#15 |
Fast sweepers when I can keep the throttle pinned while running at the limits of adhesion with only small corrections to the wheel.
Bonus points if I end up with similar front/rear slip angles putting the car into neutral 4-wheel drift. |
#16 |
Famous Potatoes
Drives: '15 ultramarine
Only time I ever dnf, and exit bad on a track was turn 6 at Laguna (now 8). Pucker every time I drove it. It was best because it was the most challenging, you hit it just right at speed and it was like catching the perfect wave, hitting the best drive, kissing the girl you love for the first time. Awesome!
| The Following 3 Users Say Thank You to Sapphireho For This Useful Post: |
#17 | |
Drives: 14 FRS Monogram, 05 Mazdasped Miata
I found this track map and description from my old NNJR PCA chapter. It's a good primer for anyone intending to run the Glen. https://nnjr-pca.com/wp-content/uplo...rn-by-Turn.pdf The Bus Stop was a good addition because so many people got in trouble in T5 after a long fast straight. NNJR usually ran the Glen twice a year both three-day events. PCA zone one had another three-day event, usually over Fourth of July, so we got about nine days a year at the Glen. |
#18 |
Drives: Crapcan
I noticed that too and thought it was strange. Up here you need at least a check ride to sign you off that you are safe to drive solo.
#19 |
Drives: Miata
#20 |
Drives: 2022 GR86
Among the ones I've driven in real life, it's definitely T6 at Laguna Seca.
Camber, pitch change, dip at the apex, long uphill straight to climb up against if you mess up the corner and lose the momentum... As it's 70+ mph even on GT Radial SX2's, my heart always misses a bit when I approach it. "That's Raidillon actually" |
#21 | |
Drives: Miata
Masta Kink at Spa, old track.
A mile and a half flat out leading into it and a mile after. Quote:
Ickx in an Alfa Romeo T33TT/12, about 200 mph through the Masta Kink at Spa
#22 |
Drives: Fr-s
My personal fav, is Road America turn 13. It's flat (in a 86), blind exit and if you get far enough into the apex curbing it bounces the car for a slight drift. It got less fun after adding aero.
#23 |
If anybody ever figures out 17 at Sebring please let me know because I sure haven't. Every time I enter 1 at Sebring I think I'm going to die, but when I clear the wall and get a look down the track I always say to myself I could've gone faster. 2 is just a little kink, and you can go deep into 3 before braking because the track surface is a little uphill.
#24 | |
Drives: 2023 BRZ
Too bad so few of you guys know the Colorado tracks. There are some pretty cool turns here. One of them is at La Junta, going 100 mph while at the edge of lateral grip. Then, mid-turn, you hit an old runway that crosses the track. It is elevated, essentially forming a jump. If done right you can get airborne. Then, as soon as you land you need to threshold brake to make the following turn. It is, um....exciting. I think more of you guys need to make guest appearances in Rocky Mountain 86CUP.
Director of Rocky Mountain 86CUP
| The Following User Says Thank You to Pat For This Useful Post: | timurrrr (03-15-2022) |
#25 | |
Drives: Crapcan
Not at these gas prices.
#26 |
Drives: 2013 Subaru BRZ
My experience is limited but since I live near Mid-Ohio my favorite is probably Madness.
| The Following User Says Thank You to RT-BRZ For This Useful Post: | NoHaveMSG (03-15-2022) |
#27 | |
Drives: 2022 BRZ Limited on order
| The Following User Says Thank You to Angrypuppy For This Useful Post: | NoHaveMSG (03-18-2022) |
#28 |
Drives: Crapcan
| The Following User Says Thank You to NoHaveMSG For This Useful Post: | NickSpaghetti (03-23-2022) |
| Car losing traction in corners | Chase1996 | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 82 | 03-06-2016 07:50 PM |
| Corners, corners, corners :-) | Artalos | BRZ Photos, Videos, Wallpapers, Gallery Forum | 4 | 06-23-2015 12:27 AM |
| Decreasing radius corners | ZionsWrath | Other Vehicles & General Automotive Discussions | 48 | 11-11-2013 07:34 PM |
| FS: OEM Clear Corners for FR-S | OCFR-S | Exterior Parts (Aero, Lighting, Etc.) | 2 | 11-07-2012 12:07 PM |
| Smoked jdm corners | Jason952 | Cosmetic Modification (Interior/Exterior/Lighting) | 4 | 10-22-2012 12:23 PM |
