Go Back   Toyota GR86, 86, FR-S and Subaru BRZ Forum & Owners Community - FT86CLUB > 2nd Gens: GR86 and BRZ > BRZ Second-Gen (2022+) — General Topics
BRZ Second-Gen (2022+) — General Topics General topics for the second-gen BRZ
Old 03-22-2022, 09:01 AM   #729
Stonehorsw
Stonehorsw's Avatar
Drives: 18 Brz (Sold) / 22 BRZ / 13 BRZ
Replaced pads (from Stock to Power Stop), Brake Fluid (RBF600) and Wheels/Tires (From 13 Brz 17” wheel with Blizzaks to 22 Brz 18” with PS4).
First time really driving on PS4 as picked the car in December and was on winter tires until now, noise level reduced a lot, also, feeling improved.
Stonehorsw is offline   Reply With Quote
The Following User Says Thank You to Stonehorsw For This Useful Post:
PBR (03-24-2022)
Old 03-22-2022, 09:28 AM   #730
des
des's Avatar
RPF1s, 225 Yoks, and swapped the 22mm Perrin for the 19. Here's why:
des is offline   Reply With Quote
The Following User Says Thank You to des For This Useful Post:
DocWalt (03-22-2022)
Old 03-22-2022, 05:50 PM   #731
azndavepgh
Drives: 2022 BRZ
So I guess the Blizzaks are pretty loud? How's the noise level for the PS4s in general?
azndavepgh is offline   Reply With Quote
Old 03-22-2022, 07:00 PM   #732
Stonehorsw
Stonehorsw's Avatar
Ps4. Blizzaks are loud and were wining in a weird way (a subtle metallic sound from the threads distortion and maybe a stick-slip situation). PS4 are good, granted that I checked pressure today and they came overinflated (about 39-40 psi), I will regulate pressure and see if makes difference
Other thing, fuel consumption improved from 24 to 28 mog on same commute, again, will check with correcr pressures
Old 03-22-2022, 07:42 PM   #733
Lelandjt
Drives: '04 STi, '12 Mazda 3 Hatch
Originally Posted by Panda Grahams View Post
Finally, past the break-in period! The car is amazing above 5k; really fun tying corners together in the higher revs.
I only put about 1000mi a summer on the car this is replacing and I might only be keeping it one summer. I don't think I'll be able to wait more than 200mi before fully enjoying the engine. Is break in supposed to be 500 or 1000mi?
It just occured to me that the average person doesn't do any break in with their new car and Kelly Blue Book doesn't ask when selling used, so....
Lelandjt is offline   Reply With Quote
Old 03-22-2022, 07:54 PM   #734
Robotaz
Drives: 2022 GR86 Premium
My heads knock until the engine is warm when the ambient temp is under 50 F in the morning. I babied it to 1000 miles. Sounds fine when warm. I don’t know if it’s normal or not, but I would recommend under 4K for the first 1,000 miles like the manual instructs. Do you not own a user manual?
Robotaz is offline   Reply With Quote
Old 03-22-2022, 07:57 PM   #735
Lelandjt
I expect I'll own a user manual when my car arrives around May 20th. Then again, the dealer still isn't very confident it will arrive. Ordered in November as soon as they were able to take an order.
Old 03-23-2022, 12:15 AM   #736
Panda Grahams
Panda Grahams's Avatar
Drives: '22 BRZ
There's no gospel. It's your car; drive it how you like! The manual does quote a 1000 mile "break-in", staying under 4k during that period, and not "racing the engine." I don't put a lot of miles on my car, either, working from home. I went on a few long drives and burned through the break-in over a few weekends. Again, no gospel on this, but I chose to change the oil afterwards and inspect the filter. Peace of mind has a different value to everyone, you do you. This engine is one of my favorites to rev out, so I couldn't blame you.
Panda Grahams is offline   Reply With Quote
Old 03-23-2022, 09:21 AM   #737
ozafar
Drives: 2015 Scion FRS Release Series 1.0
I made it to 425 miles under 4k before I lost my patience, I’m flooring it all the time now
ozafar is offline   Reply With Quote
Old 03-23-2022, 09:49 AM   #738
PBR
PBR's Avatar
Drives: 2022 BRZ Limited 6 speed manual
Had this Real steering wheel installed. Love it. The installer said it was simple with 0 issues. Pretty much the same as gen 1. No misalignment. Took about an hour. Duracon shift knob arrives today. Also really enjoying the Swift Spec R/Bilstein B8 combo. 6 month wait on TWS T66-F 18x8s
PBR is offline   Reply With Quote
The Following 3 Users Say Thank You to PBR For This Useful Post:
22 BRZ (03-23-2022), rawpoly (03-23-2022), Re_Invention (03-23-2022)
Old 03-23-2022, 10:37 AM   #739
danson
Drives: 22 brz
I just picked up my gen2 a week ago and my steering wheel seems to be tilted to the right by 5 degrees or so. Is this a quick fix? Should I take it to a dealer?
danson is offline   Reply With Quote
The Following User Says Thank You to danson For This Useful Post:
PBR (03-23-2022)
Old 03-23-2022, 11:40 AM   #740
DocWalt
DocWalt's Avatar
Drives: '22 BRZ
Easy fix, any alignment shop can handle it Mine was off too, you just need the front toe fixed (though I'd suggest having the entire car aligned as my car's alignment was not very good)
The Following User Says Thank You to DocWalt For This Useful Post:
PBR (03-23-2022)
Old 03-24-2022, 01:39 AM   #741
diga
Drives: 2022 Subaru BRZ Limited 6MT
Originally Posted by mr.whiskers View Post
Did mine today.. exactly same thoughts, don't really feel any difference but the slop at the top is kinda annoying.
Overall I don't think its worth the $50cad and like an hour lying on my back in the footwell.. also lost that small c clip while trying to put it back on, so now I gotta figure out where to find one
Debating on just putting back the old spring, but thats gonna be even harder now because the stock one is quite stiff not sure i ll be able to compress it enough with zip ties
yea I put the stock spring back in, the slop was bothering me too much! I will say it was kind of a pain the get the stock one back in! get some strong zip ties and use a clamp to compress it.
diga is offline   Reply With Quote
Old 03-24-2022, 08:00 AM   #742
Lelandjt
I thought the aftermarket lighter spring eliminated the slop that occurs with no spring. Damn. So he only way to have no slop is leave the stock spring alone?
WHAT DID YOU DO TO YOUR FRS TODAY? KalbiCool88 Scion FR-S / Toyota 86 GT86 General Forum 1 11-04-2015 10:36 PM
Do you know what today is? Yruyur Off-Topic Lounge [WARNING: NO POLITICS] 26 01-21-2015 02:51 PM
just got my OFT today...help please! carlitosway6891 Software Tuning 9 02-20-2014 10:05 PM
TODAY, TODAY, I GET IT TODAY!!!! :D Trashed675 Scion FR-S / Toyota 86 GT86 General Forum 54 02-14-2013 01:16 AM
