Old 02-19-2022, 07:16 PM   #57
Locust
Custom User Title
Locust's Avatar
Drives: 2015 Scion FR-S, 2012 OB Evo X MR
Send a message via AIM to Locust
Originally Posted by e1_griego View Post
I thought you sold your car?
I have been running Amsoil and like it a lot.
Originally Posted by Locust View Post
Thanks! I'll give it a look.
The car goes to the Millers as soon as I get the new one but Toyota producing almost 2/3rds of the 86es as ATs and having a really bad allocation of Neptune Blues has delayed that. Chris and I talked it over and I'm going to keep running the current one until I can get the new one. But my coilovers are off for a rebuild soooo who knows if I'll even have a car for Fontana...
Also I am fixing the clutch/transmission before I sell it to them so this is kinda part of that
LOCUST
2015 FR-S (STX) and 2012 Evo X MR
Instagram:
LocustAutoX
Sponsors:
DSGPerformance Drift Office Evil Apex Racing
Locust is offline   Reply With Quote
The Following User Says Thank You to Locust For This Useful Post:
e1_griego (02-20-2022)
Old 02-23-2022, 06:13 PM   #58
strat61caster
strat61caster's Avatar
Drives: '13 FRS - STX
Tried a052 for the first time this weekend, played with pressures from 30-38 psi (hot) with no discernible difference other then a minor change in feel. Pyrometer seemed to prefer the high side. What pressure do y’all run?
245/40/17 Yokohama A052 on 17x9 STX prepped twin (-4F/-2.5R ish camber).
ineedyourdiddly
Old 02-23-2022, 06:31 PM   #59
Eric1855
Drives: LP DSP / CSP '13 BRZ
I run what Ray ran before me and he did a lot of testing. Basically somewhere around 30/30 and adjust up and down +/-2psi based on the surface or car feel like 32/30 or 30/28. Its all very slight changes and also change car to car with other suspension setups. The only real good answer is to start somewhere, find a TnT, and see what works best for you and your car.
Eric1855 is offline   Reply With Quote
The Following 2 Users Say Thank You to Eric1855 For This Useful Post:
DocWalt (02-24-2022), strat61caster (02-23-2022)
Old 02-24-2022, 12:55 AM   #60
e1_griego
e1_griego's Avatar
Drives: Many
Not that I'm any good at it, but yeah 30/28 is where i usually start.
e1_griego is offline   Reply With Quote
The Following 2 Users Say Thank You to e1_griego For This Useful Post:
smg1138 (04-03-2022), strat61caster (02-24-2022)
Old 02-24-2022, 06:24 AM   #61
steverife
Drives: 2016 Scion FRS
I'm a bit lower. I've ran as low as 25/25 at low grip places and 27/27 on concrete.
...but I also tend to like vague tires, "overheated" tires, shocks on soft, etc.
steverife is offline   Reply With Quote
The Following User Says Thank You to steverife For This Useful Post:
Old 02-24-2022, 11:33 AM   #62
PointDSM
PointDSM's Avatar
Drives: 2013 Subaru BRZ
We found that running pressures below ~28psi created a "spring rebound" effect with the AO52's. Setting the tires entering the corner but when the sidewall snaps back (versus the tire loosing grip), the results are not good. 29/28 to 33/33 was the ballpark to play in.
PointDSM is offline   Reply With Quote
The Following User Says Thank You to PointDSM For This Useful Post:
Old 02-24-2022, 10:59 PM   #63
Breezio
Breezio's Avatar
Drives: 2017 BRZ series.yellow
28 in the front 26-27 in the rear when hot is what I have run the past couple seasons with A052s.
Breezio is offline   Reply With Quote
The Following User Says Thank You to Breezio For This Useful Post:
strat61caster (02-25-2022)
Old 03-02-2022, 02:31 PM   #64
Autoxer62
For anyone on the fence, there are only four entries in STX for the Tour at FedEx next month. I'm sure everyone would be happy to see a fifth entry
Well, maybe not everyone if you win, but I'm in no danger of that
-- Bryan Blackwell --
2020 Hakone 86 -- KW V2 6k&9k/Karcepts Sway Bars/SPC&Diftech RCLA/SuperPro bshngs/17x9 RPF1/255-40-17 RT660/Hawk5.0 Pads/RacerX MC Brace
Autoxer62 is offline   Reply With Quote
Old 03-02-2022, 03:32 PM   #65
e1_griego
e1_griego's Avatar
Drives: Many
Is anyone else signed up for Vegas Tour?
We had a good battle last year, but Kate is now gone and Mudge moved to the East Coast :sadpanda:
Old 03-02-2022, 03:32 PM   #66
e1_griego
e1_griego's Avatar
Drives: Many
Is anyone else signing up for Vegas Tour?
Old 03-02-2022, 04:17 PM   #67
PointDSM
PointDSM's Avatar
I would be interested in flying out there if a co-drive presented itself (my actual name is Eric Niemi)? Maybe we can get Manfred to come out as well?
Same goes for the Fedex tour event.
Winter's been long as usual here in Wisconsin...
Old 03-02-2022, 04:59 PM   #68
Autoxer62
Alas, I don't have an open seat, sorry.
The Following User Says Thank You to Autoxer62 For This Useful Post:
PointDSM (03-02-2022)
Old 03-02-2022, 05:11 PM   #69
ConnorJ
ConnorJ's Avatar
Drives: 2015 Series.Blue Subaru BRZ
2015 Series.Blue BRZ
Tein Flex Z Suspension (In the process of buying KW V3s)
SPC Rear Lower Control Arms w/ STX bushings
JDL 4-2-1 Catless Header
Perrin Overpipe, Catted Frontpipe, and Catback
Injen Tuned Intake
Xero Limit EcuTek Tune
Delicious Tuning Blue Coil Packs
17x9 45mm offset
10mm Eiback Spacers
ARP Studs w/ Gorilla Lug Nuts
Whiteline 19mm Front Sway Bar (soft setting, probably moving to stiffer setting next week)
I'm keeping my eyes open for a Mann rear sway bar and maybe a larger front bar. What else do you recommend I keep an eye out for, other than seat time, because I need about all of that I can afford.
I'm aiming to be at the Bristol events this year, but that's likely the only national level events I'll make it to. I'm regretting not being more social at Nats last year, so maybe I'll meet some of you in Bristol.
Connor Johnson
2015 Subaru BRZ Series.Blue
Tennessee Valley Region - STX #15
ConnorJ is offline   Reply With Quote
Old 03-02-2022, 09:21 PM   #70
Kelse92
At the track
Drives: '14 FRS - Former e92 M3
While we’re on the talk of traveling to events. I’m interested in an L3 ProSolo event or two if anyone has an open seat for any of those later this year.
#ladydriven Nasa TT4 FRS // JRZ RS Pro // Karcepts Sway Bars // K24 Swap (in Progress) // AP Endurance BBK // Cobalt Friction brake pads // Safeplace Auto
Kelse92 is offline   Reply With Quote
The 2022 Autocross Thread trippinbillies40 Tracking / Autocross / HPDE / Drifting 11 02-26-2023 06:13 AM
STX setup sharing thread (2021) Autoxer62 Tracking / Autocross / HPDE / Drifting 366 12-07-2021 02:57 PM
STX setup sharing thread (2020) Autoxer62 Tracking / Autocross / HPDE / Drifting 389 12-29-2020 02:40 PM
STX setup sharing thread (2019) CoolHandMoss Tracking / Autocross / HPDE / Drifting 109 02-17-2020 12:27 PM
STX Set-Up Sharing & Results Thread race2win Tracking / Autocross / HPDE / Drifting 76 02-16-2017 12:30 PM
