| Software Tuning Discuss all software tuning topics. |
Drives: gt86 turbo
ZA1JA01I for setting up a turbo using the Hybrid Speed Density system
Hi all ! I installed a turbine on a GT86 and for several years I have not been able to set up an ECU from ZA1JA01I. I want to ask you for help in obtaining and determining the ROM disk ZA1JA01I for setting up a turbo using the Hybrid Speed Density system
#2 |
Drives: brz 2017 hksv2
Do you have oft then? or tactrix? ican remember if there are available patched A01I with SD tunes around but you should definitely go with ecutek for a SD turbo tune
#3 | |
Drives: gt86 turbo
This is the only turbo gt86 in my area. I set it up for stock rom but I'm not satisfied with the result. The engine is reinforced with pistons, connecting rods and liners, a fuel pump. no access to ecutek. I hope to find definitions and roms more budget than ecutek. I myself am familiar with tuning the ecu motec linkecu CarBerry 16bit Speed Density Project. I have my own dynomax machine. |
| The Following User Says Thank You to mosterjet72 For This Useful Post: | Danny318 (04-22-2022) |
#4 | |
LMGTFY
Drives: 13 FRS, 91 Miata
#5 |
Drives: Toyota GT86
Back in the day, ztan made a tune for his A01G car with Speed Density, flex fuel and was running a turbo. I know Wayno made a port for his A01I car, but as far as I know he only ported the flex-fuel part, not the Speed Density. But you can always contact him,
http://site.wayneroms.com:8000/ But if you want a good tune, you're going to need ECUtek
"Oversteer is when your ass hits the wall, Understeer is when your face hits the wall!" - Unknown Stockcar driver
BeNeLux FB group: GT86/BRZ Owners |
#6 |
Drives: FT86
Only the manual A01G rom was patced by ztan for speed density
if your car is auto A01I then there is no speed density patch available for opensource tuning . You can tune for boost without SD but on a standard diameter maf tube your limited to about 10psi or so before maf maxes out. Then you have two options, use a maf sensor from a wrx\forester turbo car its plig and play will give you about 30% more maf reading ( will need recalibrating) or go to a bigfer maf tube diameter and rescale stock maf sensor for that otherwise if you must have SD your going to need to use ecutek system instead but more expensive |
#7 | |
Drives: Japan
![]() time tracking software recommended site Last edited by Ruuuust; 05-01-2022 at 04:09 PM. |
#8 |
LMGTFY
reported
| Angle sensor not functioning | Schace | Cosmetic Modification (Interior/Exterior/Lighting) | 16 | 02-28-2025 05:17 PM |
| Taillights with hard water spots inside | Jajanken86 | Cosmetic Modification (Interior/Exterior/Lighting) | 9 | 03-31-2017 02:35 AM |
| The All New ATI FR-S/BRZ/FT86 "Triple Meter" Gauge Pod | ATIPods | Interior Parts (Incl. Lighting) | 7 | 09-18-2014 04:14 PM |
| The All New ATI FR-S/BRZ/FT86 "Triple Meter" Gauge Pod | ATIPods | Cosmetic Modification (Interior/Exterior/Lighting) | 16 | 09-18-2014 04:10 PM |
