looks then you can probably make it work. if you are doing it for performance, i would advise against it.
Slower than Fast
Drives: BRZ Limited 6MT
I've never seen RPF1's in 10 inch width with 5x100 bolt pattern. Are you planning to use an adapter?
Just the tip
Drives: 2013 Lightning Red Subaru BRZ Mt Lt
Everything I've read says you'll rub in front if you are close to et42 and use stock suspension with the extra camber you'll get from the springs. et35 would probably fit but they will poke out too much aka won't be flush. Go with 17x8 et 35 instead. Tons of room for big break kits and no one will know they aren't 17x9, especially if you put 235 or even 245 tires on them.
Current: 2013 Lightning Red Subaru BRZ Limited
Past (sold): Click here to see previous cars and bikes ![]() |
| Boynton Beach, FL Area Assistance needed | akuhei | Southeast | 15 | 10-02-2013 01:53 PM |
| Wheel Directory: MM6 Mesh 18x8.5 +38 / 18x9.5 +40 | ModBargains.com | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 21 | 03-14-2013 05:13 PM |
| San Antonio, TX BRZ needed for clear bra template fitment | switchlanez | Southwest | 4 | 08-06-2012 09:10 PM |
| Official wheel/tire fitment thread needed | empower-auto | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 4 | 06-22-2012 01:40 AM |
| Wheel fitment | sfwg | BRZ First-Gen (2012+) — General Topics | 6 | 10-28-2011 06:33 PM |
