| BRZ Second-Gen (2022+) — General Topics General topics for the second-gen BRZ |
Drives: '22 BRZ
Sound System quality is bad?
Hey everyone - I'm a new member here and got my new BRZ (Limited) recently. I love everything about it, except the speaker quality which I found to be cheap sounding at best. Is this just me? I have the limited variant as well, with the 'premium' speakers. Cant imagine how the base version sounds.
My other vehicle is a MK7 GTI with the non-premium speakers and they sound much better in comparison. Maybe its the additional road noise that's affecting my perception. |
Drives: 2022 GR86
Congrats!
i could be wrong, but as far as i have seen it DOES NOT say ""premium" speakers" in any specifications, just that the PREMIUM trim comes with 8 speakers instead of 6. are you listening on spotify (or another streaming service?) ;P because spotify is TERRIBLE especially thru mobile data. using bluetooth VS a hardwired connection will also effect the quality |
#3 | |
Drives: 2014 Mazda CX-5
Unless the specs from Subaru are wrong, both versions get 8 speakers. It's the GR86 that the higher trim gets 8 speakers vs 6 for the base. |
Drives: 2013 Scion FR-S Series 10
I had a MK6 GTI with the base 8 speaker system and it was really good.
First thing I noticed with the FRS is how hollow everything sounded. The 1st gen had 8 speakers standard. But whether it is 8, 6, or 4, there is only so much you can do. It is mostly the lack of insulation, but then you are also dealing with a small cabin and the placement of the speakers firing either at your feet or directly up into the windshield. I think some people find that a sub and replacing all of the speakers can overcome some of that, but I don't think it will ever exceed "just okay." |
Drives: 2022 GR86
I also didn't like how the sound system sounds with the default sound settings, but having spent just a couple of minutes with it I found the quality to improve slightly after I reduced treble a bit in the EQ and moved the "fade" slightly towards the rear.
#6 | |
Drives: Scion FR-S
Drives: Subaru BRZ
Stereo is ok at best. it has no subwoofer (unless you add one) which does help sound clarity with crossovers and all that.
Will it match a Miata Bose, or a GTI Harman Karman sound system: No. |
#8 | |
Drives: '22 BRZ
And I do use Spotify (over BT or Android Auto). Will test w/ an aux wire to see if that makes any difference. |
Drives: 2022 GR86
#10 |
Drives: '22 BRZ
Probably this. The sub-woofer makes a big difference I think.
#11 |
Drives: '22 BRZ
I've set it to 'High' and the auto-adjust feature is off.
#12 | |
Drives: 2022 GR86
If you really care about audio quality first thing you should do is delete spotify :P its really quite bad |
#13 |
Drives: 22 BRZ limited
The moroney label is the window sticker.
#14 | |
Drives: 22 BRZ
https://www.whathifi.com/us/advice/s...nd-latest-news Looks like spotify will have a lossless streaming option soon.
2013 FRS -> 2011 CTS-V -> 2006 Cayman S -> 2015 GTI -> 2022 BRZ
| Speakers For Better Sound Quality | Kaotic Lazagna | Electronics | Audio | NAV | Infotainment | 24 | 01-17-2019 10:24 PM |
| Why Processing is ESSENTIAL To Sound Quality | TOOSTUBBORN2FAIL | Electronics | Audio | NAV | Infotainment | 38 | 06-03-2016 03:17 PM |
| Help with Sound Quality | otterpop | Electronics | Audio | NAV | Infotainment | 5 | 02-01-2015 01:43 PM |
| HD Radio - sound quality? ('14 BRZ) | MysteryMachine | Electronics | Audio | NAV | Infotainment | 21 | 02-13-2014 02:34 PM |
| The quality of the stock sound system?? | Jruex22 | Electronics | Audio | NAV | Infotainment | 15 | 08-13-2012 04:59 AM |
