Go Back   Toyota GR86, 86, FR-S and Subaru BRZ Forum & Owners Community - FT86CLUB > 2nd Gens: GR86 and BRZ > BRZ Second-Gen (2022+) — General Topics
BRZ Second-Gen (2022+) — General Topics General topics for the second-gen BRZ
Old 03-10-2022, 08:23 PM   #673
Up4speed
Drives: 2023 BRZ Limited
Originally Posted by bobka7914 View Post
Here ya go!
(And photobomb Lulu)
Is that the position that the OEM Subaru bracket sits, or is that the one you drilled, so it sits lower?
Up4speed is offline   Reply With Quote
Old 03-11-2022, 12:42 AM   #674
bobka7914
Drives: ‘22 BRZ, ‘18 Crosstrek
This is the one that I drilled..
bobka7914 is offline   Reply With Quote
The Following User Says Thank You to bobka7914 For This Useful Post:
Up4speed (03-11-2022)
Old 03-11-2022, 05:26 PM   #675
AK2112
AK2112's Avatar
Drives: 22 BRZ
Drove slowly to work in some snow. Not ideal but handled it well.
Then after work, I picked up a mint set of first gen take offs to use in the winter.
Finally, I stopped by the DIY wash just to use the high pressure water to blast off all the salt. Should be 50 this weekend and it will get a proper wash.
AK2112 is offline   Reply With Quote
The Following User Says Thank You to AK2112 For This Useful Post:
MikeNSX2 (03-11-2022)
Old 03-11-2022, 05:45 PM   #676
Midnightsky
Midnightsky's Avatar
Drives: 2022 BRZ WRB
Why drive slow on snow/ice when you could go fast
https://youtube.com/shorts/F1-p1wT8O_g?feature=share
Midnightsky is offline   Reply With Quote
The Following User Says Thank You to Midnightsky For This Useful Post:
AK2112 (03-11-2022)
Old 03-11-2022, 06:04 PM   #677
AK2112
AK2112's Avatar
Drives: 22 BRZ
Man, you were legit flying there. That's WILD.
Old 03-11-2022, 06:24 PM   #678
azndavepgh
Drives: 2022 BRZ
Installed my STI duracon shift knob (ST35022ST400). I got mine from Black Hawk Japan, but Subispeed has them in stock. It took longer to get here, but the total cost was about the same.
azndavepgh is offline   Reply With Quote
The Following 2 Users Say Thank You to azndavepgh For This Useful Post:
Midnightsky (03-11-2022), PBR (03-11-2022)
Old 03-12-2022, 11:49 PM   #679
eyeballs
Drives: '22 BRZ
Swapped out the winter wheelset, installed crash bolts for more camber, flushed out the OE brake fluid for higher temp, and installed higher temp pads. The pad clips on these cars are odd and annoying. Haven't driven the car yet, but 3 presses of the tpms button did not yield a psi readout as it states in the manual (had the sensors previously paired as a 2nd set at the dealer before they were fitted to the wheels).
eyeballs is offline   Reply With Quote
Old 03-13-2022, 08:37 PM   #680
AK2112
AK2112's Avatar
Drives: 22 BRZ
Did the standard LED stuff. Map lights, trunk light and reverse lights.
Dzmitry (03-17-2022)
Old 03-13-2022, 10:40 PM   #681
Panda Grahams
Panda Grahams's Avatar
Drives: '22 BRZ
Finally, past the break-in period! The car is amazing above 5k; really fun tying corners together in the higher revs.
Panda Grahams is offline   Reply With Quote
The Following User Says Thank You to Panda Grahams For This Useful Post:
kaesu (03-13-2022)
Old 03-13-2022, 11:04 PM   #682
mr.whiskers
Drives: '22 BRZ
Got a Crosstrek spare tire from a junkyard and put it in the car.
I noticed theres basically no insulation in the spare tire compartment, just painted metal. So I had this roll of thin foam insulation lying around, cut a circle out of it and stuck it in there.
Also theres already a nut welded into the floor, which is nice. I found a bolt with a proper thread and drilled a hole in a small piece of wood to use it as an improvised spare tire hold down bracket.
Also happy that all the stuff I had in the organizer fit into the spare tire, so the floor is perfectly flat.
Very happy with this purchase and a peace of mind from having a proper sparetire, not just a fix-a-flat kit.
mr.whiskers is offline   Reply With Quote
The Following 5 Users Say Thank You to mr.whiskers For This Useful Post:
EZLVN (03-14-2022), H380 (03-15-2022), kaesu (03-13-2022), LRNAD90 (03-14-2022), soundman98 (03-14-2022)
Old 03-13-2022, 11:38 PM   #683
kaesu
Drives: 22 BRZ
Installed the sti transmission mount and Cusco differential rear collar mount. Really eliminated a lot of the slack. There's a little bit of gear whine if you listen close enough, especially in 6th gear. There was a bit more NVH though. Not a lot but noticeable.
kaesu is offline   Reply With Quote
The Following User Says Thank You to kaesu For This Useful Post:
PBR (03-14-2022)
Old 03-14-2022, 08:34 PM   #684
PhatFreshPrince
PhatFreshPrince's Avatar
Drives: 2022 BRZ Limited SBP
I got my windows tinted. I went with XPEL PRIME XR BLACK 35. It states that it blocks 78% of the infrared light. I doubt it will keep it cool in the summer down south.
PhatFreshPrince is offline   Reply With Quote
Old 03-14-2022, 10:11 PM   #685
danson
Drives: 22 brz
Installed my a129 duo plus dashcams. At first I was intimidated by cable management and fiddling with the trim, but it was way easier than I anticipated. I just tucked the wires behind the headliner, into the a pillar trim, then behind the trim on the side of the glove box. For the rear, I did the same path, but went high behind the top of the a pillar piece, then into the headliner above the passenger door, down the b pillar and along the top of the tiny window. I was able to stuff about 5' of excess cable into the c pillar behind the trim, then along head liner to the cam. There's no wires showing at all, couldn't be happier!!
danson is offline   Reply With Quote
The Following User Says Thank You to danson For This Useful Post:
Pete (03-15-2022)
Old 03-15-2022, 01:20 AM   #686
Sym
Sym's Avatar
Drives: 2022 BRZ
Word of caution with the C pillar cable management - there's a lot of space back there so you might end up with a rattle if you didnt wrap up/secure the cables first.
Sym is offline   Reply With Quote
WHAT DID YOU DO TO YOUR FRS TODAY? KalbiCool88 Scion FR-S / Toyota 86 GT86 General Forum 1 11-04-2015 10:36 PM
Do you know what today is? Yruyur Off-Topic Lounge [WARNING: NO POLITICS] 26 01-21-2015 02:51 PM
just got my OFT today...help please! carlitosway6891 Software Tuning 9 02-20-2014 10:05 PM
TODAY, TODAY, I GET IT TODAY!!!! :D Trashed675 Scion FR-S / Toyota 86 GT86 General Forum 54 02-14-2013 01:16 AM
