Go Back   Toyota GR86, 86, FR-S and Subaru BRZ Forum & Owners Community - FT86CLUB > 2nd Gens: GR86 and BRZ > BRZ Second-Gen (2022+) — General Topics
BRZ Second-Gen (2022+) — General Topics General topics for the second-gen BRZ
Old 02-24-2022, 12:08 AM   #71
2020BRZtS
2020BRZtS's Avatar
Drives: '20 BRZ tS (15/300) / '09 Scion tC
Here is something to try. This is not a proven solution but a few people with 2020's including myself felt there is an improvement.
Connect your phone to the car with a USB cable.
Play music from the music app that comes with your phone and use the sound settings on your phone to adjust to your taste.
Unplug your phone and listen to the radio.
In my case the EQ settings from my phone stayed even though the settings page on the HU remained untouched. I can replicate it by resetting to factory and doing the procedure again.
2020BRZtS is offline   Reply With Quote
Old 02-24-2022, 09:49 AM   #72
Desertnate
Spelling Impaired
Drives: 2022 BRZ Limited WR Blue
When you do this I assume you leave the head unit EQ flat in the middle across all three bands?
Desertnate is offline   Reply With Quote
Old 03-08-2022, 12:09 AM   #73
McMCOO
Anti-Social Media
McMCOO's Avatar
Drives: 24 GR86 Premium MT is on the way!
Originally Posted by Robert97 View Post
I'm curious if a simple speaker upgrade will help. I see that OEM Audio sells an upgraded set of front speakers for $400. Has anyone tried these?
I contacted them today because their description on the website was contradictory and confusing. What they are offering is upgrades for the dash tweeters and the 6.5 inch door speakers.
McMCOO is offline   Reply With Quote
Old 03-08-2022, 12:36 AM   #74
LRNAD90
Drives: X5 35d, D90, CX-5 Turbo
For what it is worth, they indicated they are workign on a full system for the second gen, but no release date yet...
LRNAD90 is offline   Reply With Quote
Old 03-08-2022, 10:48 AM   #75
AK2112
AK2112's Avatar
Drives: 22 BRZ
I've got the base 6 speaker system and it's totally fine. It's a little weird that you get almost nothing from the rears but beyond that... Totally ok.
AK2112 is offline   Reply With Quote
Old 03-08-2022, 11:18 AM   #76
CincyJohn
Drives: 2022 MT Neptune GR86 Prem.
That may be true for you, and for people that don't listen to anything other than podcasts, but I doubt that's true for everyone. I had the 8 speaker in the Gen 1 that was faaaarrrr from "totally fine" - and from what I understand, the system in the Hakone was far, far worse. I am hopeful that the 8 speaker system in the premium (which I have seen some sites erroneously say includes a subwoofer) is better, hopefully much better, than the system in the Gen 1 but I am not optimistic.
The part of giving up my Gen1 that I am most upset about is losing the $700 (and lots of time, energy) I put into that stereo system (tons of dynamat, total upgraded rewire and all new speakers, two amps and a DSP). The only reason I was able to do it that cheap is some used components and access to wholesale purchase prices.
If I have to upgrade the Gen2 (and I am sure I will) I would like to do something that doesn't require the rewire and is a little more plug and play without paying the OEM Plus price - but I am not sure that will be possible.
CincyJohn is offline   Reply With Quote
Old 03-08-2022, 11:57 AM   #77
LRNAD90
Well, the upside is that the speakers and components could be transferred to the Gen 2, since it uses the same speaker sizing and placement..
Old 03-08-2022, 04:25 PM   #78
CincyJohn
The real money/value was in the two amps, DSP and time spent in wiring and putting in dynamat. The rear and front speakers, while better, weren't that expensive. The front doors were fairly expensive speakers but I got them cheap, used from a friend and actually have another pair for the Gen 2 if I do that. Taking it back to stock would have been a royal pain for the $600 or so I would have gotten back out of it so I just left it. Somebody is going to get a pretty nice stereo without probably even realizing it because the head unit is the same and none of the changes can be seen/known without looking for them. I am going to leave a manual for the DSP (which you can connect to via bluetooth) in with the stuff.
Old 04-21-2022, 01:15 AM   #79
Grif
Grif's Avatar
Drives: BRZ 2nd gen
What is everyone running for their 6 speaker settings?
I haven't had a chance to play around with mine much yet, however thought to put the question out there before I start fiddling.
Grif is offline   Reply With Quote
Old 04-21-2022, 10:34 PM   #80
Midnightsky
Midnightsky's Avatar
Drives: 2022 BRZ WRB
Im running these settings and am satisfied.
Midnightsky is offline   Reply With Quote
The Following 2 Users Say Thank You to Midnightsky For This Useful Post:
Desertnate (04-22-2022), Grif (04-23-2022)
Old 04-22-2022, 05:54 PM   #81
OkieSnuffBox
Drives: '23 BRZ Limited
Just play around with them and see what sounds good to you.
Old 04-22-2022, 06:34 PM   #82
Panda Grahams
Panda Grahams's Avatar
Drives: '22 BRZ
I recommend trying out the "Virtual Stage Enhancer" under Vocal Image Control. It definitely helps blend the audio between the drivers, instead of shouting through each one.
Panda Grahams is offline   Reply With Quote
The Following 3 Users Say Thank You to Panda Grahams For This Useful Post:
DylanJZA (05-11-2022), Grif (04-30-2022), Yoshoobaroo (04-22-2022)
Old 04-22-2022, 07:44 PM   #83
Yoshoobaroo
TRACKBREAD
Yoshoobaroo's Avatar
Thanks! I never played with it before, I just ignored the post processing so far. It really added some punch to the sound, without making it muddy or rattling the door cards, which is what upping the bass does.
Old 04-22-2022, 10:00 PM   #84
AK2112
AK2112's Avatar
Drives: 22 BRZ
Wow, first I've heard anyone liking the extra settings. I shut them all off and have the eq nearly flat (plus 1 bass, minus 1 mids and minus 1 treble)
I'll give the stage enhancer a shot just for fun.
Speakers For Better Sound Quality Kaotic Lazagna Electronics | Audio | NAV | Infotainment 24 01-17-2019 11:24 PM
Why Processing is ESSENTIAL To Sound Quality TOOSTUBBORN2FAIL Electronics | Audio | NAV | Infotainment 38 06-03-2016 04:17 PM
Help with Sound Quality otterpop Electronics | Audio | NAV | Infotainment 5 02-01-2015 02:43 PM
HD Radio - sound quality? ('14 BRZ) MysteryMachine Electronics | Audio | NAV | Infotainment 21 02-13-2014 03:34 PM
The quality of the stock sound system?? Jruex22 Electronics | Audio | NAV | Infotainment 15 08-13-2012 05:59 AM
