Go Back   Toyota GR86, 86, FR-S and Subaru BRZ Forum & Owners Community - FT86CLUB > 2nd Gens: GR86 and BRZ > BRZ Second-Gen (2022+) — General Topics
BRZ Second-Gen (2022+) — General Topics General topics for the second-gen BRZ
Old 03-10-2022, 08:15 PM   #1
CluelessPedalMasher
Drives: 2022 BRZ Limited AT White
Repair Advice for Stripped Engine Bay Bolt
I stripped the top of an engine bay bolt installing a strut bar. At this point I have three options. 1st: weld bolt overhang from replacement fender apron to replace both bolts power brace attach to. 2nd: get a tap and die kit as well as some jb weld and rethread the bolt. 3rd: replace whole fender apron myself (gotta see how doable/easy this is). I asked about spot welding a bolt on but the guy at the collision center I talked to said spot welding on new bolt would be tricky, he recommended use tap and die. Any advice?
CluelessPedalMasher is offline   Reply With Quote
Old 03-10-2022, 08:40 PM   #2
soundman98
ProCrastinationConsultant
soundman98's Avatar
seems like a poor choice to go to that shorter bolt of the body stiffener.. most strut bars mount across the actual struts, which typically have much longer studs and allow for accessory mounting.
my method, i would strip off all the stuff that mounts to the stud, run a proper-sized die down the threads, all the way to the bottom, and backwards. from there, i'd soak the die in welding anti-spatter, and then build up the damaged stud threads with a welder, dremel the welds down to create a round stud blank, repeat the first and second step at least 4-5 times, and then work the tap up with some cutting oil to re-tap the threads..
time consuming though. it'd likely be 2/3's-to all of a saturday for me...
Old 03-11-2022, 06:27 AM   #3
Q8D
Drives: N/A
Your options are either what @soundman98 suggested or grind/drill out old stud and weld a new one back onto the tower. I'd go with a new stud if I can find a proper replacement.
Q8D is offline   Reply With Quote
The Following User Says Thank You to Q8D For This Useful Post:
soundman98 (03-11-2022)
Old 03-11-2022, 07:26 AM   #4
Falken86
Falken86's Avatar
Drives: '13 WRB BRZ '22 ISM BRZ Ordered
Not sure how you managed that.. Try and repair the threads or replace
Falken86 is offline   Reply With Quote
Old 03-11-2022, 01:09 PM   #5
Wally86
Be Kind
Wally86's Avatar
Drives: 2020 86
Throwing out a crazy idea for the sake of being different... cut off old bolt, drill it out, rivnut, bolt in the other direction. Maybe.
[Insert clever signature here]
IG | WhiskyBlog | Photography
Wally86 is offline   Reply With Quote
Old 03-11-2022, 09:40 PM   #6
soundman98
soundman98's Avatar
though considering that he's attempting to structurally reinforce the front end with a strut bar, i don't particularly like the idea of a vibrating side-load on a rivnut.
i'll use rivnuts all day on loads that will put an outwards force on them, but i've used a few in perpendicular loading situations, like on pickup truck tailgates for soft-open struts, and they tend to work loose pretty in a matter of months of minimal use.
Wally86 (03-13-2022)
Old 03-12-2022, 03:44 AM   #7
Q8D
Drives: N/A
100%. Tailgate damper on my GMC worked itself loose at the rivnut soon after installation. They suck for that application.
Old 03-14-2022, 11:10 PM   #8
dave99rt
Drives: '22 BRZ
If there is room below the stud (it appears that part has room underneath), remove the damaged stud and install a new rivet stud.
The rivet stud is cheap, the tool to install it is hundreds. Probably best to find a shop that has one. I would call a few restoration and/or fabrication shops. Someone will have the required tools.
You could also grind the bolt partially smooth and die it down to the next size, that might be standard...
Making it smaller/weaker is probably not the preferred setup though.
2022 BRZ
dave99rt is offline   Reply With Quote
Old 03-18-2022, 09:15 AM   #9
CluelessPedalMasher
I will look into this! For now I bought a new nut and washer, gets enough thread to hold on tight
Header and Overpipe stripped bolt toughguy39 Engine, Exhaust, Transmission 11 05-12-2020 03:40 PM
How to remove seat rail bolt after you've stripped it protpibe DIY (Do-It-Yourself) Guides 33 02-01-2020 02:06 PM
Rear bolt stabilizer stripped Trueweltall Suspension | Chassis | Brakes -- Sponsored by 949 Racing 10 07-15-2018 12:51 AM
Stripped Wheel Bolt Flame9020 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 18 03-09-2018 10:09 PM
Wheel bolt stripped 2pointSLOW86 Issues | Warranty | Recalls / TSB 23 10-13-2014 02:29 AM
